Nginx Start problem cause /usr/bin/pkttyagent
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by R0rke, Nov 14, 2017.
  1. R0rke
    R0rke Member
    128
    Iran
    4:22 PM
    1.11.1
    10.1
    • CentOS Version: CentOS Linux release 7.4.1708 (Core)
    • Nginx Version Installed: 1.13.6
    • PHP Version Installed: 5.6.32
    • When was last time updated Centmin Mod code base ? : its latest code
    • Persistent Config:
      cat: /etc/centminmod/custom_config.inc: No such file or directory
    PHP:
    Restarting nginx (via systemctl):  Job for nginx.service failed because the control process exited with error codeSee "systemctl status nginx.service" and "journalctl -xe" for details.
    Nov 14 12:44:39 SomEhOst.co mysqld[11983]: 2017-11-14 12:44:39 140542759934208 [NoteInnoDB:  Percona XtraDB (http://www.percona.com) 5.6.36-82.2 sta
    Nov 14 12:44:39 SomEhOst.co mysqld[11983]: 2017-11-14 12:44:39 140541836650240 [NoteInnoDBDumping buffer pool(snot yet started
    Nov 14 12
    :44:39 SomEhOst.co mysqld[11983]: 2017-11-14 12:44:39 140542759934208 [NotePlugin 'FEEDBACK' is disabled.
    Nov 14 12:44:39 SomEhOst.co mysqld[11983]: 2017-11-14 12:44:39 140542759934208 [NoteServer socket created on IP'::'.
    Nov 14 12:44:39 SomEhOst.co mysqld[11983]: 2017-11-14 12:44:39 140542759934208 [Note] /usr/sbin/mysqldready for connections.
    Nov 14 12:44:39 SomEhOst.co mysqld[11983]: Version'10.1.28-MariaDB'  socket'/var/lib/mysql/mysql.sock'  port3306  MariaDB Server
    Nov 14 12
    :44:39 SomEhOst.co systemd[1]: Started MariaDB database server.
    SubjectUnit mariadb.service has finished start-up
    -- Defined-Bysystemd
    -- Supporthttp://lists.freedesktop.org/mailman/listinfo/systemd-devel
    Unit mariadb.service has finished starting up.
    The start-up result is done.
    Nov 14 12:44:39 SomEhOst.co polkitd[630]: Unregistered Authentication Agent for unix-process:11732:10717 (system bus name :1.32object path /org/free
    Nov 14 12
    :44:43 SomEhOst.co polkitd[630]: Registered Authentication Agent for unix-process:12022:11475 (system bus name :1.33 [/usr/bin/pkttyagent --n
    Nov 14 12
    :44:43 SomEhOst.co systemd[1]: Starting SYSVNginx is an HTTP(SserverHTTP(Sreverse proxy and IMAP/POP3 proxy server...
    SubjectUnit nginx.service has begun start-up
    Unit nginx.service has begun starting up.
    Nov 14 12:44:43 SomEhOst.co systemd[1]: nginx.servicecontrol process exitedcode=exited status=5
    Nov 14 12
    :44:43 SomEhOst.co systemd[1]: Failed to start SYSVNginx is an HTTP(SserverHTTP(Sreverse proxy and IMAP/POP3 proxy server.
    SubjectUnit nginx.service has failed
    Unit nginx.service has failed.
    The result is failed.
    Nov 14 12:44:43 SomEhOst.co systemd[1]: Unit nginx.service entered failed state.
    Nov 14 12:44:43 SomEhOst.co systemd[1]: nginx.service failed.
    Nov 14 12:44:43 SomEhOst.co polkitd[630]: Unregistered Authentication Agent for unix-process:12022:11475 (system bus name :1.33object path /org/free
    Nginx not startin cause : polkitd[630]: Registered Authentication Agent for unix-process:12022:11475 (system bus name :1.33 [/usr/bin/pkttyagent --n
    and
    Nov 14 12:44:39 SomEhOst.co polkitd[630]: Unregistered Authentication Agent for unix-process:11732:10717 (system bus name :1.32, object path /org/free
    have no idea why its happening just installed centmin mod a hour ago via git
    38,622
    8,530
    9:22 AM
    Example list /root/centminlogs files in date ascending order and grep for install.log
  3. R0rke
    R0rke Member
    128
    Iran
    4:22 PM
    1.11.1
    10.1
    updated post #1
    and send u a centminmod_1.2.3-eva2000.09.008_141117-054145_install.log as private message because pastebin is sucks . its down for heavy traffic
    38,622
    8,530
    9:22 AM
    were there recent yum updates ? check output for
    yum history list
    could be centos 7.4 related updates which would require a server reboot
  5. R0rke
    R0rke Member
    128
    Iran
    4:22 PM
    1.11.1
    10.1
    ID     | Command line             | Date and time    | Action(s)      | Altered
       124 | update --disableplugin=p | 2017-11-14 12:41 | Update         |    7 EE
       123 | -y -q install haveged rn | 2017-11-14 06:12 | Install        |    2
       122 | -q -y install pure-ftpd  | 2017-11-14 06:12 | Install        |    3
       121 | -y install yum-plugin-ve | 2017-11-14 06:11 | Install        |    1
       120 | -y install perl-LWP-Prot | 2017-11-14 06:11 | Install        |    2
       119 | -q -y install libmemcach | 2017-11-14 06:10 | Install        |    2
       118 | -q -y install postfix-pe | 2017-11-14 06:09 | Install        |    4
       117 | -y install mailx         | 2017-11-14 06:09 | Install        |    1
       116 | -q -y install libicu lib | 2017-11-14 06:02 | Install        |    2
       115 | -q -y install fio --disa | 2017-11-14 06:02 | Install        |    9
       114 | -y install mytop         | 2017-11-14 06:01 | Install        |    1
       113 | -y install net-snmp --di | 2017-11-14 06:01 | Install        |    1
       112 | -y install postfix --dis | 2017-11-14 06:01 | Install        |    1
       111 | -q -y install perl-DBD-M | 2017-11-14 06:01 | Install        |    1
       110 | -y install MariaDB-clien | 2017-11-14 06:00 | Install        |    8 EE
       109 | -y remove mariadb-libs   | 2017-11-14 06:00 | Erase          |    5 EE
       108 | -y install libuuid-devel | 2017-11-14 06:00 | Install        |    1
       107 | -y install ntp           | 2017-11-14 05:57 | Install        |    3
       106 | -q -y remove axel        | 2017-11-14 05:55 | Erase          |    1
       105 | -y install ImageMagick6  | 2017-11-14 05:55 | Install        |   24
    history list
    i do reboot , but nothin
    38,622
    8,530
    9:22 AM
    • Funny Funny x 1
    38,622
    8,530
    9:22 AM
    if nginx failed to restart run config test to see if nginx reports the issue
    nginx -t
  8. R0rke
    R0rke Member
    128
    Iran
    4:22 PM
    1.11.1
    10.1
    yeah its fresh install i do reboot -h now again :
    when i run service nginx restart :
     journalctl -xe
    -- Unit session-2.scope has begun starting up.
    Nov 14 14:27:36 localhost.co sshd[1661]: pam_unix(sshd:session): session opened for user root by (uid=
    Nov 14 14:27:40 localhost.co postfix/pickup[1448]: EEA10A9B0F: uid=0 from=<root>
    Nov 14 14:27:40 localhost.co postfix/cleanup[1723]: EEA10A9B0F: message-id=<[email protected]
    Nov 14 14:27:40 localhost.co postfix/qmgr[1449]: EEA10A9B0F: from=<[email protected]>, size=513, nrcpt=1
    Nov 14 14:27:40 localhost.co postfix/pickup[1448]: F2B9714310A: uid=0 from=<root>
    Nov 14 14:27:40 localhost.co postfix/cleanup[1723]: F2B9714310A: message-id=<20171114105740.F2B9714310
    Nov 14 14:27:40 localhost.co postfix/qmgr[1449]: F2B9714310A: from=<[email protected]>, size=515, nrcpt=
    Nov 14 14:27:41 localhost.co postfix/smtp[1725]: Trusted TLS connection established to mta5.am0.yahood
    Nov 14 14:27:41 localhost.co postfix/smtp[1727]: Trusted TLS connection established to mta5.am0.yahood
    Nov 14 14:27:42 localhost.co postfix/smtp[1727]: F2B9714310A: to=<[email protected]>, relay=mta5.am0.
    Nov 14 14:27:42 localhost.co postfix/qmgr[1449]: F2B9714310A: removed
    Nov 14 14:27:42 localhost.co postfix/smtp[1725]: EEA10A9B0F: to=<[email protected]>, relay=mta5.am0.y
    Nov 14 14:27:42 localhost.co postfix/qmgr[1449]: EEA10A9B0F: removed
    Nov 14 14:27:46 localhost.co polkitd[648]: Registered Authentication Agent for unix-process:1741:4768
    Nov 14 14:27:46 localhost.co systemd[1]: Starting SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse pr
    -- Subject: Unit nginx.service has begun start-up
    -- Defined-By: systemd
    -- Unit nginx.service has begun starting up.
    Nov 14 14:27:46 localhost.co systemd[1]: nginx.service: control process exited, code=exited status=5
    Nov 14 14:27:46 localhost.co systemd[1]: Failed to start SYSV: Nginx is an HTTP(S) server, HTTP(S) rev
    -- Subject: Unit nginx.service has failed
    -- Unit nginx.service has failed.
    -- The result is failed.
    Nov 14 14:27:46 localhost.co systemd[1]: Unit nginx.service entered failed state.
    Nov 14 14:27:46 localhost.co systemd[1]: nginx.service failed.
    Nov 14 14:27:46 localhost.co polkitd[648]: Unregistered Authentication Agent for unix-process:1741:476
    lines 2499-2532/2532 (END)
    i do but nginx -t :
    -bash: nginx: command not found
    38,622
    8,530
    9:22 AM
    k found the problem as you're not using betainstaller.sh but using betainstaller-latest.sh ? for installing 123.09beta01 ? if using betainstaller-latest.sh then ngx_pagespeed is enabled and you hit ngx_pagespeed 1.13.35.1 beta bug
    adding module in ../ngx_pagespeed-1.13.35.1-beta
    mod_pagespeed_dir=../ngx_pagespeed-1.13.35.1-beta/psol/include
    build_from_source=false
    checking for psol ... not found
    ./configure: error: module ngx_pagespeed requires the pagespeed optimization library.
    Look in /svr-setup/nginx-1.13.6/objs/autoconf.err for more details.
    as requires new libuuid-devel yum package and my work around fix was for nginx upgrades it seems as initial nginx installs the libuuid-devel package install came later in the routine so nginx fails to install
    updated 123.09beta01 to move libuuid-devel yum to much earlier in initial install routine
  10. R0rke
    R0rke Member
    128
    Iran
    4:22 PM
    1.11.1
    10.1
    aha i remeber also i got error last time i installed centminmod Option enabled :
    NGINX_PAGESPEEDGITMASTER='n(changed to y)' # Install ngx_pagespeed from official github master instead
    i got some error when installing Nginx but i do OS reload and fresh install Centminmod till this problem happened .
    fix up initial install ngx_pagespeed
    centminmod committed 26 minutes ago
    - missing libuuid-devel yum package
    fast update
