Troubleshoot system load 90 on Centos 6.6 64bit
Discussion in 'System Administration' started by pamamolf, Jan 15, 2015.
    4,101
    428
    4:28 PM
    Nginx-1.26.x
    Hi
    I am getting a system load of 90 and i have a lot of free ram swap i not used at all and cpu is high about 90% but i am sure that the problem is from a background system command that can't be found using top :(
    Using top all are normal and i have very low numbers as always....
    I am not also under attack for sure as i don't have many connections on the server...
    Is there anyway to check with more details what is causing this system load?
    Maybe an application task is running or maybe a task crash?
    After restarting the server is fine now but just to know for the next time...
    55,802
    12,272
    11:28 PM
    start with my mysqlmymonlite.sh script at mysqlmymonlite.sh Addon | Centmin Mod Community it's basically a lite version of the full version I use for my paid optimisation consults I do with clients :)
    Official site page is at mysqlmymon.com and the web site lists an example output of what type of server info and stats the script gathers.
  3. pamamolf
    4,101
    428
    4:28 PM
    Nginx-1.26.x
    Ok thanks George i will try it tomorrow if i have again the same problem and let's hope that i will be able to view the problem in the output :)
    55,802
    12,272
    11:28 PM
    readme.txt in zip for mysqlmymonlite.sh has instructions for setting cronjob to run script to gather output and save to disk log file or email you every X interval where X can be every 5-15 minutes or every hour. So you do not need to physically present to catch the high load situations.
  5. pamamolf
    4,101
    428
    4:28 PM
    Nginx-1.26.x
    Ok great
