PHP-FPM Upgrade issue
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Exurant, Jan 25, 2017.
  1. Exurant
    Exurant New Member
    9:19 AM
    • CentOS Version: i.e. CentOS 6 64
    • Centmin Mod Version Installed: i.e. 123.08stable
    • Nginx Version Installed: 1.11.8
    • PHP Version Installed: 5.5.38.
    • MariaDB MySQL Version Installed: 10.0.29
    trying to update to PHP 5.6.27 this happens all the time please help
    Automatically continuing upgrade in 6 seconds...
    make: *** No rule to make target `clean'. Stop.
    Forcing buildconf
    Removing configure caches
    buildconf: checking installation...
    buildconf: autoconf version 2.63 (ok)
    ../configure --enable-fpm --enable-opcache --enable-intl --enable-pcntl --with-mcrypt --with-snmp --with-mhash --with-zlib --with-gettext --enable-exif --enable-zip --with-bz2 --enable-soap --enable-sockets --enable-sysvmsg --enable-sysvsem --enable-sysvshm --enable-shmop --with-pear --enable-mbstring --with-openssl --with-mysql=mysqlnd --with-libdir=lib64 --with-mysqli=mysqlnd --with-mysql-sock=/var/lib/mysql/mysql.sock --with-curl --with-gd --with-xmlrpc --enable-bcmath --enable-calendar --enable-ftp --enable-gd-native-ttf --with-freetype-dir=/usr --with-jpeg-dir=/usr --with-png-dir=/usr --with-xpm-dir=/usr --with-vpx-dir=/usr --with-t1lib=/usr --enable-pdo --with-pdo-sqlite --with-pdo-mysql=mysqlnd --enable-inline-optimization --with-imap --with-imap-ssl --with-kerberos --with-readline --with-libedit --with-gmp --with-pspell --with-tidy --with-enchant --with-fpm-user=nginx --with-fpm-group=nginx --disable-fileinfo --with-ldap --with-ldap-sasl --with-config-file-scan-dir=/etc/centminmod/php.d --with-xsl
    checking build system type... x86_64-unknown-linux-gnu
    checking host system type... x86_64-unknown-linux-gnu
    checking target system type... x86_64-unknown-linux-gnu
    checking whether the C compiler works... no
    configure: error: in `/svr-setup/php-5.6.27/fpm-build':
    configure: error: C compiler cannot create executables
    See `config.log' for more details
    make: *** No targets specified and no makefile found. Stop.
    real 0m0.002s
    user 0m0.001s
    sys 0m0.000s
    make: *** No rule to make target `install'. Stop.
    real 0m0.002s
    user 0m0.001s
    sys 0m0.000s
    strip PHP binary...
    -rwxr-xr-x 1 root root 9.1M Jan 25 13:31 /usr/local/bin/php
    -rwxr-xr-x 1 root root 9.1M Jan 25 13:31 /usr/local/bin/php-cgi
    -rwxr-xr-x 1 root root 9.1M Jan 25 13:35 /usr/local/bin/php
    -rwxr-xr-x 1 root root 9.1M Jan 25 13:35 /usr/local/bin/php-cgi
    Wed Jan 25 13:35:14 UTC 2017
    Success: PHP configure ok
    service php-fpm restart
    Starting php-fpm done
    make -j2
    real 0m0.002s
    user 0m0.001s
    sys 0m0.001s
    Wed Jan 25 13:35:15 UTC 2017
    Error: 2, PHP make failed (1.2.3-eva2000.08)
    55,209
    12,251
    12:19 PM
    PHP 5.6.30 is the latest https://community.centminmod.com/threads/php-5-6-30-is-available.10102/. Have you tried that yet ?
    • Which version did you upgrade from ?
    Every centmin.sh menu option has a full server log created with time stamped file name at /root/centminlogs. You can check that specific error log for clues or copy and paste log contents and post to pastebin.com or gist.github.com for sharing.
    To troubleshoot, you need to check the the php upgrade logs at /root/centminlogs and instructions under Sharing logs and errors heading for using Pastebin.com or Gists to share a sanitised version of the contents of the nginx_upgrade and php_upgrade logs. You can see full details at How to troubleshoot Centmin Mod initial install issues
    if you type this command it lists all logs in date ascending order so latest log at bottom
    ls -lArt /root/centminlogs
    so copy the entire contents of latest php_upgrade log to gist.github.com or pastebin.com
    you can use grep to filter the logs, i.e. look for nginx_upgrade or php in log name
    ls -lahrt /root/centminlogs/ | egrep 'nginx_upgrade|php_upgrade'
    -rw-r--r--  1 root root  2.6M Oct  3 03:48 centminmod_1.2.3-eva2000.09.001_031016-034409_php_upgrade.log
    -rw-r--r--  1 root root  664K Oct 12 09:24 centminmod_1.2.3-eva2000.09.001_121016-092406_nginx_upgrade.log
    So the last php upgrade log was named centminmod_1.2.3-eva2000.09.001_031016-034409_php_upgrade.log and located at /root/centminlogs/centminmod_1.2.3-eva2000.09.001_031016-034409_php_upgrade.log
    then use cat command to output the contents of that log.
    cat /root/centminlogs/centminmod_1.2.3-eva2000.09.001_031016-034409_php_upgrade.log
    then select and copy and paste output to pastebin.com or gist.github.com file to share. If your SSH client's scroll buffer isn't large enough using cat might not output the entire log file contents, so you may need to download the log and use local text editor to open and copy and paste.
    so only need content of a specific log, in this case most recent php_upgrade.log logs
    1. Upgrading the actual Centmin Mod code outlined at Upgrade Centmin Mod - CentminMod.com LEMP Nginx web stack for CentOS This is heart of Centmin Mod where the code is the engine that runs centmin.sh shell based menu and all the automation you're accustomed to.
    2. Upgrade software that Centmin Mod installed or manages. For this part following outline at Upgrade - How to upgrade Centmin Mod | Centmin Mod Community
