Xenforo vB to XF Rewrite Help
Discussion in 'Forum software usage' started by BoostN, Nov 1, 2014.
  1. BoostN
    BoostN Active Member
    125
    27
    4:32 PM
    1.13.6
    10.0.34
    I'm converting on of my forums from vB (no VBSEO, just vB URLs) to XF within the week.. I'm planning everything now.
    I'm looking for the Nginx rewrites for converting the URLs. I've searched on the XF site but I'm not having much luck (or confidence) for that matter.
  2. rdan
    1,354
    5:32 AM
    49,890
    11,489
    7:32 AM
  4. BoostN
    125
    27
    4:32 PM
    1.13.6
    10.0.34
    49,890
    11,489
    7:32 AM
    really depends on how you setup vb default non-vbseo urls
    @BamaStangGuy probably has more experience with vB to XF conversions
  6. BoostN
    125
    27
    4:32 PM
    1.13.6
    10.0.34
    Current (OLD) URL:
    http://www.thetruckstop.us/forum/showthread.php?36935-2003-lb7-injector-replacement
    XF will have friend urls enabled.. and be in the same /forum/ structure.
    49,890
    11,489
    7:32 AM
  8. BoostN
    125
    27
    4:32 PM
    1.13.6
    10.0.34
    Anyone know the best way to handle the vBulletin forum.php URL? It comes up as a 404 in Nginx, any pointers for a rewrite to fix that?
    49,890
    11,489
    7:32 AM
    just do a normal nginx rewrite from A to B where A = forum.php and B = / or /forum if it's a subdirectory
  10. BoostN
    125
    27
    4:32 PM
    1.13.6
    10.0.34
    Current config:
    location /{
    rewrite ^/(.*) http://www.$server_name/forum/ permanent;
    location /forum/ {
    try_files $uri $uri/ /forum/index.php?$uri&$args;
    location /forum/internal_data/ {
    internal;
    allow 127.0.0.1;
    deny all;
    location /forum/library/ {
    internal;
    allow 127.0.0.1;
    deny all;
    location ~ \.php$ {
    try_files $uri =404;
    fastcgi_pass 127.0.0.1:9000;
    include fastcgi_params;
    I tried adding:
    rewrite /(forum.php)$ /forum/index.php last;
    to my forum block but no luck..
    49,890
    11,489
    7:32 AM
    it's probably because you your catchall redirect all in / to redirect to /forum/ causing problems?
    location /{
    that should catch /forum.php I believe already?
    usually without the catchall redirect you have, would be something like
    note: placed outside of any existing location block
    rewrite ^/forum.php$ /forum/index.php permanent;
    or just create a new forum.php with a php location header redirect to /forum
    You're on your own for the rest unless other members would like to chime in :)
  12. BoostN
    125
    27
    4:32 PM
    1.13.6
    10.0.34
    I just created a new forum.php file and redirected that way with success! Thanks!
  13. jeffwidman
    jeffwidman Active Member
    152
    27
    2:32 PM
    @BoostN did you ever get this figured out?
    I'm looking for the same thing... VB 4.2 basic urls --> XF urls. Content ID's stayed the same, so just need to rewrite the URL format.
    I don't want the overhead that the addon requires of hitting PHP on redirects, much rather just handle it with Nginx rewrite rules.
    I'm comfortable with regex's and Nginx rewrites/location blocks, but looking for some example rewrite regex's to get me started and save time.
    cc @eva2000 @BamaStangGuy as I think you've both also migrated VB 4 forums over to XF...
