PHP-FPM Stuck on Axel command
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Doni, Jan 28, 2017.
  1. Doni
    Doni Member
    32
    5:44 AM
    nginx/1.7.4
    mysql Ver 15.1 Distrib 5.5.39-MariaDB, for Linux (x86_64) using readline 5.1
    I just installed centmin on my VPS, but when i try to update the PHP, the process is stuck. I do ps aux to check the process, and it seems it stuck on axel command when try to download PHP. I try to manually execuate the command and it also stuck. Can you help me with this?
    root      1505  0.0  0.1 347356  2548 pts/0    Sl+  15:47   0:00 axel http://php.net/get/php-5.6.30.tar.gz/from/this/mirror -o php-5.6.30.tar.gz
    • Nginx Version Installed: i.e. 1.11.9
    • When was last time updated Centmin Mod code base ? : Today
    38,028
    8,352
    8:44 AM
    could be network connectivity issues or slowness between your server and php
    Example list /root/centminlogs files in date ascending order and grep for install.log
    38,028
    8,352
    8:44 AM
    also what do you get for output for this command
    curl -I http://php.net/get/php-5.6.30.tar.gz/from/this/mirror
    i.e.
    HTTP/1.1 302 Found
    Server: nginx/1.6.2
    Date: Fri, 27 Jan 2017 17:04:30 GMT
    Connection: keep-alive
    X-Powered-By: PHP/5.6.29-0+deb8u1
    Content-language: en
    X-Frame-Options: SAMEORIGIN
    Set-Cookie: COUNTRY=NA%2C100.11.11.11; expires=Fri, 03-Feb-2017 17:04:30 GMT; Max-Age=604800; path=/; domain=.php.net
    X-PHP-Load: 2.39, 2.56, 2.84
    Status: 302 Found
    Location: http://php.net/distributions/php-5.6.30.tar.gz
  4. Doni
    Doni Member
    32
    5:44 AM
    nginx/1.7.4
    Its CentOS 7 64 bit with OpenVZ virtualisation
    123.09beta01
    I upgrade from 08 stable because when i try to install .09 directly from one liner command, it also stuck when downloading the PHP
    .08 was installed using one liner curl
    A couple hours ago
    and this is the log from my instalation:
    https://gist.github.com/anonymous/e8623dadb0dd82277a6d02c738a3c84b[CODEB]
  5. Doni
    Doni Member
    32
    5:44 AM
    nginx/1.7.4
    38,028
    8,352
    8:44 AM
    from install log seems you have a few locale issues in server and/or derived from your local system/ssh client
    what is the operating system and ssh client you using to connect to the server from ? MacOS, Windows, Linux ? is your local pc that you run ssh client from non-english language based ?
    This software comes with no warranty of any kind. You are free to use
    it for both personal and commercial use as licensed under the GPL.
    Please read the included readme.txt before using this script.
    useradd: group '500' does not exist
    removing any i686 packages installed by default
    Failed to set locale, defaulting to C
    Check CSF Firewall Version:
    perl: warning: Setting locale failed.
    perl: warning: Please check that your locale settings:
        LANGUAGE = (unset),
        LC_ALL = (unset),
        LC_CTYPE = "UTF-8",
        LANG = "en_US.UTF-8"
        are supported and installed on your system.
    perl: warning: Falling back to the standard locale ("C").
    You have an unresolved error when starting csf:
    Error: FASTSTART: (Packet Filter IPv4) [] [iptables-restore: line 14 failed]. Try restarting csf with FASTSTART disabled, at line 5046 in /usr/sbin/csf
    You need to restart csf successfully to remove this warning, or delete /etc/csf/csf.error
    Check mysqlreport version:
        LANGUAGE = (unset),
        LC_ALL = (unset),
        LC_CTYPE = "UTF-8",
    what's output in ssh for your server for command
    locale
    and
    localectl status
    maybe unrelated to php download issue though
  7. Doni
    Doni Member
    32
    5:44 AM
    nginx/1.7.4
    Hi Eva,
    I'm using terminal in OSX to connect to my server. The setting are attached below.
    This is the output for locale command
    [[email protected] centminmod]# locale
    LANG=C
    LC_CTYPE="C"
    LC_NUMERIC="C"
    LC_TIME="C"
    LC_COLLATE="C"
    LC_MONETARY="C"
    LC_MESSAGES="C"
    LC_PAPER="C"
    LC_NAME="C"
    LC_ADDRESS="C"
    LC_TELEPHONE="C"
    LC_MEASUREMENT="C"
    LC_IDENTIFICATION="C"
    LC_ALL=C
    And this is for localectl status
    [[email protected] centminmod]# localectl status
       System Locale: LANG=C
           VC Keymap: n/a
          X11 Layout: n/a
  8. Doni
    Doni Member
    32
    5:44 AM
    nginx/1.7.4
    Hi eva, you are right, the problem is on the locale. I try to list locale on my VPS using
    locale -a
    And from that list i set the locale via .bashrc until it look like this
    [[email protected] ~]# locale
    LANG=en_US.utf8
    LC_CTYPE="en_US.utf8"
    LC_NUMERIC="en_US.utf8"
    LC_TIME="en_US.utf8"
    LC_COLLATE="en_US.utf8"
    LC_MONETARY="en_US.utf8"
    LC_MESSAGES="en_US.utf8"
    LC_PAPER="en_US.utf8"
    LC_NAME="en_US.utf8"
    LC_ADDRESS="en_US.utf8"
    LC_TELEPHONE="en_US.utf8"
    LC_MEASUREMENT="en_US.utf8"
    LC_IDENTIFICATION="en_US.utf8"
    LC_ALL=en_US.utf8
    Logout and re-login to my VPS and now the axel command are run smoothly.
    Thank you
    38,028
    8,352
    8:44 AM
    Great work. Looking good then :D
