Amazon AWS Cloudflare Use Route53 for geoDNS and Cloudflare for CDN
Discussion in 'Domains, DNS, Email & SSL Certificates' started by adamus007p, Mar 18, 2020.
  1. adamus007p
    adamus007p Member
    380
    20
    5:28 PM
    I am sorry I mean Cloudflare not Cloudfront which is from Amazon. I will correct my post above.
    60,460
    12,614
    2:28 AM
    Try changing Cloudflare to Full SSL non-strict mode and re-enable orange cloud proxy
  3. adamus007p
    adamus007p Member
    380
    20
    5:28 PM
    I am trying to open cdn (some jpg) in browser.
    https://cdn.domain.com/img/abcd.jpg
    This site can’t be reached
    cdn.domain.com unexpectedly closed the connection.
    when I change to http://cdn.domain.com/img/abcd.jpg
    there is error
    Please enable cookies.
    Error 1001 Ray ID: 57xxxxx3cd447 • 2020-03-23
    DNS resolution error
    What happened?
    You've requested a page on a website (cdn.domain.com) that is on the Cloudflare network. Cloudflare is currently unable to resolve your requested domain (cdn.domain.com). There are two potential causes of this:
    Most likely: if the owner just signed up for Cloudflare it can take a few minutes for the website's information to be distributed to our global network.
    Less likely: something is wrong with this site's configuration. Usually this happens when accounts have been signed up with a partner organization (e.g., a hosting provider) and the provider's DNS fails.
  4. adamus007p
    adamus007p Member
    380
    20
    5:28 PM
    OK i have found info:
    Troubleshooting Cloudflare 1XXX errors
    A non-Cloudflare domain cannot CNAME to a Cloudflare domain unless the non-Cloudflare domain is added to a Cloudflare account.
    60,460
    12,614
    2:28 AM
    Ah that explains why I could do it. So guess not an option for you as DNS you need AWS Route53
  6. adamus007p
    adamus007p Member
    380
    20
    5:28 PM
    could or could not do it?
    60,460
    12,614
    2:28 AM
    I could do it because both domains are on CF just one is with grey cloud DNS only
  8. adamus007p
    adamus007p Member
    380
    20
    5:28 PM
    OK I understand. I did not found my solution so i test my webiste and DNS.
    I need to read more about other thing which you wrote.
    There is other thind that you can use a solution like he wrote.
    CNAME from CloudflareDomain to nonCloudflareDomain.
    Moreover info from here is against the CF policy. I mean this solution.
    https://stackoverflow.com/questions...-based-routing-in-conjunction-with-cloudflare
    Self-Serve Subscription Agreement | Cloudflare
    DNS only should be ok, but serving with other domain only images seems not.
    @eva2000 you wrote that you can use header for subdomains.
    add_header Link "<http://domain.com$request_uri>; rel=\"canonical\"";
    http only or is should be https?
  9. adamus007p
    adamus007p Member
    380
    20
    5:28 PM
    Have you make a research about it?
    60,460
    12,614
    2:28 AM
    should use whatever you intend for your site to be used with - which usually is https these days
