[Solved] /usr/bin/centmin: line 2: centmin.sh: command not found (when disabing selinux)
Discussion in 'Bug Reports' started by arlon, Feb 23, 2016.
  1. arlon
    arlon Member
    95
    6
    1:34 AM
    1.13.6
    10.1
    Hi, a few hours ago i just installed new CMM on fresh vps server, installation ran well and didn't get any error
    and when i disabled my selinux i get this error:
    checking /etc/selinux/config
    SELinux already disabled
    SELINUX=disabled
    [root@apel ~]# centmin
    /usr/local/src/centminmod ~
    it forced me EXIT from CMM menu, i'm not sure its bug ir not
    55,158
    12,249
    4:34 AM
    Thanks for the report. How did you exactly invoke and run centmin.sh ? Commands you used to disable selinux ? via centmin.sh menu option 14 ? that should be removed as usually selinux is already disabled
    • Server or VPS details ? XEN, KVM, OpenVZ, VMWare or dedicated server ? OS ? CentOS 6.7 or 7.1 ? 32bit or 64bit ?
    • What version of Centmin Mod ? .07 stable or .08 beta03 or .08 stable or .09 beta01 ?
    1. Upgrading the actual Centmin Mod code outlined at Upgrade Centmin Mod - CentminMod.com LEMP Nginx web stack for CentOS This is heart of Centmin Mod where the code is the engine that runs centmin.sh shell based menu and all the automation you're accustomed to.
    2. Upgrade software that Centmin Mod installed or manages. For this part following outline at Upgrade - How to upgrade Centmin Mod | Centmin Mod Community
    55,158
    12,249
    4:34 AM
    @arlon fixed it in commit to centmin mod 123.09beta01 branch update centmin.sh · centminmod/centminmod@db5703b · GitHub :)
    thanks :D
    ./centmin.sh
    Centmin Mod 1.2.3-eva2000.09 - http://centminmod.com
                       Centmin Mod Menu
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    11). MariaDB 5.2/5.5 & 10.x Upgrade Sub-Menu
    14). SELinux disable
    16). Change SSHD Port Number
    20). NSD Re-install
    24). Exit
    Enter option [ 1 - 24 ] 14
  4. arlon
    arlon Member
    95
    6
    1:34 AM
    1.13.6
    10.1
    my server details:
    Vultr vps 756MB, 1 core, centos 6.7 64bit (latest update)
    Centmin Mod 1.2.3-eva2000.08 on FRESH server instalation, i installed just 5 hours ago..
    i ran CMM menu using shortcut "centmin" then selected 14 option on menu,, this is the report
    SELINUX=disabled
    then i tried again (centmin shortcut -> option 14) i didn't get error but it always forces me exit from CMM menu option
  5. arlon
    arlon Member
    95
    6
    1:34 AM
    1.13.6
    10.1
