utf8mb4_general_ci VS utf8_general_ci
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by pamamolf, Jun 9, 2014.
    4,101
    428
    5:47 AM
    Nginx-1.26.x
    Hi
    Why i can see as default on phpmyadmin centminmod addon the utf8mb4_general_ci?
    Is it better or faster than utf8_general_ci ?
    I know i can change it but i am curious :)
    Or is it better to use even utf8_unicode_ci ?
    What is the default and better that the most forums/blogs uses?
    55,803
    12,272
    12:47 PM
    @pamamolf where are you seeing that ? Read on my blog http://vbtechsupport.com/1375/ to be clear of the differences between phpmyadmin default session character set and collation versus your database defaults. They are 2 different things. It could phpmyadmin default session collation is set different for some specific support ?
    http://dev.mysql.com/doc/refman/5.5/en/charset-unicode-sets.html
    so it looks for better and wider compatibility phpmyadmin session only defaults to utf8mb4. You need to check what you databases default to as that would be different from phpmyadmin session defaults as per explanation at http://vbtechsupport.com/1375/
