SSL Letsencrypt ssl not issued for subdomain vhost
Discussion in 'Domains, DNS, Email & SSL Certificates' started by adzkii, Apr 20, 2020.
  1. adzkii
    adzkii Member
    38
    10:27 AM
    [Mon Apr 20 00:45:00 UTC 2020] Lets find script dir.
    [Mon Apr 20 00:45:00 UTC 2020] _SCRIPT_='/root/.acme.sh/acme.sh'
    [Mon Apr 20 00:45:00 UTC 2020] _script='/root/.acme.sh/acme.sh'
    [Mon Apr 20 00:45:00 UTC 2020] _script_home='/root/.acme.sh'
    [Mon Apr 20 00:45:00 UTC 2020] Using config home:/root/.acme.sh
    [Mon Apr 20 00:45:00 UTC 2020] LE_WORKING_DIR='/root/.acme.sh'
    [Mon Apr 20 00:45:00 UTC 2020] Running cmd: issue
    [Mon Apr 20 00:45:00 UTC 2020] _main_domain='mail.domain.com'
    [Mon Apr 20 00:45:00 UTC 2020] _alt_domains='no'
    [Mon Apr 20 00:45:00 UTC 2020] ACME_DIRECTORY='https://acme-v02.api.letsencrypt.org/directory'
    [Mon Apr 20 00:45:00 UTC 2020] _ACME_SERVER_HOST='acme-v02.api.letsencrypt.org'
    [Mon Apr 20 00:45:00 UTC 2020] DOMAIN_PATH='/root/.acme.sh/mail.domain.com'
    [Mon Apr 20 00:45:00 UTC 2020] '/home/nginx/domains/mail.domain.com/public' does not contain 'dns'
    [Mon Apr 20 00:45:00 UTC 2020] Using ACME_DIRECTORY: https://acme-v02.api.letsencrypt.org/directory
    [Mon Apr 20 00:45:00 UTC 2020] _init api for server: https://acme-v02.api.letsencrypt.org/directory
    [Mon Apr 20 00:45:00 UTC 2020] GET
    [Mon Apr 20 00:45:00 UTC 2020] url='https://acme-v02.api.letsencrypt.org/directory'
    [Mon Apr 20 00:45:00 UTC 2020] timeout=
    [Mon Apr 20 00:45:00 UTC 2020] _CURL='curl -L --silent --dump-header /root/.acme.sh/http.header  -g '
    [Mon Apr 20 00:45:01 UTC 2020] ret='0'
    [Mon Apr 20 00:45:01 UTC 2020] response='{
      "6hTF0nbZfHo": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
      "keyChange": "https://acme-v02.api.letsencrypt.org/acme/key-change",
      "meta": {
        "caaIdentities": [
          "letsencrypt.org"
        "termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
        "website": "https://letsencrypt.org"
      "newAccount": "https://acme-v02.api.letsencrypt.org/acme/new-acct",
      "newNonce": "https://acme-v02.api.letsencrypt.org/acme/new-nonce",
      "newOrder": "https://acme-v02.api.letsencrypt.org/acme/new-order",
      "revokeCert": "https://acme-v02.api.letsencrypt.org/acme/revoke-cert"
    [Mon Apr 20 00:45:01 UTC 2020] ACME_KEY_CHANGE='https://acme-v02.api.letsencrypt.org/acme/key-change'
    [Mon Apr 20 00:45:01 UTC 2020] ACME_NEW_AUTHZ
    [Mon Apr 20 00:45:01 UTC 2020] ACME_NEW_ORDER='https://acme-v02.api.letsencrypt.org/acme/new-order'
    [Mon Apr 20 00:45:01 UTC 2020] ACME_NEW_ACCOUNT='https://acme-v02.api.letsencrypt.org/acme/new-acct'
    [Mon Apr 20 00:45:01 UTC 2020] ACME_REVOKE_CERT='https://acme-v02.api.letsencrypt.org/acme/revoke-cert'
    [Mon Apr 20 00:45:01 UTC 2020] ACME_AGREEMENT='https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf'
    [Mon Apr 20 00:45:01 UTC 2020] ACME_NEW_NONCE='https://acme-v02.api.letsencrypt.org/acme/new-nonce'
    [Mon Apr 20 00:45:01 UTC 2020] ACME_VERSION='2'
    [Mon Apr 20 00:45:01 UTC 2020] Le_NextRenewTime
    [Mon Apr 20 00:45:01 UTC 2020] _on_before_issue
    [Mon Apr 20 00:45:01 UTC 2020] _chk_main_domain='mail.domain.com'
    [Mon Apr 20 00:45:01 UTC 2020] _chk_alt_domains
    [Mon Apr 20 00:45:01 UTC 2020] '/home/nginx/domains/mail.domain.com/public' does not contain 'no'
    [Mon Apr 20 00:45:01 UTC 2020] Le_LocalAddress
    [Mon Apr 20 00:45:01 UTC 2020] d='mail.domain.com'
    [Mon Apr 20 00:45:01 UTC 2020] Check for domain='mail.domain.com'
    [Mon Apr 20 00:45:01 UTC 2020] _currentRoot='/home/nginx/domains/mail.domain.com/public'
    [Mon Apr 20 00:45:01 UTC 2020] '/home/nginx/domains/mail.domain.com/public' does not contain 'apache'
    [Mon Apr 20 00:45:01 UTC 2020] _saved_account_key_hash='0qn73TTxalGaekfufPW+sj9CT4rueLUqYxvtO6/DEoc='
    [Mon Apr 20 00:45:01 UTC 2020] _saved_account_key_hash is not changed, skip register account.
    [Mon Apr 20 00:45:01 UTC 2020] Read key length:
    [Mon Apr 20 00:45:01 UTC 2020] Creating domain key
    [Mon Apr 20 00:45:01 UTC 2020] Using config home:/root/.acme.sh
    [Mon Apr 20 00:45:01 UTC 2020] ACME_DIRECTORY='https://acme-v02.api.letsencrypt.org/directory'
    [Mon Apr 20 00:45:01 UTC 2020] _ACME_SERVER_HOST='acme-v02.api.letsencrypt.org'
    [Mon Apr 20 00:45:01 UTC 2020] Domain key exists, do you want to overwrite the key?
    [Mon Apr 20 00:45:01 UTC 2020] Add '--force', and try again.
    [Mon Apr 20 00:45:01 UTC 2020] Create domain key error.
    [Mon Apr 20 00:45:01 UTC 2020] pid
    [Mon Apr 20 00:45:01 UTC 2020] No need to restore nginx, skip.
    [Mon Apr 20 00:45:01 UTC 2020] _clearupdns
    [Mon Apr 20 00:45:01 UTC 2020] dns_entries
    [Mon Apr 20 00:45:01 UTC 2020] skip dns.
    [Mon Apr 20 00:45:01 UTC 2020] _on_issue_err
    [Mon Apr 20 00:45:01 UTC 2020] Please check log file for more details: /root/centminlogs/acmetool.sh-debug-log-200420-004414.log
    [Mon Apr 20 00:45:01 UTC 2020] _chk_vlist
    mail.domain.com is not a top level domain
    your server IPv4 IP address: 78.141.22x.xxx
    current DNS A record IPv4 address for mail.domain.com is: 78.141.22x.xxx
    Do you want to continue [y/n]: y
    can't figure out why
    domain entry is correct
    mail.domain.com A 78.141.22x.xxx
    45,183
    10,276
    7:27 PM
    did you previously run mail.domain.com nginx vhost creation ? clue is
    First try running your intended SSL certificate domain through the letsdebug.net online testing tool to check for potential errors with HTTP-01 validation. If you created Centmin Mod 123.09beta01 or higher Nginx site with Letsencrypt via centmin.sh menu option 2, 22 or nv command line, you now also have an automatic letsdebug.net API check log saved at /root/centminlogs/letsdebug-yourdomain.com-${DT}.log where yourdomain.com is domain specified during nginx vhost creation and DT is date/timestamp. Inspecting the /root/centminlogs/letsdebug-yourdomain.com-${DT}.log log will also give you clues as to why letsencrypt SSL certificate issuance failed.
    How was the initial letsencrypt ssl certificate obtained ? Which method ?
    • Was the domain nginx vhost alreadying created prior or new domain nginx vhost site setup for first time ?
    • Via centmin.sh menu option 2, 22, /usr/bin/nv ?
    • If you ran centmin.sh menu option 2 or 22, which letsencrypt option did you select from
      Setup full Nginx vhost + Wordpress + WP Plugins
      Enter vhost domain name you want to add (without www. prefix): acme3.domain1.com
      You have 4 options:
      1. issue staging test cert with HTTP + HTTPS
      2. issue staging test cert with HTTPS default
      Enter option number 1-4: 1
    • Via addons/acmetool.sh ? which specific command ? examples
      ./acmetool.sh issue acme.domain.com
      ./acmetool.sh issue acme.domain.com live
      ./acmetool.sh issue acme.domain.com d
      ./acmetool.sh issue acme.domain.com lived
    • What was order of steps you did ? Did you run centmin.sh menu option 2 first with letsencrypt ? Then did you run addons/acmetool.sh afterwards ?
    Troubleshooting
      ls -lahrt /root/centminlogs
      ACMEDEBUG='y'
    If acme.sh auto renewals didn't happen, check output for the following commands
    grep acme /var/log/cron* | sed -e "s|$(hostname -s)|host|g"
    echo | openssl s_client -connect yourdomain.com:443
    SSLLabs Test
    Also run your HTTPS domain site through SSLLabs tester at SSL Server Test (Powered by Qualys SSL Labs) if it says untrusted SSL cert and prompts to continue the test, continue the test.
    45,183
    10,276
    7:27 PM
    If you using @brijendrasial mail addon at Install Mail Server on Centminmod then it has it's own letsencrypt issuance routine separate from centmin.sh menu option 2, 22 or nv command so may have conflicted with centmin.sh menu option 2, 22 or nv's own letsencrypt. You'd need to sort that out at @brijendrasial thread at Install Mail Server on Centminmod if you are creating mail.domain.com for that mail addon purpose and not use centmin.sh menu option 2, 22 or nv routines for such.
