The out of the box cache rules needs to be updated for WordPress running any ecommerce solution
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Saumya Majumder, Aug 18, 2016.
  1. JarylW
    JarylW Active Member
    216
    41
    Singapore
    12:22 AM
    Cache enabler by default already doesn't cache the cart checkout and account pages, even without the rules. Their nginx conf settings
    WordPress Cache Enabler Plugin - KeyCDN Support
        set $cache_uri $request_uri;
        # bypass cache if POST requests or URLs with a query string
        if ($request_method = POST) {
            set $cache_uri 'nullcache';
        if ($query_string != "") {
        # bypass cache if URLs containing the following strings
        if ($request_uri ~* "(/wp-admin/|/xmlrpc.php|/wp-(app|cron|login|register|mail).php|wp-.*.php|/feed/|index.php|wp-comments-popup.php|wp-links-opml.php|wp-locations.php|sitemap(_index)?.xml|[a-z0-9_-]+-sitemap([0-9]+)?.xml)") {
        # bypass cache if the cookies containing the following strings
        if ($http_cookie ~* "comment_author|wordpress_[a-f0-9]+|wp-postpass|wordpress_logged_in") {
        # custom sub directory e.g. /blog
        set $custom_subdir '';
        # default html file
        set $cache_enabler_uri '${custom_subdir}/wp-content/cache/cache-enabler/${http_host}${cache_uri}index.html';
        # webp html file
        if ($http_accept ~* "image/webp") {
            set $cache_enabler_uri '${custom_subdir}/wp-content/cache/cache-enabler/${http_host}${cache_uri}index-webp.html';
            gzip_static on; # this directive is not required but recommended
            try_files $cache_enabler_uri $uri $uri/ $custom_subdir/index.php?$args;
    59,718
    2:22 AM
    i don't see anything in those rules that would exclude checkout/account pages though ? unless it's in the php code itself
  3. JarylW
    216
    41
    Singapore
    12:22 AM
    Yea. The plugin just doesnt create any cache for the woocommerce pages (maybe with exception of /shop/ page)
    59,718
    2:22 AM
    well doesn't hurt to specifically add it to the default cache-enable nginx setup :)
  5. Saumya Majumder
    Saumya Majumder Member
    60
    9:52 PM
    1.9.12
    10.0.24
    Hey @eva2000 I've found another issue with Redis at Nginx level caching. You see when we login to wp admin as a admin, there is an option to enable the header toolbar while viewing your pages.
    Now recently I've seen an wired issue, after I enable that toolbar it shows a blank space at top. instead of showing the toolbar.
    Is there any way to not show cached version of the site when admin is logged in? Not sure if it's possible.
    59,718
    2:22 AM
    that's already the default as it works for me that way and never had any blank pages for header toolbar
  7. Saumya Majumder
    60
    9:52 PM
    1.9.12
    10.0.24
    Yes I found the issue it wasn't redis, it was deregistering dashicons.
    59,718
    2:22 AM
    Good to know :)
