Master Branch add /etc/csf/load.sh script for additional server stats
Discussion in 'Centmin Mod Github Commits' started by eva2000, Apr 19, 2018.
    60,036
    12,571
    6:16 PM
    - When csf firewall's lfd daemon detects & triggers a high cpu load alert (over 15 min interval) defined in /etc/csf/csf.conf config file with related PT_LOAD variables, it usually sends an lfd email alert. CSF Firewall can also be configured via PT_LOAD_ACTION setting to run a custom script i.e. /etc/csf/load.sh when high cpu alert is triggered. This update configures a custom /etc/csf/load.sh script on Centmin Mod 123.09beta01 and newer versions which will call cminfo top and netstat commands outlined at https://community.centminmod.com/threads/update-cminfo-cmd-with-top-related-server-statistics.14597/ and https://community.centminmod.com/threads/update-cminfo-command-with-netstat-flag-option.14468/ and send a 2nd high cpu alert email to the email address defined in LF_ALERT_TO in /etc/csf/csf.conf if the email in LF_ALERT_TO is empty it sends email to root system user's inbox.
    - Also previously the PT_LOAD_LEVEL was hardcoded to value of 8 in /etc/csf/csf.conf, but on this update it will be changed to the value equal to number of cpu threads detected on the server which is a more accurate value to monitor and alert for.
