Using Cloudflare & Ezoic with CentminMod
Discussion in 'Other Web Apps usage' started by BamaStangGuy, Sep 26, 2019.
  1. BamaStangGuy
    BamaStangGuy Active Member
    668
    192
    10:12 AM
    I am trying to setup Ezoic on my site but running into issues.
    The process goes like this: User > CloudFlare> Ezoic > My Server.
    When Ezoic is enabled it pulls up the default CentminMod page instead of my website as seen in the screenshot below.
    Here is their email to me:
    We're still having issues. It looks like your origin/host could be blocking us, can you reach out to them and have them whitelist our IPs?
    When we run your site through our servers we still get this:
    The process goes: user > cloudflare > ezoic > origin (request now coming from ezoic ip's) > gives us this page instead of the site
    We think this could be if your host/origin is only allowing Cloudflare connections to come from Cloudflare so when it gets our IP we see the above image.
    Best,
    Alexis
    I am not blocking all requests other than CloudFlare on this server so I do not believe that is it. Is there some other issue that I should be looking into?
    55,168
    12,249
    1:12 AM
    See Using the X-Forwarded-For (XFF) Header which shows you how to add X-Forwarded-For header to PHP code. But you can do it on server level just have to remove existing Cloudflare real IP configuration outlined at Nginx Cloudflare & Incapsula (reverse proxy HttpRealIpModule) - CentminMod.com LEMP Nginx web stack for CentOS as you're immediate reverse proxy in front of your Centmin Mod Nginx server is no longer Cloudflare but Ezoic which seems to be on AWS Cloud servers running with Varnish Cache. See Module ngx_http_realip_module
    and Origin Errors and Other Error Messages
  3. BamaStangGuy
    668
    192
    10:12 AM
    I can do that and will once we get it working but I can't see how that is the issue. The IP Address of the user should not have anything to do with what virtual host Nginx sees should it? Right now, when Ezoic is becoming between Cloudflare and my server, Nginx is serving up the default virtual host at /usr/local/nginx/html/
  4. BamaStangGuy
    668
    192
    10:12 AM
    I have also already added the Ezoic IP addresses to the csf allow list.
  5. BamaStangGuy
    668
    192
    10:12 AM
    I have setup X-Forwarded-For and disabled CloudFlare to see if this helps.
    55,168
    12,249
    1:12 AM
    what is set in main hostname's /usr/local/nginx/conf/conf.d/virtual.conf Nginx vhost for server_name ? it should be different from your site's nginx vhost server_name.
    Also what is Ezoic using for Varnish Cache's backend reference to your site, an IP address or the hostname = your domain name ? As Centmin Mod's IP address access goes to main hostname's nginx i.e. /usr/local/nginx/html while hostname = your domain name backend would go to your site.
  7. BamaStangGuy
    668
    192
    10:12 AM
    lixxx-xxx.members.linode.com is the server_name. Will ask second question to them.
  8. BamaStangGuy
    668
    192
    10:12 AM
    Still have been unable to find a solution. User > CloudFlare > Server brings up the correct virtual host. User > CloudFlare > Ezoic > Server brings up /usr/local/nginx/html/
  9. Solidus
    Solidus New Member
    7
    4:12 PM
    1.9
    10.1
    Are you integrating via CloudFlare or the WordPress plugin?
  10. BamaStangGuy
    668
    192
    10:12 AM
    Was CloudFlare but we never got it to work. The Wordpress plugin works though so we are using that now.
    55,168
    12,249
    1:12 AM
    did you get an answer ?
  12. BamaStangGuy
    668
    192
    10:12 AM
    I asked but they never replied to that specific question.
