Wordpress Cache-Enabler Plugin Weird issue with Cache Enabler
Discussion in 'Blogs & CMS usage' started by Jay Chen, Sep 18, 2018.
  1. Jay Chen
    Jay Chen Active Member
    187
    60
    11:34 AM
    I am going to try other cache, do I need to modify ant config on CMM side? I know Cache Enabler has some config, not sure if same is needed for other cache plugin, primarily Hyper Cache.
  2. ndha
    ndha Member
    10:34 PM
    1.27
    10.6
    Yeah,, i already reported in here when cache enabler had problem with mobile version since they update it..
    now i switch to wp fastest cache problem gone..
    1:34 AM
    Yes see Wordpress - Disable Or Remove KeyCDN Cache Enabler
    so same problem you reported at Wordpress - WP Cacher Enabler Plugin by KeyCDN folks, don't think you replied to my troubleshooting questions there.
  4. Jay Chen
    187
    60
    11:34 AM
    Initially I thought this is a mobile issue, but I was able to reproduce the same cache issue on desktop as well. At this point, I am going to switch to a different cache plugin and hopefully this willl resolve the probekem.
    1:34 AM
    FYI, been testing this myself for Cache Enabler 1.3.1 with/without mobile cache exclusions and desktop and mobile update fine for me when editing wordpress blog posts.
  6. Jay Chen
    187
    60
    11:34 AM
    I am not editing post, I have a lot of posts scheduled, when one post is published, cache enabler should have invalidated the home page cache, but for some reasons, it is not.
    1:34 AM
    But does editing posts deal with cache invalidation properly for your ?
    I haven't tested scheduled posts so will do that.
    FYI, Cache Enabler older 1.2.3 had some fixes for scheduled posts keycdn/cache-enabler though latest is 1.3.1
    1:34 AM
    Just tested and scheduled posts work fine here with Cache Enabler 1.3.1 in both logged in and logged out visitors in Chrome and Canary web browsers on desktop
    edit: ok Chrome on mobile seems to not properly show scheduled post updates but Canary on mobile did
    edit2: ok it's showing up when i scheduled the time properly now had it set UTC time instead of GMT +10 my time so mobile shows up scheduled posts
  9. Jay Chen
    187
    60
    11:34 AM
    I haven't try it yet, I have removed the plugin.
    I will reinstall the plugin and try it out sometime next week.
    Now I am playing with hyper cache, I like the option that invalidates the most recent x posts when post is published. This way next and previous buttons are in sync.
  10. Jay Chen
    187
    60
    11:34 AM
    After close monitoring hypercache for the past few days, I realized that hypercache is having the same issue with cache enabler, which is not invalidating cache when a new scheduled post is published.
    This led me to think maybe the problem is on my end.
    What is interesting is that the timestamp on the cached page is
    <!-- hyper cache 2018-10-06 03:55:14 -->
    but when I checked CMM, the time is correct, which is also the same as what Wordpress show under General -> Timezone
    [11:54][root@newssdnodes-85656 ~]# date
    Sat Oct  6 11:55:43 EDT 2018
    I will disable the plugin for now until I figured out a solution. Sorry for misleading your guys.
  11. Jay Chen
    187
    60
    11:34 AM
    I am back with an update:
    So the problem is caused by a cloudflare page rule, it is set to cache everything, I didn't know cloudflare cache html as well.
    Once I turn this rule off, the problem goes away. I have been testing and monitoring for over a week now, everything seems to be working fine. With that being said, I will keep using Hyper Cache, because it option to invalidate the most recent X posts.
    Thank you all for helping, especially eva.
    1:34 AM
