Beta Branch update prep for ModSecurity v3.0
Discussion in 'Centmin Mod Github Commits' started by eva2000, Aug 5, 2017.
    60,097
    12,585
    5:49 AM
    unless you know how to configure modsecurity and it's gotchas, I'd avoid it. if using Cloudflare Pro and higher paid plans, you already have CF WAF available anyway.
  2. Rake-GH
    Rake-GH Active Member
    179
    93
    USA
    3:49 PM
    default
    default
    I don't use the paid cloudflare. But I did get modsecurity installed, got it setup and got it to trigger with your test rule. Pretty neat. I'm just gonna play with it in DetectionOnly mode for a couple days.
    I also found they have an exclusion profile for Xenforo too: crs_exclusions_xenforo
    60,097
    12,585
    5:49 AM
    oh didn't know that :cool:
  4. Pasta
    Pasta New Member
    14
    3:49 AM
    MariaDB 10.4
    Is this the correct way to set up logrotate for modsecurity. Does the alias ngxrestart work after postrotate?
    nano /etc/logrotate.d/mod_security
    /var/log/modsec_audit.log {
    daily
    rotate 7
    missingok
    compress
    postrotate
    ngxrestart > /dev/null 2>/dev/null || true
    endscript
    60,097
    12,585
    5:49 AM
    You can check if ngxrestart works for that by manually doing a forced debug logrotate via command
    logrotate -df /var/log/modsec_audit.log
  6. Pasta
    Pasta New Member
    14
    3:49 AM
    MariaDB 10.4
    Thanks, i had to chmod modsec_audit.log to 0644 to make it work.
  7. hazehs
    hazehs Member
    34
    7:49 PM
    NGINX 1.18
    MariaDB 10.4
