Install 140.00beta01 vs 141.00beta01
Discussion in 'Install & Upgrades or Pre-Install Questions' started by pamamolf, May 20, 2026.
    4,128
    8:07 PM
    What's the difference and can we just use:
    branchname=141.00beta01
    cd /usr/local/src
    rm -rf centminmod*
    cd centminmod
    ./centmin.sh
    to replace the 140.00beta01?
    Thanks !
  2. Itworx4me
    344
    35
    10:07 AM
    Nginx 1.27.4
    MariaDB 10.6.21
    I followed this and didn't have any issues. I was running 140.00beta01 and upgraded to 141.00beta01 with no issues.
  3. pamamolf
    4,128
    8:07 PM
    Thanks for your reply...
    Probably it get's first some updates?
    But does the OS is important and we may not use it on specific OS versions like Centos 7, Almalinux 8,9 Rocky Linux etc?
    3:07 AM
    Centmin Mod 141.00beta01 is solely for EL10 development and testing but is backwards compatible with EL7, EL8, EL9 OSes https://community.centminmod.com/th...0-rocky-linux-10-compatibility-worklog.29603/
    Yes you can those manual commands to switch to any Centmin Mod branch usually.
  5. iaTa
    iaTa Member
    101
    6:07 PM
    MariaDB 10.11.x
    Since following the code replacement instructions for 140.00beta01, running cmupdate shows the following:
    root@server:~#cmupdate
    From https://github.com/centminmod/centminmod
     * branch            140.00beta01 -> FETCH_HEAD
    Is that expected?
    3:07 AM
    normal but fixing that with more user friendly message right now
    3:07 AM
    restored friendlier messages
    cmupdate
    Updating Centmin Mod code
    * 141.00beta01
    Checking for updates on origin/141.00beta01 ...
     * branch            141.00beta01 -> FETCH_HEAD
    Already up to date with origin/141.00beta01 at fcee543.
    Latest commit: fcee543 (2026-05-20)
        wrap cmupdate latest-commit line to fit 80-col terminals in 141.00beta01
    Updated Centmin Mod code
  8. iaTa
    iaTa Member
    101
    6:07 PM
    MariaDB 10.11.x
    Great, and one other point regarding the new compact fancy DMOTD - is this message necessary:
    [!!]  ! Older branch (140.00beta01) — newer: 132.00stable or 141.00beta01 (threads/25572)
    Also, the new cmupdate output states Updating... and Updated... even when everything is already up to date.
    3:07 AM
    Yeah update fixed a bug which now shows this message as actually intended, so yes message is meant to show now the bug is fixed. But will re-word it
