Stable Branch update nginx module security pins and fix module builds in 132.00stable
Discussion in 'Centmin Mod Github Commits' started by eva2000, Nov 9, 2026 at 10:14 PM.
    60,340
    12,609
    5:43 PM
    Security pins and build fixes for shipped nginx modules, matching
    141.00beta01.
    Changes:
    - njs 1.0.2 (CVE-2026-101025, CVE-2026-101019), Angie-1.12.4,
    freenginx 1.30.2 (CVE-2026-97629), headers-more 0.41, echo 0.66
    (fixes freenginx builds), ngx_http_redis 0.4.1-cmm
    - ngx_cache_purge 2.5.3 -> 3.0.4 (CVE-2026-108981 and the nginx 1.29.4+
    proxy struct misread), plus the freenginx struct guard
    - nginx_upstream_check_module 0.4.0 pinned to NGINX_UPSTREAMCHECKCOMMIT
    and its nginx core patch now applied (check_1.30.4+.patch for nginx
    1.29.6+, dry-run first, skipped on Angie and freenginx), so health
    checks run
    - ModSecurity from github.com/owasp-modsecurity pinned to v3.0.17 and
    connector v1.0.4, recursive submodules, libmaxminddb version check fix,
    and modsecurity directives only enabled when the module built
    - NGINX_STICKY: deprecation warning, native sticky disabled with the
    matching --without switch, source compat fix for nginx 1.23.0+ and Angie
    - NGINX_TLS_FINGERPRINT: deprecation warning, corrected gate, nginx patch
    dry-run, no forced OpenSSL rebuild with system OpenSSL, libssl.num entry
    - Angie builds: restore --with-stream, --with-stream_ssl_module and
    --with-threads
    - ngx_devel_kit complex value end patch: include Angie 1.12.1+ in its
    gate, fixing worker crashes in set_* directives with variable arguments
    on Angie 1.12.4
    132.00stable branch
