Beta Branch add NGINX_PRIORITIZECHACHA patch routine support
Discussion in 'Centmin Mod Github Commits' started by eva2000, Sep 26, 2018.
    60,644
    12,635
    9:11 PM
    - Add NGINX_PRIORITIZECHACHA='n' variable support disabled by default unless set in persistent config file /etc/centminmod/custom_config.inc as NGINX_PRIORITIZECHACHA='y' and OpenSSL 1.1.1+ and Nginx 1.15.4+ are detected. Current patch doesn't work but the routine is put in place so that when a working patch is is available Nginx - [nginx-announce] nginx-1.15.4
    123.09beta01 branch
  2. buik
    2,044
    527
    Flanders
    12:11 PM
    This is a release blocker if you ask me.
    Nginx is not going to support the OpenSSL 1.1.1 feature: SSL_OP_PRIORITIZE_CHACHA as it is classified by the Nginx team as hack.
    Also the Nginx patch from carter.li won't work.
    So you have to look further on the OpenSSL area.
    I could rebuild the SSL_OP_PRIORITIZE_CHACHA OpenSSL 1.1 patch.
    But then there must be enough enthusiasm for it.
