Wordpress Using WP Rocket plugin
Discussion in 'Blogs & CMS usage' started by Matt Williams, Sep 29, 2015.
  1. JarylW
    JarylW Active Member
    216
    41
    Singapore
    8:16 PM
    I think it is very dependent on the setup, especially the wordpress theme you are using. I'm not sure if object cache does anything to the frontend, since I understand it caches the transient options. Also, I'm not sure if client would be happy with having to wipe object cache everytime an option is changed in admin panel.
    I think most popular apart from Autoptimize would be BWP or W3 Total Cache, but w3 is a caching plugin by itself already.
    Cachify (supports Memcached page caching like WP-FFPC) seems interesting but I haven't had the chance to try it.
  2. redbird
    redbird Member
    109
    15
    Web
    10:16 PM
    Can someone provide or point me to step by step instructions on setting up wp-rocket plugin along with redis nginx level + redis object caching in wp on centminmod?
    Or I don't need the third part with wp-rocket? not really clear here.
    Also how does this work in the mix: GitHub - maximejobin/rocket-nginx: Nginx configuration for WP-Rocket
    are any of these overlap? Not very experienced in caching business ))
    Some pointers would be simply awesome. And a lot of people will probably find that pair effective.
    Thank you.
    60,172
    12,595
    10:16 PM
    if you're using full nginx level redis caching, you don't need wp-rocket :)
  4. redbird
    redbird Member
    109
    15
    Web
    10:16 PM
    What if I through keycdn into the mix? How does that work? do I need their wp cacher plugin? or just rewrite rules in nginx conf?
    60,172
    12,595
    10:16 PM
  6. redbird
    redbird Member
    109
    15
    Web
    10:16 PM
    @eva2000 if setting up redis cache server on a separate machine does it matter if it's a container of full virtualization? Which one is preferred?
    Thank you.
  7. Lux
    Lux New Member
    Worldwide
    8:16 PM
    I just installed wp rocket, and I too have the same problem.
    I've checked every permissions and still, error 403. Is centmin mod not compatible with it yet?
    60,172
    12,595
    10:16 PM
