Wordpress The connection was reset
Discussion in 'Blogs & CMS usage' started by Yohan, Oct 4, 2015.
  1. Yohan
    Yohan Member
    68
    11:02 PM
    1.9.x
    MariaDB 10
    Hello , I recently having issue some of my WP post its apering "The connection was reset" hope any one have idea ? :(
    55,983
    3:32 AM
    Where are you seeing that message. I don't think I've see such for WP posts specifically
  3. Yohan
    Yohan Member
    68
    11:02 PM
    1.9.x
    MariaDB 10
    I just send you PM ... there few of post will getting this error ... but main site is working .. even there no error log has any issue .. its not mention anything about that
    55,983
    3:32 AM
    what about your nginx vhost's access log ?
    i get
    No data received
    ERR_EMPTY_RESPONSE
    Unable to load the webpage because the server sent no data.
    did you enable the block.conf include in your vhost centminmod/block.conf at master · centminmod/centminmod · GitHub it has some spam and adult related keyword blocks that might be catching your site as it's adult content related
    although they're 403 permission denied codes so not what you see
        ## Block spam
        set $block_spam 0;
        if ($query_string ~ "\b(ultram|unicauca|valium|viagra|vicodin|xanax|ypxaieo)\b") {
            set $block_spam 1;
        if ($query_string ~ "\b(erections|hoodia|huronriveracres|impotence|levitra|libido)\b") {
            set $block_spam 1;
        if ($query_string ~ "\b(ambien|blue\spill|cialis|cocaine|ejaculation|erectile)\b") {
            set $block_spam 1;
        if ($query_string ~ "\b(lipitor|phentermin|pro[sz]ac|sandyauer|tramadol|troyhamby)\b") {
            set $block_spam 1;
        if ($block_spam = 1) {
            return 403;
  5. Yohan
    Yohan Member
    68
    11:02 PM
    1.9.x
    MariaDB 10
    OK i just removed that line .... error still the same ... YES the your toll error msg from chorme .. im using Firefox .. any idea ?
    55,983
    3:32 AM
    did you restart nginx server and php-fpm after ?
    nprestart
  7. Yohan
    Yohan Member
    68
    11:02 PM
    1.9.x
    MariaDB 10
    YES sure ..
    [root@a169 ~]# nprestart
    Restarting nginx (via systemctl):                          [  OK  ]
    Starting php-fpm  done
    [root@a169 ~]#
    55,983
    3:32 AM
    also check all instances of dropping connections with 444 nginx status code in your nginx vhost files
    find which files have 444 text in them
    grep -Ro 444 /usr/local/nginx/conf | uniq
    example 3 files i have
    /usr/local/nginx/conf/wpsecure_newdomain2.com.conf:444
    /usr/local/nginx/conf/drop.conf:444
    /usr/local/nginx/conf/wpsecure_newdomain.com.conf:444
    check most obvious drop.conf as it's included to all nginx vhosts by default
    grep -n 444 /usr/local/nginx/conf/drop.conf
    7:      location ~* \.(bak|php~|php#|php.save|php.swp|php.swo)$ { return 444; }
    any of those extensions specicially will give 444 status code and end the connection without returning a response i.e. if it ended in filename.php.swp
    not applicable to you
    next check wordpress auto installer centmin.sh menu option 22 generated wpsecure_yourdomain.com.conf include files
    grep -C4 -n 444 /usr/local/nginx/conf/wpsecure_newdomain.com.conf
    21-
    22-# Make sure files with the following extensions do not get loaded by nginx because nginx would display the source code, and these files can contain PASSWORDS!
    23-location ~* \.(engine|inc|info|install|make|module|profile|test|po|sh|.*sql|theme|tpl(\.php)?|xtmpl)$|^(\..*|Entries.*|Repository|Root|Tag|Template)$|\.php_
    24-{
    25:return 444;
    26-}
    27-
    28-#nocgi
    29-location ~* \.(pl|cgi|py|sh|lua)$ {
    30:return 444;
    31-}
    32-
    33-#disallow
    34-location ~* (roundcube|webdav|smtp|http\:|soap|w00tw00t) {
    35:return 444;
    36-}
    37-
    38-location ~ /(\.|wp-config\.php|wp-config\.txt|readme\.html|license\.txt) { deny all; }
    could be something in your wordpress post title/url matching something like 'soap', checking the url you gave me it has that word !
    -soapland-
    hmm might remove that word soap from this list hehe
    55,983
    3:32 AM
    updated stable and beta's with fix too update tools/nvwp.sh and inc/wpsetup.inc remove url blocks · centminmod/centminmod@a627245 · GitHub
    Updated both Centmin Mod 123.08stable and 123.09beta01 builds
    To update your Centmin Mod builds follow instructions at centminmod.com/upgrade.html and respective version threads below:
    for existing installs of wordpress edit the wpsecure_yourdomain.conf include and change the lines as per update tools/nvwp.sh and inc/wpsetup.inc remove url blocks · centminmod/centminmod@a627245 · GitHub
  10. Yohan
    Yohan Member
    68
    11:02 PM
    1.9.x
    MariaDB 10
    Haha... its working !! :)
    55,983
    3:32 AM
    soap ain't a bad thing afterall ! :D
  12. Yohan
    Yohan Member
    68
    11:02 PM
    1.9.x
    MariaDB 10
    Hahaha .. finally ... but this issue really annoying me last night .. i didn't even slep well ..
