PHP-FPM Switch from TCP to UNIX domain sockets
Discussion in 'Centmin Mod Insights' started by rdan, Jun 7, 2014.
    1,412
    10:36 PM
    I just read this:
    What adjustments on centminmod should do to make this happen? :)
    Thanks!
  2. rdan
    1,412
    10:36 PM
    55,802
    12,272
    12:36 AM
    straight from https://plus.google.com/b/104831941868856035845/113497966974166918390/posts/3oSoWwRvPqz
    FYI, the way the automated menu stuff is done in Centmin Mod it relies or assumes PHP-FPM uses TCP. You can try switching but it might auto revert on PHP updates to TCP
    To switch from TCP to Unix sockets need to edit 2 files
    Both can be edited using command shortcuts outlined in FAQ 16 at http://centminmod.com/faq.html
    edit /usr/local/etc/php-fpm.conf (fpmconf)
    comment out with semicolon the line
    from
    listen = 127.0.0.1:9000
    to
    ;listen = 127.0.0.1:9000
    uncomment the line
    from
    ;listen = /tmp/php5-fpm.sock
    to
    edit /usr/local/nginx/conf/php.conf (phpinc)
    uncomment the line
    from
        fastcgi_pass   127.0.0.1:9000;
        #fastcgi_pass   unix:/tmp/php5-fpm.sock;
    to
        #fastcgi_pass   127.0.0.1:9000;
    Then restart PHP-FPM
    service php-fpm restart
    or via command shortcut
    fpmrestart
  4. Matt
    Matt Well-Known Member
    932
    415
    Rotherham, UK
    3:36 PM
    1.5.15
    MariaDB 10.2
    I've tried on both. Didn't notice any difference personally, but I highly doubt my sites are going to cause enough traffic on the socket to stress it out, so I've just left it on TCP
  5. rdan
    1,412
    10:36 PM
    Thanks for the steps :)
    What about this step?
    3. Setup upstream load balancing
  6. rdan
    1,412
    10:36 PM
    What about this line on /usr/local/etc/php-fpm.conf (fpmconf)
    Should I comment it out also?
    On /usr/local/nginx/conf/php.conf (phpinc)
    I see this:
    So I need to change it to:
    Right?
    55,802
    12,272
    12:36 AM
    You can try it out, just need to create additional PHP-FPM pools and their conf files in /usr/local/nginx/conf/phpfpmd/. There's a sample second pool in zip download at /config/php-fpm/php-fpm-min-2pools.conf to work off of - just look at the settings from the second pool downwards after and including the [www2] line or as below.
    Of course tuning each PHP-FPM pool optimally within the confines of your server resources and site usage requirements is left up to you :)
    [www2]
    user = nginx
    group = nginx
    listen = 127.0.0.1:9001
    ;listen.backlog = -1
    ;listen = /tmp/php5-fpm2.sock
    ;listen.owner = nobody
    ;listen.group = nobody
    ;listen.mode = 0666
    pm = dynamic
    pm.max_children = 5
    pm.start_servers = 1
    pm.min_spare_servers = 1
    pm.max_spare_servers = 3
    pm.max_requests = 5000
    rlimit_files = 65536
    rlimit_core = 0
    ; The timeout for serving a single request after which the worker process will
    ; be killed. This option should be used when the 'max_execution_time' ini option
    ; does not stop script execution for some reason. A value of '0' means 'off'.
    ; Available units: s(econds)(default), m(inutes), h(ours), or d(ays)
    ; Default Value: 0
    ;request_terminate_timeout = 0
    ; Default Value: 0
    ;request_slowlog_timeout = 0
    slowlog = /var/log/php-fpm/www-slow2.log
    pm.status_path = /phpstatus2
    ping.path = /phpping2
    ping.response = pong
    ; Limits the extensions of the main script FPM will allow to parse. This can
    ; prevent configuration mistakes on the web server side. You should only limit
    ; FPM to .php extensions to prevent malicious users to use other extensions to
    ; exectute php code.
    ; Note: set an empty value to allow all extensions.
    ; Default Value: .php
    security.limit_extensions = .php .php3 .php4 .php5
    Centmin Mod does have plans in place for multiple PHP-FPM pools as such for both TCP and Unix sockets ;)
    edit: changed the following lines
    55,802
    12,272
    12:36 AM
    whoops yeah missed that, updated https://community.centminmod.com/threads/switch-from-tcp-to-unix-domain-sockets.307/#post-1431
  9. rdan
    1,412
    10:36 PM
    But on /usr/local/nginx/conf/php.conf (phpinc), it should be:
    to
    Right?
    I don't see any code that just: ;listen = /tmp/php5-fpm.sock
    55,802
    12,272
    12:36 AM
  11. rdan
    1,412
    10:36 PM
    Just tried it and display,
    502 Bad Gateway
    nginx
    55,802
    12,272
    12:36 AM
    which you tried switching to Unix socket or 2nd pool ?
    for 2nd pool might need to change
    to
    listen.owner = nginx
    listen.group = nginx
  13. rdan
    1,412
    10:36 PM
    Unix socket.
    55,802
    12,272
    12:36 AM
    in /usr/local/etc/php-fpm.conf (fpmconf) you might need to
    change
    to
    55,802
    12,272
    12:36 AM
    Actually started testing what is outlined at http://www.softwareprojects.com/res...-and-php-fpm-for-high-traffic-sites-2081.html myself on this forum using the above outlined steps.
    Upstream load balancing between TCP port 9000 and 1x php-fpm Unix socket. Unix socket isn't as stable under high loads, so gave TCP a 75% weighting and PHP-FPM unix socket a 25% weighting and you can see some PHP-FPM stats at https://community.centminmod.com/pages/mstats/.
    Used Blitz.io for stress testing the forums but didn't have enough free credits at Blitz.io to complete testing, so no conclusive results and have to wait until next month when the free credits start over (each month) and will try and see what happens if I add a 2nd or more PHP-FPM unix sockets to the upstream mix.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    55,802
    12,272
    12:36 AM
    Finished testing using php-fpm unix sockets and no where near as stable as TCP, so switched to testing multiple TCP php-fpm pools :)
  17. rdan
    1,412
    10:36 PM
    Please also share how tos :D
    Thanks!
    55,802
    12,272
    12:36 AM
    basically same as above just
    instead of within each php-fpm pool /usr/local/nginx/conf/phpfpmd/YOURNEWPHPPOOLNAME.conf file
    you specify a different TCP port each with own unique paths
    fastcgi_pass   127.0.0.1:9001;
  19. rdan
    1,412
    10:36 PM
    I tried to follow this again but, still 502 Bad Gateway.
  20. rdan
    1,412
    10:36 PM
    Works now :D
    Didn't know Nginx needs to be restarted also:D
