Using Cloudflare
Discussion in 'Install & Upgrades or Pre-Install Questions' started by cloud9, Mar 8, 2022.
  1. cloud9
    cloud9 Premium Member Premium Member
    435
    118
    England
    4:41 PM
    1.25.3
    10.6.x
    • CentOS Version:CentOS7
    • Nginx Version Installed: 1.21.6
    • PHP Version Installed: 8.0.16
    • MariaDB MySQL Version Installed: 10.3.x
      Post output in CODE tags.
    I have a forum running fine, thinking of using Cloudflare, site has SSL with letsencrypt, is it just a case of swopping DNS - as I see some # Cloudflare settings in Centmin Mod configs (the domain ssl conf file)
    If I enable Cloudflare on DNS - do I need to unease these ? And any Cloudflare settings I should disable or enable ? Its the free Cloudflare plan
    55,234
    12,253
    1:41 AM
    After swapping DNS/nameservers to Cloudflare and adding your domain to Cloudflare Account, if you already have HTTPS/Letsencrypt enabled on Centmin Mod Nginx site, then make sure you set in CF SSL tab dashboard and change from Flexible SSL to Full SSL at minimum.
    Other Cloudflare settings, would entirely depend on your web application used on your domain. Cloudflare when you add a new domain will have email/links to getting started guides. One will ask if you want to redirect non-HTTPS to HTTPS requests or always use HTTPS. If you Nginx vhost config has a non-https to https redirect via a 302, you can only enable one - either Cloudflare side and disable Nginx vhost config 302 redirect via commenting out that 1st server{} context or leave Nginx vhost config 302 redirect and NOT enable Cloudflare side for those settings to redirect non-HTTPS to HTTPS.
  3. cloud9
    435
    118
    England
    4:41 PM
    1.25.3
    10.6.x
    What about these in my .conf.ssl settings
    # cloudflare authenticated origin pull cert
    #  ssl_client_certificate /usr/local/nginx/conf/ssl/cloudflare/mydomain.co.uk/origin.crt;
    #  ssl_verify_client on;
    55,234
    12,253
    1:41 AM
  5. cloud9
    435
    118
    England
    4:41 PM
    1.25.3
    10.6.x
    @eva2000 Thanks, all set up and working fine, added all the csf stuff you mention in all your links as well....
