Wordpress Uninstalling script issue
Discussion in 'Blogs & CMS usage' started by amin, Oct 13, 2015.
  1. amin
    amin Member
    38
    6
    9:11 PM
    Katest
    I tried to remove a test website:
    /root/tools/wp_uninstall_test.com.sh
    /root/tools/wp_uninstall_test.com.sh: line 14: unexpected EOF while looking for matching `"'
    /root/tools/wp_uninstall_test.com.sh: line 18: syntax error: unexpected end of f ile
    55,983
    3:41 AM
    can you post contents of your /root/tools/wp_uninstall_test.com.sh
    55,983
    3:41 AM
    ah found the bug some stray ending quotes " ended up on my rm -rf files
    incorrect
    cat /root/tools/wp_uninstall_newdomain2.com.sh
    #/bin/bash
    rm -rf /usr/local/nginx/conf/conf.d/newdomain2.com.conf
    rm -rf /usr/local/nginx/conf/conf.d/newdomain2.com.ssl.conf
    rm -rf /home/nginx/domains/newdomain2.com
    rm -rf /usr/local/nginx/conf/wpsecure_newdomain2.com.conf
    rm -rf /usr/local/nginx/conf/wpsupercache_newdomain2.com.conf
    rm -rf /root/tools/wp_updater_newdomain2.com.sh
    rm -rf /usr/local/nginx/conf/ssl/newdomain2.com/newdomain2.com.crt"
    rm -rf /usr/local/nginx/conf/ssl/newdomain2.com/newdomain2.com.key"
    rm -rf /usr/local/nginx/conf/ssl/newdomain2.com/newdomain2.com.csr"
    crontab -l > cronjoblist
    sed -i "/wp_updater_newdomain2.com.sh/d" cronjoblist
    sed -i "/\/newdomain2.com\/wp-cron.php/d" cronjoblist
    crontab cronjoblist
    rm -rf cronjoblist
    service nginx restart
    correct is to remove the ending " on these 3 lines
    55,983
    3:41 AM
  5. JarylW
    JarylW Active Member
    216
    41
    Singapore
    1:41 AM
    Noticed this some time ago but it stilled removed the folders correctly so i didnt think too much of it
  6. amin
    amin Member
    38
    6
    9:11 PM
    Katest
    I think it would be good to add the command to remove the uninstallation file too.
    Thank you
