WebPerf Webp Not working after configuring nginx
Discussion in 'Web Development & Web Performance' started by pheonis, Mar 22, 2019.
  1. pheonis
    pheonis Member
    62
    11:21 PM
    I am using Wordpress. Recently i found out the benefits of webp image format and wanted to use it in my wordpress website.
    I followed the steps mentioned here https://centminmod.com/webp/
    But the end at the end when i checked my website its still serving jpg. Is there anything need to be done after these steps?
    NOTE : I am also using cloudflare
    and how can i install and use optimise-images.sh script. I have no idea and there is no documentation i can found.
    45,974
    10,444
    3:51 AM
    you won't see webp images until you make a copy of your jpg/png files which is webp format converted. The steps at https://centminmod.com/webp/ are just to tell nginx to server webp extension files if they exist to supported browsers. If no webp version of the image exists, it won't server webp.
    first sentence on the webp linked page links to optimise-images.sh docs via hyperlink = optimise-images.sh
    also discussed at https://community.centminmod.com/th...age-load-times-with-optimise-images-sh.11533/
    and in wordpress context at https://community.centminmod.com/th...-optimizer-wordpress-plugin.12573/#post-53333
    45,974
    10,444
    3:51 AM
