PHP-FPM WARNING: [pool pool5] server reached max_children setting (4), consider raising it
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Matt Williams, Dec 16, 2015.
  1. Matt Williams
    537
    104
    Virginia, USA
    8:32 PM
    latest
    Where would I edit [pool pool5] ? I know the main one fpmconf but where do I edit the different pools 2-5?
    55,941
    10:32 AM
    see Beta Branch - Centmin Mod .08 beta03+ Multiple PHP-FPM pools support added | Centmin Mod Community
    Each phpfpm_poolX.conf file respectively has a listen = 127.0.0.1:9002 through to 127.0.0.1:9005, their own slowlog, pm.status_path, ping.path, own php-fpm-poolX.sock path (commented out), own error_log path at /var/log/php-fpm/www-php.error-poolX.log and named the pools as pool2, pool3, pool4, and pool5.
    ls -lah /usr/local/nginx/conf/phpfpmd
    total 24K
    drwxr-xr-x 2 root root 4.0K Jun 26 05:57 .
    drwxr-xr-x 5 root root 4.0K Jun 26 05:34 ..
    -rw-r--r-- 1 root root 1.8K Jun 26 05:55 phpfpm_pool2.conf
    -rw-r--r-- 1 root root 1.7K Jun 26 05:35 phpfpm_pool3.conf
    -rw-r--r-- 1 root root 1.7K Jun 26 05:35 phpfpm_pool4.conf
    -rw-r--r-- 1 root root 1.7K Jun 26 05:35 phpfpm_pool5.conf
    so /usr/local/nginx/conf/phpfpmd/phpfpm_pool5.conf
