Versaweb Dedicated Servers (Las Vegas)
Discussion in 'Dedicated server hosting' started by eva2000, Aug 5, 2014.
    55,941
    10:39 AM
    On my test dedicated server at Versaweb, I reloaded the OS and installed Centmin Mod 1.2.3-eva2000.07 stable (special Intel optimised branch for Nginx and PHP-FPM) = centminmod/centminmod at 123.07stable_intel · GitHub
    • Intel Xeon E3-1240v3 Haswell
    • 32GB Memory
    • 250GB Samsung 840 EVO SSD
    • 200Mbps dedicated line ~60TB bandwidth
    • CentOS 6.5 64bit
    Total Centmin Mod Install Time: 408.683358849 seconds
    free -m
                 total       used       free     shared    buffers     cached
    Mem:         32044       1727      30316          0          2       1353
    -/+ buffers/cache:        371      31672
    Swap:        16087          0      16087
    processor       : 0
    vendor_id       : GenuineIntel
    cpu family      : 6
    model           : 60
    model name      : Intel(R) Xeon(R) CPU E3-1240 v3 @ 3.40GHz
    stepping        : 3
    cpu MHz         : 3392.450
    cache size      : 8192 KB
    physical id     : 0
    siblings        : 8
    core id         : 0
    cpu cores       : 4
    apicid          : 0
    initial apicid  : 0
    fpu             : yes
    fpu_exception   : yes
    cpuid level     : 13
    wp              : yes
    flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm ida arat epb xsaveopt pln pts dts tpr_shadow vnmi flexpriority ept vpid fsgsbase bmi1 hle avx2 smep bmi2 erms invpcid rtm
    bogomips        : 6784.90
    clflush size    : 64
    cache_alignment : 64
    address sizes   : 39 bits physical, 48 bits virtual
    power management:
    processor       : 1
    cpu family      : 6
    model           : 60
    stepping        : 3
    cpu MHz         : 3392.450
    physical id     : 0
    siblings        : 8
    core id         : 1
    cpu cores       : 4
    apicid          : 2
    initial apicid  : 2
    fpu             : yes
    fpu_exception   : yes
    cpuid level     : 13
    wp              : yes
    bogomips        : 6784.90
    clflush size    : 64
    power management:
    processor       : 2
    cpu family      : 6
    model           : 60
    stepping        : 3
    cpu MHz         : 3392.450
    physical id     : 0
    siblings        : 8
    core id         : 2
    cpu cores       : 4
    apicid          : 4
    initial apicid  : 4
    fpu             : yes
    fpu_exception   : yes
    cpuid level     : 13
    wp              : yes
    bogomips        : 6784.90
    clflush size    : 64
    power management:
    processor       : 3
    cpu family      : 6
    model           : 60
    stepping        : 3
    cpu MHz         : 3392.450
    physical id     : 0
    siblings        : 8
    core id         : 3
    cpu cores       : 4
    apicid          : 6
    initial apicid  : 6
    fpu             : yes
    fpu_exception   : yes
    cpuid level     : 13
    wp              : yes
    bogomips        : 6784.90
    clflush size    : 64
    power management:
    processor       : 4
    cpu family      : 6
    model           : 60
    stepping        : 3
    cpu MHz         : 3392.450
    physical id     : 0
    siblings        : 8
    core id         : 0
    cpu cores       : 4
    apicid          : 1
    initial apicid  : 1
    fpu             : yes
    fpu_exception   : yes
    cpuid level     : 13
    wp              : yes
    bogomips        : 6784.90
    clflush size    : 64
    power management:
    processor       : 5
    cpu family      : 6
    model           : 60
    stepping        : 3
    cpu MHz         : 3392.450
    physical id     : 0
    siblings        : 8
    core id         : 1
    cpu cores       : 4
    apicid          : 3
    initial apicid  : 3
    fpu             : yes
    fpu_exception   : yes
    cpuid level     : 13
    wp              : yes
    bogomips        : 6784.90
    clflush size    : 64
    power management:
    processor       : 6
    cpu family      : 6
    model           : 60
    stepping        : 3
    cpu MHz         : 3392.450
    physical id     : 0
    siblings        : 8
    core id         : 2
    cpu cores       : 4
    apicid          : 5
    initial apicid  : 5
    fpu             : yes
    fpu_exception   : yes
    cpuid level     : 13
    wp              : yes
    bogomips        : 6784.90
    clflush size    : 64
    power management:
    processor       : 7
    cpu family      : 6
    model           : 60
    stepping        : 3
    cpu MHz         : 3392.450
    physical id     : 0
    siblings        : 8
    core id         : 3
    cpu cores       : 4
    apicid          : 7
    initial apicid  : 7
    fpu             : yes
    fpu_exception   : yes
    cpuid level     : 13
    wp              : yes
    bogomips        : 6784.90
    clflush size    : 64
    power management:
    * Post-Install Check List....
    Check ccache Version:
    ccache version 3.1.6
    Copyright (C) 2009-2011 Joel Rosdahl
    version.
    Check Nginx Version:
    nginx version: nginx/1.7.2
    TLS SNI support enabled
    configure arguments: --with-cc-opt='-I/svr-setup/staticlibssl/include -I/usr/include' --with-ld-opt='-L/svr-setup/staticlibssl/lib -Wl,-rpath -lssl -lcrypto -ldl -lz' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_ssl_module --with-http_gzip_static_module --with-http_stub_status_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module --with-http_secure_link_module --with-http_flv_module --with-http_realip_module --with-openssl-opt=enable-tlsext --add-module=../ngx-fancyindex-ngx-fancyindex --add-module=../ngx_cache_purge-2.1 --add-module=../headers-more-nginx-module-0.25 --add-module=../nginx-accesskey-2.0.3 --add-module=../nginx-http-concat-master --with-openssl=../openssl-1.0.1h --with-libatomic --with-pcre=../pcre-8.35 --with-pcre-jit --with-http_spdy_module --add-module=../ngx_pagespeed-release-1.8.31.4-beta
    Check PHP-FPM Version:
    PHP 5.4.31 (cli) (built: Aug  5 2014 00:03:30)
    MariaDB-common-5.5.38-1.el6.x86_64
    MariaDB-devel-5.5.38-1.el6.x86_64
    MariaDB-compat-5.5.38-1.el6.x86_64
    MariaDB-client-5.5.38-1.el6.x86_64
    MariaDB-shared-5.5.38-1.el6.x86_64
    MariaDB-server-5.5.38-1.el6.x86_64
    memcached 1.4.20
    Check CSF Firewall Version:
    csf: v7.07 (generic)
    SIEGE 3.0.6
    Copyright (C) 2014 by Jeffrey Fulmer, et al.
    FOR A PARTICULAR PURPOSE.
    pscontrol handler
    pscontrol edit
    pscontrol on
    pscontrol off
    pscontrol statson
    pscontrol statsoff
    Check mysqlreport version:
    Check NSD Bind Version:
    NSD version 3.2.17
    Written by NLnet Labs.
    Check YUM Repo List
    Loaded plugins: downloadonly, fastestmirror, priorities
    * base: mirror.san.fastserv.com
    * epel: mirrors.solfo.com
    * extras: centos.tcpdiag.net
    * rpmforge: mirror.webnx.com
    * updates: mirror.supremebytes.com
    1565 packages excluded due to repository priority protections
    repo id        repo name                                             status
    base           CentOS-6 - Base                                       4,859+1,508
    epel           Extra Packages for Enterprise Linux 6 - x86_64        8,451+2,600
    extras         CentOS-6 - Extras                                              14
    mariadb        MariaDB                                                       8+1
    rpmforge       RHEL 6 - RPMforge.net - dag                           3,202+1,516
    updates        CentOS-6 - Updates                                        917+334
    repolist: 17,451
    Stopping NSD service:
    Stopping nsd:
    Disabling NSD service:
    In future to re-enable NSD service type these 2 commands:
    service nsd start
    chkconfig nsd on
  2. rdan
    1,412
    8:39 AM
    That's the most fastest install.
    55,941
    10:39 AM
    Yeah it flew through both the yum download and compile stages - combination of fast hardware and good network connectivity I guess :)
    Just had to upgrade Nginx via centmin.sh menu option 4 as I left .07 version at Nginx 1.7.2.
    Update to Nginx 1.7.3
    tail -1 centminmod_1.2.3-eva2000.07_050814-001821_nginx_upgrade.log
    Total Nginx Upgrade Time: 130.011202385 seconds
    Intel optimised compilation for Nginx and PHP-FPM will increase the time (slow down) it takes to complete and install them so can't really compare it to non-Inte optimised compiles
    Let's see ccache compiler caching feature in Centmin Mod at work recompiling a previously installed Nginx or PHP-FPM version ~34% faster on recompiles via ccache
    tail -1 centminmod_1.2.3-eva2000.07_050814-003439_nginx_upgrade.log
    Total Nginx Upgrade Time: 85.018503460 seconds
  4. rdan
    1,412
    8:39 AM
    How can I apply that Intel Optimization on my server also? :D
  5. rdan
    1,412
    8:39 AM
    55,941
    10:39 AM
    Yeah they post specials on WHT forums so you'd want to keep an eye on bargains and they offer upgrades to DDOS protection too :)
    download the zip for the Github hosted .07 stable intel branch centminmod/centminmod at 123.07stable_intel · GitHub to /usr/local/src and extract the zip and rename extracted folder to match your existing one i.e. centmin-v1.2.3mod. Then apply your own custom settings if you changed centmin.sh.
    Then whenever you upgrade Nginx or PHP-FPM the intel optimised flags are applied.
    ls -lah /usr/local/src
    total 300K
    drwxr-xr-x.  3 root root 4.0K Aug  4 23:27 .
    drwxr-xr-x. 18 root root 4.0K Aug  5 00:18 ..
    -rw-r--r--   1 root root 286K Aug  4 23:26 123.07stable_intel.zip
    drwxr-xr-x  11 root root 4.0K Aug  3 14:07 centmin-v1.2.3mod
  7. rdan
    1,412
    8:39 AM
    Link please :)
    Thanks I will do this when Nginx 1.7.4 comes out ;)
    55,941
    10:39 AM
    edit: doh thought you meant link to the centmin mod .07 intel zip heh
    FYI, all Github branches have links to zip files on the right sidebar ;)
    55,941
    10:39 AM
    For WHT specials by Versaweb they post new specials every few days, so just follow and stalk Rob (Versaweb owner via his threads started link Web Hosting Talk - Search Results :) )
    55,941
    10:39 AM
  11. rdan
    1,412
    8:39 AM
    But with 8GB RAM only :)
    55,941
    10:39 AM
    Yeah still cheap :)
    configuration says upgrade to 16GB = US$15/month extra and 32GB = US$30/month extra
    Moved discussion to own Versaweb thread :D
  13. rdan
    1,412
    8:39 AM
    With this:
    • 32GB Memory
    • CentOS 6.5 64bit
    How much monthly?
    55,941
    10:39 AM
    Was a super special he had posted on WHT last year = US$229/quarter = US$76.33/month :D
  15. rdan
    1,412
    8:39 AM
    55,941
    10:39 AM
  17. rdan
    1,412
    8:39 AM
    The difference is the price, which I pay $63 USD on mine, $70 USD for the first 6 months.
    Location of Versaweb is great for me wooH!
    55,941
    10:39 AM
    Same here for Asia/Oceania region is why I primarily choose LA/Las Vegas or San Jose :)
  19. rdan
    1,412
    8:39 AM
    Yeah, with my current OVH I got 250-300 ms for ping and with Versaweb, I only got 190ms.
    55,941
    10:39 AM
    Yeah I get ~340ms pings to OVH !
