Trying to figure out how to port an Apache SetEnv to NGINX in Centmin
Discussion in 'Other Web Apps usage' started by fly, Mar 8, 2023.
  1. fly
    fly Premium Member Premium Member
    68
    13
    6:18 PM
    I'm (clearly) not so good with some of the configuration changes needed to move from Apache to NGINX. One of them is where to put a SetEnv setting for a site.
    49,869
    11,482
    8:18 AM
    What are you trying to do?
  3. fly
    68
    13
    6:18 PM
    So in Apache, an .htaccess file sets the environment with
    SetEnv CI_ENV development
    According to Google, I *think* I can set that with a fastcgi_param, but haven't tested it.
    49,869
    11,482
    8:18 AM
    Yes you use fastcgi_param if you want PHP-FPM to read the set environmental variable and not Nginx. If you want Nginx to read, use env variable Core functionality
  5. fly
    68
    13
    6:18 PM
    How in the heck did that not come up in my Google search? :dead:
    Hmm, that says I can only put it in main though. I will have multiple environments on the same server. Is the result the same no matter where it's set? If it matters, its obviously running PHP code.
