Wordpress weird wordpress issue
Discussion in 'Blogs & CMS usage' started by Moe, Mar 11, 2018.
  1. Moe
    Moe New Member
    Jupiter
    5:25 AM
    1.9.7
    I have installed centminmod Wordpress with Redis and something too weird is happening
    my WordPress keeps frozen no matter what changes I do to it.for example I activate a theme but doesn't change.I try to delete a file but doesn't delete
    please help me if anyone is having a similar problem and what might what is causing that
    note I disabled all plugins and changed multiple themes
    44,483
    10,164
    12:25 PM
    did you have redis object cache wp plugin enabled ? i'd disable that and do a hard refresh in web browser CTRL+F5 after clearing wordpress cache from wordpress admin
    what file and how was it installed/uploaded ?
    are you using redis for any other web apps storage/caching ?
  3. Moe
    Moe New Member
    Jupiter
    5:25 AM
    1.9.7
    truly weird
    I deleted all plugins and everything back to normal
    I will reinstall same plugins one by one to see which one caused the problem
    note:i have php 7.3 installed
  4. Moe
    Moe New Member
    Jupiter
    5:25 AM
    1.9.7
    Seems problem was Wp Redis plugin
    once I press enable Redis Object Cache and enable database cache my site become truly stupid
  5. Moe
    Moe New Member
    Jupiter
    5:25 AM
    1.9.7
    PHP 7.2.3
    44,483
    10,164
    12:25 PM
    yeah leave off redis object cache it's not enabled by default in centmin.sh menu option 22 wordpress installer for this reason
  7. johanguse
    johanguse New Member
    11:25 PM
    1.11.13
    44,483
    10,164
    12:25 PM
    If you edit php files directly, zend opcache only rechecks updates by default every 180 seconds, so to flush zend opcache caching after editing php files directly = restart php-fpm service and nginx for nginx cache
    you can restart both nginx and php-fpm via cmd shortcut
    nprestart
