Beta Branch updated workaround for CentOS 7 EOL repo closures in 140.00beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Jul 2, 2024.
    59,369
    12,510
    4:54 AM
    - CentOS 7 is end of life as of June 30, 2024 so no more security or bug fix updates via official YUM repos. For migration options read https://community.centminmod.com/threads/centos-7-end-of-life-eol-june-30-2024.25589/.
    - CentOS folks have been quick to disable their YUM repos as YUM repo's mirror.centos.org etc are now no longer working. This update disables broken YUM repos and switches CentOS 7 mirrorlist.centos.org to archive vault.centos.org to prevent YUM repo errors when you run yum.
    - Existing Centmin Mod users can run cmupdate command and then, run and exit centmin.sh once to apply the workarounds
    140.00beta01 branch
  2. pamamolf
    4,126
    9:54 PM
    59,369
    12,510
    4:54 AM
    What does your /etc/yum.repos.d/kernelcare.repo contents look like ? like below?
    [kernelcare]
    name=kernelcare
    baseurl=https://repo.cloudlinux.com/kernelcare/$releasever/$basearch
    enabled=1
    gpgcheck=1
    gpgkey=https://repo.cloudlinux.com/kernelcare/RPM-GPG-KEY-KernelCare
    Pretty sure unrelated as that is CloudLinux KernelCare YUM repo and not CentOS releated. Can you ping their repo URL? Any packet loss ?
    ping -c4 repo.cloudlinux.com
    curl -I https://repo.cloudlinux.com
    HTTP/1.1 200 OK
    Server: nginx
    Date: Mon, 01 Jul 2024 19:48:09 GMT
    Content-Type: text/html
    Content-Length: 0
    Last-Modified: Mon, 21 Nov 2016 19:01:46 GMT
    Connection: keep-alive
    ETag: "5833449a-0"
    Strict-Transport-Security: max-age=63072000; includeSubdomains
    X-Frame-Options: DENY
    X-XSS-Protection: 1; mode=block
    Accept-Ranges: bytes
  4. pamamolf
    4,126
    9:54 PM
    Maybe a temporary issue :)
    Now it works..
