Nginx using linode block storage
Discussion in 'Install & Upgrades or Pre-Install Questions' started by moshbit, Jul 23, 2017.
  1. moshbit
    moshbit Member
    51
    9:47 AM
    1.15.0
    MariaDB 10.1.33
    • CentOS Version: 7
    • Nginx Version Installed: 1.11.10
    • PHP Version Installed: 7.0.15
    • Persistent Config: no
    Forgive me if this is a bit of a newbish question, but I'm trying to set up a new centminmod install on a new server using linode. I'd like to take advantage of linode's new block storage. I've got everything set up, but I'm not sure how to use the block storage with centminmod. Do I just edit the vhost for that website to point to the new location? Is there anything I should specifically keep in mind when doing so?
    Thanks!
    38,044
    8,358
    3:47 AM
    Depends on how the block storage works, haven't used Linode's yet. If it's like DigitalOcean's block storage and you can mount the block storage to any directory, then you can be very creative as to how you configure it. i.e. you could mount the block storage as a new /home/nginx mount prior to centmin mod install so all /home/nginx/domain sites are on block storage and have mysql data on local disk in /var/lib/mysql if there is enough room on /var. Or have separate block storage mounts for /home/nginx, /var/lib/mysql and even /svr-setup if you want.
    If you mount them as existing known directories prior to centmin mod install, then you don't have to do anything centmin mod alteration wise.
    Note block storage will be slower than local disk most of the time i.e. o DigitalOcean's block storage was around 40-50% the performance of local disks.
    38,044
    8,358
    3:47 AM
    just did a quick $5 Linode VPS test with 20GB block storage mounted as /home/nginx
    full benchmarks at Linode - Linode Block Storage - Early Access
    Total Curl Installer YUM or DNF Time: 111.7093 seconds
    Total YUM Time: 12.132566469 seconds
    Total YUM or DNF + Source Download Time: 40.5412
    Total Nginx First Time Install Time: 409.5826
    Total PHP First Time Install Time: 719.5636
    Download Zip From Github Time: 3.7432
    Total Time Other eg. source compiles: 391.3836
    Total Centmin Mod Install Time: 1561.0710
    Total Install Time (curl yum + cm install + zip download): 1676.5235 seconds
    df -hT
    /dev/root      ext4       20G  5.3G   13G  29% /
    devtmpfs       devtmpfs  493M  4.0K  493M   1% /dev
    tmpfs          tmpfs     495M     0  495M   0% /dev/shm
    tmpfs          tmpfs     495M  7.7M  488M   2% /run
    tmpfs          tmpfs     495M     0  495M   0% /sys/fs/cgroup
    tmpfs          tmpfs      99M     0   99M   0% /run/user/0
    /dev/sdc       ext4       20G   45M   19G   1% /home/nginx
    /dev/loop0     ext4      976M  2.6M  907M   1% /tmp
    ls -lah /home/nginx/domains/
    total 12K
    drwxr-s--- 3 nginx nginx 4.0K Jul 23 00:09 .
    drwxr-sr-x 4 nginx nginx 4.0K Jul 23 00:09 ..
    drwxr-x--- 6 nginx nginx 4.0K Jul 23 00:09 demodomain.com
  4. moshbit
    moshbit Member
    51
    9:47 AM
    1.15.0
    MariaDB 10.1.33
    hmm yeah those are all good points. i'm only hosting a xenforo forum so i decided to keep everything but the /data and /internal_data folders on the main drive and put those on the block storage. most of that is images that get served via KeyCDN anyways. i figure this way i won't run out of room for storing images anytime soon while keeping the cost of my linode pretty cheap.
    thank you for the advice and benchmarks!
    38,044
    8,358
    3:47 AM
    yeah that would work too
    though haven't checked if linode backup's include block storage ?
    ah from Linode Forum :: Linode Block Storage (beta)
