Versaweb Dedicated Servers (Las Vegas)
Discussion in 'Dedicated server hosting' started by eva2000, Aug 5, 2014.
    1,412
    7:38 PM
    Nah!
    If Versaweb offer refund if I want to.
    I will try their server right now :)
    And see the difference.
    55,906
    12,281
    9:38 PM
    don't think they do.. might need to check their web site.. or wait until I load my server with some test site data you can see
    Although you can pretty much see the diff just by visiting this forum - Freemont, California region at Linode :)
    edit: okay Freemont would be faster location than Las Vegas Fremont, CA - Google Maps heh. Maybe ~10-15ms ping difference
  3. rdan
    1,412
    7:38 PM
    Their FB page has bad reviews :D
    55,906
    12,281
    9:38 PM
  5. rdan
    1,412
    7:38 PM
    Can't wait Nginx 1.7.4, I just applied this my live server :)
    Thanks!
    55,906
    12,281
    9:38 PM
    well Nginx 1.7.4 is here now Nginx - [nginx-announce] nginx-1.7.4 | Centmin Mod Community
    updated this dedicated server at Versaweb too
    and MariaDB 5.5.39 update MariaDB - MariaDB 5.5.39 now available | Centmin Mod Community
  7. rdan
    1,412
    7:38 PM
    Yeah, upgraded again my server :D
    55,906
    12,281
    9:38 PM
    Severbear benchmark for my server seems a bit lower than my previous benchmark prior to reloading OS i.e. Unixbench was ~7400 mark Benchmark Report: E3-1240v3 32GB 250GB SSD @ VersaWeb
    Read IOPS    71329.0
    Read Bandwidth    285.3 MB/second
    Write IOPS    66331.0
    Write Bandwidth    265.3 MB/second
    Cachefly    71.4 MB/s
    Linode, Atlanta, GA, USA    28.6 MB/s
    Linode, Dallas, TX, USA    27.7 MB/s
    Linode, Tokyo, JP    14.8 MB/s
    Linode, London, UK    11.2 MB/s
    OVH, Paris, France    9.93 MB/s
    SmartDC, Rotterdam, Netherlands    4.61 MB/s
    Hetzner, Nuernberg, Germany    155 KB/s
    iiNet, Perth, WA, Australia    6.54 MB/s
    MammothVPS, Sydney, Australia    1.26 MB/s
    Leaseweb, Haarlem, NL    10.1 MB/s
    Leaseweb, Manassas, VA, USA    16.4 MB/s
    Softlayer, Singapore    10.4 MB/s
    Softlayer, Seattle, WA, USA    46.8 MB/s
    Softlayer, San Jose, CA, USA    60.7 MB/s
    Softlayer, Washington, DC, USA    29.4 MB/s
       BYTE UNIX Benchmarks (Version 5.1.3)
       System: ******************
       OS: GNU/Linux -- 2.6.32-431.23.3.el6.x86_64 -- #1 SMP Thu Jul 31 17:20:51 UTC 2014
       Machine: x86_64 (x86_64)
       Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
       CPU 0: Intel(R) Xeon(R) CPU E3-1240 v3 @ 3.40GHz (6784.7 bogomips)
              Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
       CPU 1: Intel(R) Xeon(R) CPU E3-1240 v3 @ 3.40GHz (6784.7 bogomips)
       CPU 2: Intel(R) Xeon(R) CPU E3-1240 v3 @ 3.40GHz (6784.7 bogomips)
       CPU 3: Intel(R) Xeon(R) CPU E3-1240 v3 @ 3.40GHz (6784.7 bogomips)
       CPU 4: Intel(R) Xeon(R) CPU E3-1240 v3 @ 3.40GHz (6784.7 bogomips)
       CPU 5: Intel(R) Xeon(R) CPU E3-1240 v3 @ 3.40GHz (6784.7 bogomips)
       CPU 6: Intel(R) Xeon(R) CPU E3-1240 v3 @ 3.40GHz (6784.7 bogomips)
       CPU 7: Intel(R) Xeon(R) CPU E3-1240 v3 @ 3.40GHz (6784.7 bogomips)
       14:20:52 up 14:05,  1 user,  load average: 0.00, 0.05, 0.14; runlevel 3
    Benchmark Run: Wed Aug 06 2014 14:20:52 - 14:48:55
    8 CPUs in system; running 1 parallel copy of tests
    Dhrystone 2 using register variables       40378059.9 lps   (10.0 s, 7 samples)
    Double-Precision Whetstone                     4286.2 MWIPS (9.9 s, 7 samples)
    Execl Throughput                               6017.0 lps   (30.0 s, 2 samples)
    File Copy 1024 bufsize 2000 maxblocks       1268516.8 KBps  (30.0 s, 2 samples)
    File Copy 256 bufsize 500 maxblocks          339232.5 KBps  (30.0 s, 2 samples)
    File Copy 4096 bufsize 8000 maxblocks       3171051.8 KBps  (30.0 s, 2 samples)
    Pipe Throughput                             2223114.7 lps   (10.0 s, 7 samples)
    Pipe-based Context Switching                 258701.1 lps   (10.0 s, 7 samples)
    Process Creation                              20129.2 lps   (30.0 s, 2 samples)
    Shell Scripts (1 concurrent)                   9666.1 lpm   (60.0 s, 2 samples)
    Shell Scripts (8 concurrent)                   4180.1 lpm   (60.0 s, 2 samples)
    System Call Overhead                        3150970.8 lps   (10.0 s, 7 samples)
    System Benchmarks Index Values               BASELINE       RESULT    INDEX
    Dhrystone 2 using register variables         116700.0   40378059.9   3460.0
    Double-Precision Whetstone                       55.0       4286.2    779.3
    Execl Throughput                                 43.0       6017.0   1399.3
    File Copy 1024 bufsize 2000 maxblocks          3960.0    1268516.8   3203.3
    File Copy 256 bufsize 500 maxblocks            1655.0     339232.5   2049.7
    File Copy 4096 bufsize 8000 maxblocks          5800.0    3171051.8   5467.3
    Pipe Throughput                               12440.0    2223114.7   1787.1
    Pipe-based Context Switching                   4000.0     258701.1    646.8
    Process Creation                                126.0      20129.2   1597.6
    Shell Scripts (1 concurrent)                     42.4       9666.1   2279.7
    Shell Scripts (8 concurrent)                      6.0       4180.1   6966.8
    System Call Overhead                          15000.0    3150970.8   2100.6
    System Benchmarks Index Score                                        2122.2
    Benchmark Run: Wed Aug 06 2014 14:48:55 - 15:17:06
    8 CPUs in system; running 8 parallel copies of tests
    Dhrystone 2 using register variables      184220115.1 lps   (10.0 s, 7 samples)
    Double-Precision Whetstone                    29765.8 MWIPS (10.0 s, 7 samples)
    Execl Throughput                              36539.8 lps   (30.0 s, 2 samples)
    File Copy 1024 bufsize 2000 maxblocks       1333515.8 KBps  (30.0 s, 2 samples)
    File Copy 256 bufsize 500 maxblocks          346394.2 KBps  (30.0 s, 2 samples)
    File Copy 4096 bufsize 8000 maxblocks       3880447.4 KBps  (30.0 s, 2 samples)
    Pipe Throughput                             9937424.1 lps   (10.0 s, 7 samples)
    Pipe-based Context Switching                2360483.6 lps   (10.0 s, 7 samples)
    Process Creation                             108838.5 lps   (30.0 s, 2 samples)
    Shell Scripts (1 concurrent)                  38777.4 lpm   (60.0 s, 2 samples)
    Shell Scripts (8 concurrent)                   5257.0 lpm   (60.0 s, 2 samples)
    System Call Overhead                        9663030.2 lps   (10.0 s, 7 samples)
    Dhrystone 2 using register variables         116700.0  184220115.1  15785.8
    Double-Precision Whetstone                       55.0      29765.8   5412.0
    Execl Throughput                                 43.0      36539.8   8497.6
    File Copy 1024 bufsize 2000 maxblocks          3960.0    1333515.8   3367.5
    File Copy 256 bufsize 500 maxblocks            1655.0     346394.2   2093.0
    File Copy 4096 bufsize 8000 maxblocks          5800.0    3880447.4   6690.4
    Pipe Throughput                               12440.0    9937424.1   7988.3
    Pipe-based Context Switching                   4000.0    2360483.6   5901.2
    Process Creation                                126.0     108838.5   8638.0
    Shell Scripts (1 concurrent)                     42.4      38777.4   9145.6
    Shell Scripts (8 concurrent)                      6.0       5257.0   8761.6
    System Call Overhead                          15000.0    9663030.2   6442.0
    System Benchmarks Index Score                                        6628.6
    55,906
    12,281
    9:38 PM
    55,906
    12,281
    9:38 PM
    heads up on latest Versaweb deal at WHT Versaweb 10 Year Anniversary! Xeon E3-1230v3 + 32G + 240G SSD $66! DDoS Protection! - Dedicated Hosting Offers - Web Hosting Talk
  11. rdan
    1,412
    7:38 PM
    I wish I could have this :(
    55,906
    12,281
    9:38 PM
  13. rdan
    1,412
    7:38 PM
    Haha, most of his good deals are sold out.
    I'll bookmark this started threads and keeps on visiting every hour :D
    55,906
    12,281
    9:38 PM
    @RoldanLT heads up https://www.webhostingtalk.com/showthread.php?t=1418219
  15. rdan
    1,412
    7:38 PM
    Yeah that server is there since last month.
    Same promo :)
    If only a 32GB RAM and 240 SSD is free upgrade for 6 months plan I will purchase it :)
    55,906
    12,281
    9:38 PM
    haha been spoilt by OVH/SoYouStart I guess heh - reality is pretty hard to get cheaper than OVH/SoYouStart :)
  17. rdan
    1,412
    7:38 PM
    Yeah my current plan on SYS is a lot cheaper than most of them.
    32GB ram, 320 SSD with only $56 USD per month :)
    9K passmark: PassMark CPU Lookup
    We have a long conversation also via email of SYS support about my trace-route to their server and also MTR.
    And they have positive suggestions.
    But it will take months to implement it maybe because they will be asking our ISP directly here heheh
    From the current ping ms of 290, they can lower it to 260ms :)
    55,906
    12,281
    9:38 PM
    well I get 344ms pings from Australia to my SoYouStart server so you got it good heh
  19. rdan
    1,412
    7:38 PM
    Sorry and am I off topic here? hehe
    The current route is Philippines > Hongkong > Tokoyo > US West Coast then Canada = 290ms
    What they suggested is and will try to ask our ISP is re-route us to Singapore > Italy > UK > then Canada = 260ms.
    55,906
    12,281
    9:38 PM
    Or just go VersaWeb - Australia to my VersaWeb server is 150-180ms :D
