Varnish setup help
Discussion in 'Other Centmin Mod Installed software' started by DenSouLew, Oct 18, 2015.
    5:54 AM
    output for
    netstat -tulpn | grep :80
    netstat -tulpn | grep :443
  2. ahmed
    ahmed Active Member
    404
    49
    9:54 PM
    [16:08][root@instance-2 conf]# netstat -tulpn | grep :80
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      21086/varnishd
    tcp6       0      0 :::80                   :::*                    LISTEN      21086/varnishd
    Nothing on 443 as Nginx is not started
    5:54 AM
    try manually killing nginx process in case any left behind and then do nginx restart
  4. ahmed
    ahmed Active Member
    404
    49
    9:54 PM
    I even rebooted the whole VPS, no good
    -I also opened 8080 port in CSF and google firewall
    - Looks like there is something in the setup
    it shall be Nginx 443 on front and varnish is behind on port 80
  5. ahmed
    ahmed Active Member
    404
    49
    9:54 PM
    I changed the varnish port from 80 to 81 and the proxy url in nginx vhost to 81 too
    however curl gives this:
    HTTP/1.1 200 OK
    Date: Wed, 03 May 2017 16:43:01 GMT
    Content-Length: 3801
    Last-Modified: Sun, 19 Mar 2017 21:10:27 GMT
    Connection: keep-alive
    Vary: Accept-Encoding
    ETag: "58cef3c3-ed9"
    Server: nginx centminmod
    X-Powered-By: centminmod
    Expires: Thu, 04 May 2017 16:43:01 GMT
    Cache-Control: max-age=86400
    Cache-Control: public, must-revalidate, proxy-revalidate
    Accept-Ranges: bytes
  6. ahmed
    ahmed Active Member
    404
    49
    9:54 PM
    now I have these ports mapped:
    tcp        0      0 0.0.0.0:81              0.0.0.0:*               LISTEN      699/varnishd
    tcp6       0      0 :::81                   :::*                    LISTEN      699/varnishd
    [16:56][root@instance-2 ahmedalshaarawy]# netstat -tulpn | grep :443
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1331/nginx: master
    [16:56][root@instance-2 ahmedalshaarawy]# netstat -tulpn | grep :8080
    tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1331/nginx: master
  7. ahmed
    ahmed Active Member
    404
    49
    9:54 PM
    I think I need to make the curl to https url only, will try
  8. ahmed
    ahmed Active Member
    404
    49
    9:54 PM
    I receive
    403 Forbidden
    LOOKS LIKE IT IS TOO COMPLICATED :(
    UPDATE:
    I think the problem is in varnish
    curl: (7) Failed connect to 1.1.1.1.1:81; Connection timed out
    5:54 AM
    did you whitelists port 81 in TCP_IN and TCP6_IN for /etc/csf/csf.conf and restart csf firewall
  10. ahmed
    ahmed Active Member
    404
    49
    9:54 PM
    yes I did that, and now on chrom I got:
    ERR_TOO_MANY_REDIRECTS
    And this curl:
    [17:40][root@instance-2 ahmed]# curl -I my-ip-address:443
    HTTP/1.1 400 Bad Request
    Date: Wed, 03 May 2017 17:41:40 GMT
    Content-Length: 264
    Connection: close
    [17:41][root@instance-2 ahmed]# curl -I my-ip-address:81
    HTTP/1.1 200 OK
    Date: Wed, 03 May 2017 17:41:47 GMT
    ETag: W/"58cef3c3-ed9"
    Expires: Thu, 04 May 2017 17:41:47 GMT
    Cache-Control: max-age=86400, public, must-revalidate, proxy-revalidate
    X-Cache: MISS
    X-Cache-Hits: 0
    [17:41][root@instance-2 ahmed]# curl -I my-ip-address:8080
    HTTP/1.1 403 Forbidden
    Date: Wed, 03 May 2017 17:41:52 GMT
    Content-Length: 162
    HTTP/1.1 200 OK
    Date: Wed, 03 May 2017 17:42:02 GMT
    Expires: Thu, 04 May 2017 17:42:02 GMT
  11. ahmed
    ahmed Active Member
    404
    49
    9:54 PM
    looks like Im close, now Im started to see 503 errors with varnish signature
    Error 503 Backend fetch failed
    Guru Meditation:
    XID: 32774
    Varnish cache server
  12. ahmed
    ahmed Active Member
    404
    49
    9:54 PM
    I guess I need to solve this and I'm all set:
    [17:53][root@instance-2 ahmedalshaarawy]# curl -I my-ip:8080
    Date: Wed, 03 May 2017 17:53:51 GMT
    Content-Length: 162
  13. ahmed
    ahmed Active Member
    404
    49
    9:54 PM
    this is the server block for the port 8080
       listen 8080;
       index index.php;
       port_in_redirect off;
       location ~ \.php$ {
           try_files $uri =404;
  14. ahmed
    ahmed Active Member
    404
    49
    9:54 PM
    Looks like the problem now is within varnish VCL etc...
    I got this debug repor:
    Debug: Child cleanup complete
    Debug: Child (2217) Started
    Info: Child (2217) said Child starts
    Error: Child (2217) died signal=6
    Error: Child (2217) Panic at: Wed, 03 May 2017 18:54:33 GMT
    Assert error in vca_acct(), cache/cache_acceptor.c line 539:
      Condition((listen(ls->sock, cache_param->listen_depth)) == 0) not true.
    version = varnish-5.1.1 revision de38712, vrt api = 6.0
    ident = Linux,3.10.0-514.10.2.el7.x86_64,x86_64,-junix,-smalloc,-smalloc,-hcritbit,epoll
    now = 872.763238 (mono), 1493837673.824164 (real)
    Backtrace:
      0x439397: varnishd() [0x439397]
      0x415e55: varnishd() [0x415e55]
      0x7f36b5aebdc5: /lib64/libpthread.so.0(+0x7dc5) [0x7f36b5aebdc5]
      0x7f36b581a73d: /lib64/libc.so.6(clone+0x6d) [0x7f36b581a73d]
    errno = 98 (Address already in use)
    thread = (cache-acceptor)
    thr.req = (nil) {
    thr.busyobj = (nil) {
  15. ahmed
    ahmed Active Member
    404
    49
    9:54 PM
    --- Finally some progress
    However the nginx 403 is the issue:
    Connecting to DOMAIN.COM|1.1.1.1.1.|:443... connected.
    HTTP request sent, awaiting response...
      Date: Wed, 03 May 2017 19:32:02 GMT
      Content-Length: 162
      X-Varnish: 32779 3
      Via: 1.1 varnish (Varnish/5.1)
      X-Cache: HIT
    2017-05-03 19:32:02 ERROR 403: Forbidden.
  16. ahmed
    ahmed Active Member
    404
    49
    9:54 PM
    and the debug of varnishd -F -f /etc/varnish/default.vcl shows:
    Error: Could not get socket :80: Address already in use
    (-? gives usage)
    although I dont point it at all into varnish
    looks like this is the main issue the port 80 thing !!!!
    uPDATE:
    still have the 403 error, although the port 80 now is used by varnish
  17. ahmed
    ahmed Active Member
    404
    49
    9:54 PM
    this is nginx error logs:
    2017/05/03 19:40:25 [error] 1786#1786: *339 recv() failed (104: Connection reset by peer) while reading response header from upstream, client: 0000000, server: domain.com, requ$
    2017/05/03 19:45:24 [error] 3069#3069: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 0000000, server: domain.com, request: "GET / HTTP/1.1"$
