Sysadmin Uptimerobot issues
Discussion in 'System Administration' started by denellum, Jan 29, 2017.
  1. denellum
    denellum Member
    88
    22
    Dallas
    8:48 PM
    1.13.8
    10.1.29
    The news isnt good :/
    I have checked with :
    [root@WEB01 ~]# csf -g  69.162.124.229
    Chain            num   pkts bytes target     prot opt in     out
    source               destination
    No matches found for 69.162.124.229 in iptables
    IPSET: No matches found for 69.162.124.229
    And i've verified the IP is the NON-DDOS IP.
    Any ideas?
  2. denellum
    denellum Member
    88
    22
    Dallas
    8:48 PM
    1.13.8
    10.1.29
    IF i disable CSF it works :/
    44,731
    10,196
    11:48 AM
    Weird then.
    Centmin Mod CSF Firewall rate limits pings so probably could be related to that ?
    in /etc/csf/csf.conf config file
    # Allow incoming PING
    ICMP_IN = "1"
    # Set the per IP address incoming ICMP packet rate
    # To disable rate limiting set to "0"
    ICMP_IN_RATE = "1/s"
    # Allow outgoing PING
    ICMP_OUT = "1"
    # Set the per IP address outgoing ICMP packet rate (hits per second allowed),
    # e.g. "1/s"
    ICMP_OUT_RATE = "0"
    Maybe if raise the ICMP_IN_RATE from 1/s to 5/s ?
  4. denellum
    denellum Member
    88
    22
    Dallas
    8:48 PM
    1.13.8
    10.1.29
    to reload it i just use :
    csf -r
    Correct? If so, that did not resolve the issue :/
    44,731
    10,196
    11:48 AM
    yeah that will restart csf.
    what if you totally disable ping rate limit by setting ICMP_IN = "1" to ICMP_IN = "0"
  6. denellum
    denellum Member
    88
    22
    Dallas
    8:48 PM
    1.13.8
    10.1.29
    Sadly still down :(
  7. SFLC
    SFLC Active Member
    224
    59
    The Canadas
    3:48 AM
    csf is strange, when I make changes csf -r won't do anything, try csf -x then csf -e
    when i disabled access to port 3306 from csf a few months ago, no matter what it would remain open until I restarted the whole server, then it started applying the rule, don't know if that's a csf thing or an iptables issue
  8. denellum
    denellum Member
    88
    22
    Dallas
    8:48 PM
    1.13.8
    10.1.29
    hmm, yeah when i take it down UptimeRobot works haha. THen when i re-enable it, goes back down.
  9. denellum
    denellum Member
    88
    22
    Dallas
    8:48 PM
    1.13.8
    10.1.29
    ALRIGHT! IT IS RESOLVED!
    I didn't read the full command (my fault)
    curl -s https://uptimerobot.com/inc/files/ips/IPv4andIPv6.txt | while read i; do echo "csf -a ${i}"; done
    The end of it... the echo, i needed it to RUN the command.
    curl -s https://uptimerobot.com/inc/files/ips/IPv4andIPv6.txt | while read i; do csf -a ${i}; done
    Boom, I watched it saved the rules, and now I'm golden.
    44,731
    10,196
    11:48 AM
    strange should work with csf -r only.
    ah ha.. whitelisted now.. yes the outputted commands need to be run :)
  11. denellum
    denellum Member
    88
    22
    Dallas
    8:48 PM
    1.13.8
    10.1.29
    :) Sorry for all the spam, gave you all some rep love for the help!
    Thanks again all!
    44,731
    10,196
    11:48 AM
  13. SFLC
    SFLC Active Member
    224
    59
    The Canadas
    3:48 AM
    nice, so csf was doing exactly what it was supposed to do. In my opinion, I'd rather security be too much that it starts to interfere with me, versus lax security that could affect me, if you know what I mean.
  14. denellum
    denellum Member
    88
    22
    Dallas
    8:48 PM
    1.13.8
    10.1.29
    100% agree brotha :)
    44,731
    10,196
    11:48 AM
    Yup that's why CSF is installed by default. I'm be scared to see what other LAMP/LEMP stacks do without a firewall in place at all !
