Versaweb Dedicated Servers (Las Vegas)
Discussion in 'Dedicated server hosting' started by eva2000, Aug 5, 2014.
    1,412
    12:58 AM
    Indeed, I got 190ms with them :)
    With Las Vegas location.
  2. rdan
    1,412
    12:58 AM
    I just order this server: Versaweb - Order Page
    Quarterly plan for now and with 240GB SSD.
    Still on 16GB ram, I think that's enough for me now.
    55,400
    12,255
    2:58 AM
    nice... yeah from your previous stats you showed, you weren't using anywhere near 32GB of memory, so 16GB should be fine
  4. rdan
    1,412
    12:58 AM
    But I'm little bit worried now, just read on their website that they just null route ddos attack IP.
    Not actually protect like SYS or OVH :(
    55,400
    12,255
    2:58 AM
    they have paid upgrades for premium DDOS protection between US$20-39/month for 10Gbit DDOS
  6. rdan
    1,412
    12:58 AM
    yeah it's $20
    Added amount :(
    I hope my budget can handle this. :(
    55,400
    12,255
    2:58 AM
    Guess you'll have to wait and see how it fairs for your member/visitor experience for Asian traffic :)
    It's reason why most my servers and VPSes are LA west coast USA types :D
  8. rdan
    1,412
    12:58 AM
    The only hosting I see that have West Coat is Linode and Vultr.
    55,400
    12,255
    2:58 AM
    There's quite a few more west coast USA web hosts on my short list which I use for consult client recommendations depending on their needs but probably all out of your budget with minimum US$150-450/month ranges heh. Los Angeles is generally more expensive for web hosting regardless compared to mid and east coast USA.
  10. rdan
    1,412
    12:58 AM
    So I got now 4 available IP's.
    So to avoid problems I need to declare each IP on each domain vhost right?
    And even my virtual vhost I need to declare a dedicated IP?
    55,400
    12,255
    2:58 AM
    not sure I understand, you'd want to add all 4 ips to your server if they haven't already been added and it's really up to you how you want to use them, a dedicated ip for some Nginx vhosts with listen dedicatedip:80 or a shared ip with just listen 80.
  12. rdan
    1,412
    12:58 AM
    Ok, I will declare each IP per vhost including virtual.conf.
    But for now, VNC setup didn't work on Versaweb server :(
    And there's no way I can reload the OS like SYS :(
    Can't boot the server, Ouch.
    55,400
    12,255
    2:58 AM
    VNC worked for me but I also tried their IPMI KVM console to load centos 6.5 netinstall iso from my pc install method too - much slower taking 2+ hrs but still worked. Slow part is netinstall.iso upload.
    You need to log into https://noc.versaweb.com/client/ to access the Device Manager > View Devices and click your server device id number. You can launch KVM console from there which will prompt you to download a *.jnlp file you need to run
    KVM console file will give warning and untrusted you need to accept and continue
    The default java KVM Console first screen is the familiar CentOS login prompt, from here you can log into your server and do all your SSH stuff like you normally would if you were blocked from normal SSH access.
    You need to click Virtual Media menu and select Virtual storage > Device 1 and from drop down menu select ISO file, then click open image and browse and select the CentOS-6.5-x86_64-netinstall.iso iso image file. Then click Plug in to mount the iso file to the server and hit OK. Then just reboot your server. You can log into prompt and do a reboot via command line and watch console screen boot up to load the netinstall.so just like for Netinstall guide at RamNode - CentOS 7.0 Netinstall Guide for RamNode CKVM VPS server | Centmin Mod Community
    For netinstall I used these mirrors:
    http://centos.mirror.ndchost.com/6.5/os/x86_64/
    http://centos.mirror.ndchost.com/7/os/x86_64/
    The iso you upload to KVM console is the netinstall.iso which is 243MB versus minimal.iso at 398MB - CentOS-6.5-x86_64-netinstall.iso
    launched IPMI netinstall you want to grab your server's existing ip settings from ifconfig -a and /etc/sysconfig/network and /etc/resolv.conf for your records as you'd need them later
    netinstall like as described at RamNode - CentOS 7.0 Netinstall Guide for RamNode CKVM VPS server | Centmin Mod Community needs network TCP settings.
    double check your gateway ip via ifconfig eth0 Mask reported ip address
  14. rdan
    1,412
    12:58 AM
    But on that way I need to upload my own ISO.
    And also I need to download it to my PC first, it will take hours :(
    55,400
    12,255
    2:58 AM
    yeah it will that's the price of cheaper dedicated, no full IPMI access with web login to load a url based ISO file.
  16. rdan
    1,412
    12:58 AM
    This would be great if they have this.
    55,400
    12,255
    2:58 AM
    yeah they don't :(
    FYI, you get 1 free OS reload per month. Then additional is US$25 per reload if you need quicker OS reloads that they can do for you too.
  18. rdan
    1,412
    12:58 AM
    I will follow your guide now @eva2000
    Thanks a lot!
    55,400
    12,255
    2:58 AM
    one more thing, why do reinstall ? their provided OS is barebones and clean so unless you want to repartition, you can always use the default provided OS. But learning how to use IPMI java KVM console on emoty server is worth the experience anyway :D
  20. rdan
    1,412
    12:58 AM
    My bad, I thought it was full centos setup.
    I tried to re-install because I want minimal setup.
