vhost SSL problem
Discussion in 'Install & Upgrades or Pre-Install Questions' started by aidzo, Nov 15, 2018.
  1. aidzo
    aidzo New Member
    6:53 AM
    When setting up a second website with option 2 in centmin.sh with cloudflare dns ssl doesn't seem to work not sure how to fix it tried everything.
    • CentOS Version: Centos 7 64 BITS
    • Nginx Version Installed: 1.15.6
    • PHP Version Installed: 7.2.12
    38,027
    8,352
    4:53 PM
    How was the initial letsencrypt ssl certificate obtained ? Which method ?
    • Was the domain nginx vhost alreadying created prior or new domain nginx vhost site setup for first time ?
    • Via centmin.sh menu option 2, 22, /usr/bin/nv ?
    • If you ran centmin.sh menu option 2 or 22, which letsencrypt option did you select from
      Setup full Nginx vhost + Wordpress + WP Plugins
      Enter vhost domain name you want to add (without www. prefix): acme3.domain1.com
      You have 4 options:
      1. issue staging test cert with HTTP + HTTPS
      2. issue staging test cert with HTTPS default
      Enter option number 1-4: 1
    Troubleshooting
      ls -lahrt /root/centminlogs
      ACMEDEBUG='y'
    If acme.sh auto renewals didn't happen, check output for the following commands
    grep acme /var/log/cron* | sed -e "s|$(hostname -s)|host|g"
    echo | openssl s_client -connect yourdomain.com:443
    SSLLabs Test
    Also run your HTTPS domain site through SSLLabs tester at SSL Server Test (Powered by Qualys SSL Labs) if it says untrusted SSL cert and prompts to continue the test, continue the test.
