SSL Cloudflare SSL Issues When Enable Cloudflare's SSL/TSL in "Full" or "Full (Strict)" Mode
Discussion in 'Domains, DNS, Email & SSL Certificates' started by tommy2024, Aug 30, 2024.
  1. tommy2024
    tommy2024 New Member
    11
    3:51 PM
    140.00beta01
    MariaDB Ver
    Hi Guys,
    I just tried out CMM and successfully set up Vhost for my website. However, when I was trying to use Self-Signed SSL Certificate (Paid SSL certificate from Namecheap.com) with Cloudflare's DNS, i was able to access the default: hostname.domain.com (Centmin Mod Nginx Test Page) or any other Centmin Tools pages such as: Memcached, etc only when using Cloudflare's SSL/TSL in "Flexible" Mode. If I change the Cloudflare's SSL/TSL in "Full" or "Full (Strict)" Mode, the hostname.domain.com (Centmin Mod Nginx Test Page) or other Centmin Tools pages when I typed will automatically redirected back to the vhost site (where my website is installed) instead.
    Here are all based steps I tried, could you have a look to see if i was missed out something:
    I) I used Digital Ocean with Centos 9 Stream x64 (2 vCPUs 4GB / 120GB Disk) to install CMM
    II) Before setup the "Add Nginx Vhost Domain" (Centmin Mod Menu - Step 2), I was followed the instructions on this page to create Nginx SPDY SSL Vhost for self signed SSL certificates (method 1):
    Nginx HTTP/2 & SPDY SSL Configuration - CentminMod.com LEMP Nginx web stack for CentOS, AlmaLinux, Rocky Linux
    - My domain purchased on Godaddy, I already transferred the Nameservers to Cloudflare
    - My SSL purchased from Namecheap.com (just DV only, not Wildcard one)
    - I used Digicert.com CSR wizard to generates a openssl command
    All above steps are done well as even after created my own self signed SSL certificate, the "CSR Code" I input on the Namecheap for Domain Validation, it was stated as "valid" status.
    After that, when set up the Nginx Vhost Domain (Centmin Mod Menu - Step 2):
    "Create a self-signed certificate Nginx host?"
    > I chosen "y" (Yes) (not sure if it is correct or not when I choose "Yes" again even I already created my own self signed SSL certificate with valid "CSR Code" before the host setup)
    Get Letsencrypt SSL certificate Nginx host?
    >I chosen "n" (No).
    Then CMM displaying 4 options for me to choose on how I wanna issue the cer, I chosen the number (3), which was:
    "3. Issue live cert with HTTP + HTTPS (trusted)"
    And continuing until successfully vhost creation.
    Once everything is done, I successfully installed Xenforo Forum on the vhost I just created under the public folder (root).
    The "https" with valid certificate has no issues at all for Xenforo site in all Cloudflare's SSL/TSL modes: "Flexible"/ "Full"/ or "Full (Strict)". The only issue here is that If I change the Cloudflare's SSL/TSL in "Full" or "Full (Strict)" Mode, the hostname.domain.com (Centmin Mod Nginx Test Page) or other Centmin Tools pages, such as such as: Memcached, etc when I typed on browser will automatically redirected back to the vhost site (Xenforo) instead, unless I change the Cloudflare's SSL/TSL mode to "Flexible", which I am not prefer since I don't want the connection from Cloudflare to Origin Server is not encrypted (even though my Xenforo site still displaying in "https" when I changed to this option).
    Here is my virtual.conf file:
                listen 80 default_server backlog=131070 reuseport;
                server_name turbosv;
                root   html;
            access_log              /var/log/nginx/localhost.access.log     combined buffer=256k flush=5m;
            #access_log              /var/log/nginx/localhost.access.json    main_json buffer=256k flush=5m;
            error_log               /var/log/nginx/localhost.error.log      error;
    # ssi  on;
            location /nginx_status {
            stub_status on;
            access_log   off;
            allow 127.0.0.1;
            #allow youripaddress;
            deny all;
    #Enables directory listings when index file not found
    #autoindex  on;
    #Shows file listing times as local time
    #autoindex_localtime on;
    #try_files \$uri \$uri/ /index.php?q=\$uri&\$args;
    include /usr/local/nginx/conf/include_opcache.conf;
    #include /usr/local/nginx/conf/phpstatus.conf;
    #include /usr/local/nginx/conf/vts_mainserver.conf;
    Hope anyone or @eva2000 - you could spend sometimes to have a look on above issues and advise if i did something wrong with the set up.
    Really appreciated your help!
    Thank you very much.
  2. tommy2024
    11
    3:51 PM
    140.00beta01
    MariaDB Ver
    Hello,
    Updating something that you may ask:
    (Note: mydomain.net >> sorry for hiding my real domain as this is for testing only, but the real domain was used)
    [root@turbosv ~]# curl -I https://mydomain.net
    HTTP/2 301
    date: Fri, 30 Aug 2024 13:39:59 GMT
    content-type: text/html; charset=utf-8
    x-frame-options: SAMEORIGIN
    x-content-type-options: nosniff
    last-modified: Fri, 30 Aug 2024 13:39:59 GMT
    expires: Thu, 19 Nov 1981 08:52:00 GMT
    cache-control: private, no-cache, max-age=0
    x-powered-by: centminmod
    x-xss-protection: 1; mode=block
    cf-cache-status: DYNAMIC
    report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v4?s=2Z%2FD87dTHTyheJ7b%2FxaPsosFRZGiCafgrtdEe1Ajw42fmSTD0eOCSDk1cC0GxM7iILxP11aC1YVU1KdgzqQErZ8OK38Ob0YYxkIYKY7Lp4rQ54MCpCCdGh3Vg0dnjPQDw7M%3D"}],"group":"cf-nel","max_age":604800}
    nel: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
    server: cloudflare
    cf-ray: 8bb530a60cc85647-SIN
    alt-svc: h3=":443"; ma=86400
    [root@turbosv ~]# curl -I https://www.mydomain.net
    HTTP/2 301
    date: Fri, 30 Aug 2024 13:45:09 GMT
    last-modified: Fri, 30 Aug 2024 13:45:09 GMT
    report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v4?s=RRgb2%2BzjD0fVZiTyWjBBWmfLAG0x38Zb86TNec%2FNLZ6FBmqbyUczy%2F6bnfDww0qghbpwtPuwl7vzgMiWmBAWaTnRRtsfkhBSOlwvOi0CiQw1Or4TyfQ26n4eMJhiTAGH0eTu%2FOmA"}],"group":"cf-nel","max_age":604800}
    server: cloudflare
    cf-ray: 8bb53838da55604b-SIN
    [root@turbosv ~]# curl -I http://mydomain.net
    Date: Fri, 30 Aug 2024 13:46:58 GMT
    Content-Type: text/html
    Content-Length: 167
    Connection: keep-alive
    Cache-Control: max-age=3600
    Expires: Fri, 30 Aug 2024 14:46:58 GMT
    Report-To: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v4?s=zeMdQqefFzbIHwLm0GPWjqPtOwYG2DcVBo%2FVRvlgYRLKPmdcEszZD0ZS%2BrvGISXfg1rIPu3HtBYW2QPgGtwtPf33m5AYesS%2FJMXj0pZ0jPjh2ewWT6wyfJy3RjT2jE7m%2FNA%3D"}],"group":"cf-nel","max_age":604800}
    NEL: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
    Server: cloudflare
    CF-RAY: 8bb53ae23dde81ea-SIN
    [root@turbosv ~]# curl -I http://www.mydomain.net
    Date: Fri, 30 Aug 2024 13:49:10 GMT
    Content-Length: 167
    Expires: Fri, 30 Aug 2024 14:49:10 GMT
    Report-To: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v4?s=szKf04DknZhifksQGhr05OvlBKJQsiNhtuxdTIokYhTdIqJMFlczn7V%2BRvCJenxHgU3j408rObCqbq4o9so1t2qt7P1RGytjXZfpfin6bIxaLvj%2BJh81hg8UHl%2F5SiFOxyEBcngD"}],"group":"cf-nel","max_age":604800}
    Server: cloudflare
    CF-RAY: 8bb53e1f2d70ce32-SIN
    Thank you!
    55,180
    12,251
    6:51 PM
    If you disable Cloudflare settings for always use HTTPS and auto redirect non-https to https with Cloudflare Full sll mode does it work?
    Is hostname.domain.com's domain.com the same as mydomain.net domain?
    What does mydomain.net nginx vhost config files look like?
    what is output of these commands in ssh if you disable Cloudflare settings for always use HTTPS and auto redirect non-https to https with Cloudflare Full sll mode
    curl -I https://domain.com
    curl -I http://domain.com
    curl -I http://www.domain.com
    wrap output in CODE tags
  4. tommy2024
    11
    3:51 PM
    140.00beta01
    MariaDB Ver
    Hi @eva2000 ,
    Thank you for your response :)
    My apologize, yes. It is the same domain. Let's say we use this one from now: "mydomain.net"
    (as my real domain also .net's domain).
    > I tried to DISABLE both of setting under Cloudflare's Edge Certificates:
    - Always Use HTTPS: Off
    - Automatic HTTPS Rewrites: Off
    While still remain the Cloudflare's SSL/TLS encryption mode in "Full" mode. Still the same, the hostname.mydomain.net (Centmin Mod Nginx Test Page) or other Centmin Tools pages, such as such as: Memcached, etc when I typed on browser will automatically redirected back to the vhost site (Xenforo) instead.
    > Please see the contents of the mentioned file as below:
    # must read https://centminmod.com/getstarted.html
    #server {
    #            listen   80;
    #            server_name mydomain.net;
    #            return 301 $scheme://www.mydomain.net$request_uri;
      listen   80;
      server_name mydomain.net www.mydomain.net;
      #add_header Permissions-Policy "accelerometer=(), camera=(), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), payment=(), usb=()";
      # ssi  on;
      access_log /home/nginx/domains/mydomain.net/log/access.log combined buffer=256k flush=5m;
      #access_log /home/nginx/domains/mydomain.net/log/access.json main_json buffer=256k flush=5m;
      error_log /home/nginx/domains/mydomain.net/log/error.log;
      include /usr/local/nginx/conf/autoprotect/mydomain.net/autoprotect-mydomain.net.conf;
      root /home/nginx/domains/mydomain.net/public;
      # server and/or vhost site
      #location ~ (?:^|/)\. {
      # deny all;
      #autoindex  on;
      include /usr/local/nginx/conf/pre-staticfiles-local-mydomain.net.conf;
    # For HTTP/2 SSL Setup
    # read https://centminmod.com/letsencrypt-freessl.html
    # server {
    #       listen   80;
    #       server_name mydomain.net www.mydomain.net;
    #       return 302 https://$server_name$request_uri;
      listen 443 ssl;
      http2 on;
      ssl_dhparam /usr/local/nginx/conf/ssl/mydomain.net/dhparam.pem;
      ssl_certificate      /usr/local/nginx/conf/ssl/mydomain.net/mydomain.net.crt;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/mydomain.net/mydomain.net.key;
      #ssl_client_certificate /usr/local/nginx/conf/ssl/cloudflare/mydomain.net/origin.crt;
      #ssl_verify_client on;
      # mozilla recommended
      ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384;
      #spdy_headers_comp 5;
      ssl_buffer_size 1369;
      ssl_session_tickets on;
      # enable ocsp stapling
      #resolver 8.8.8.8 8.8.4.4 1.1.1.1 1.0.0.1 valid=10m;
      #resolver_timeout 10s;
      #ssl_stapling on;
      #ssl_stapling_verify on;
      #ssl_trusted_certificate /usr/local/nginx/conf/ssl/mydomain.net/mydomain.net-trusted.crt;
      # ssi  on;
      index index.php index.html;
      #autoindex  on;
    location ^~ /install/data/ {
        internal;
    location ^~ /install/templates/ {
        internal;
    location ^~ /internal_data/ {
        internal;
    location ^~ /library/ { #legacy
        internal;
    location ^~ /src/ {
        internal;
    location ~ \.php$ {
        try_files $uri =404;
        fastcgi_pass    127.0.0.1:9000;
        fastcgi_param   SCRIPT_FILENAME $document_root$fastcgi_script_name;
        include         fastcgi_params;
    Please see below:
    [11:16][root@turbosv ~]# curl -I https://mydomain.net
    HTTP/2 301
    date: Sat, 31 Aug 2024 11:37:16 GMT
    last-modified: Sat, 31 Aug 2024 11:37:16 GMT
    report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v4?s=jLjHrOLd6nSVmyWKlhiMnKpq4IbBPT55Yw05wrgTbuBvzKxhXLWegknwiXv3Y5Wc0OOZL%2BU%2FUOXsV0lyFMtY4SeTscD%2FnP0ymm8l6XiYeLYgmWOR44dBw60oZbStejlunWk%3D"}],"group":"cf-nel","max_age":604800}
    server: cloudflare
    cf-ray: 8bbcba451dc29f7a-SIN
    [11:37][root@turbosv ~]# curl -I https://www.mydomain.net
    HTTP/2 301
    date: Sat, 31 Aug 2024 11:39:46 GMT
    last-modified: Sat, 31 Aug 2024 11:39:46 GMT
    report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v4?s=RVMTns4YKbGNopR42HRvicCpZwS4YFK3zvOLNXbsT5yRMumZfCICBUvpE11ap4lrKKcg7lWMB3m1trrXMHHa%2ByZKpLsKIbmhd2LmoRNQpud1JQYegaVkCfM%2F%2BxeLxC50OUf48L8E"}],"group":"cf-nel","max_age":604800}
    server: cloudflare
    cf-ray: 8bbcbdeeaa049d08-SIN
    [11:39][root@turbosv ~]# curl -I http://mydomain.net
    Date: Sat, 31 Aug 2024 11:41:28 GMT
    X-Frame-Options: SAMEORIGIN
    Last-Modified: Sat, 31 Aug 2024 11:41:28 GMT
    Expires: Thu, 19 Nov 1981 08:52:00 GMT
    Cache-Control: private, no-cache, max-age=0
    X-Powered-By: centminmod
    CF-Cache-Status: DYNAMIC
    Report-To: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v4?s=vXcy2jk3UsH3fgNDNcVHKskP7iWkWQ5Yx2BIE3b5KoIVRRCljHHf%2B3h7t5YSC8CAldLIEFQrR%2FXO0HViUVYkdUudChlY5Z%2BSB2LAgDZEjIRP1%2FDGF7POFjwap8amX1b3F1o%3D"}],"group":"cf-nel","max_age":604800}
    Server: cloudflare
    CF-RAY: 8bbcc069dfdfa8f7-SIN
    [11:41][root@turbosv ~]# curl -I http://www.mydomain.net
    Date: Sat, 31 Aug 2024 11:45:48 GMT
    Last-Modified: Sat, 31 Aug 2024 11:45:48 GMT
    Report-To: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v4?s=WeewJg1ROqo%2Fw9SijGw27NTxcxMhDrVG9y5TPIe56OgQIvAVYSNYaU1JRevWucs1m7Siz%2FWGfLoD32YVlUN2ZdZW7BQkn2yUTWXGCq9dgtdz4xuxoBQqj1AJ4JRAN6MtX5qVOee%2F"}],"group":"cf-nel","max_age":604800}
    Server: cloudflare
    CF-RAY: 8bbcc6c4acd99b9d-SIN
    Lastly, this is the "virtual.conf" file contents after i changed the setting you advised as above, just pasted it here incase if you need:
                root   html;
    # ssi  on;
            stub_status on;
            access_log   off;
            allow 127.0.0.1;
            deny all;
    #autoindex  on;
    Have a nice weekend.
    55,180
    12,251
    6:51 PM
    Make sure virtual.conf main hostname's server_name isn't same as any added nginx vhost site's domain name as per Getting Started Guide step 1, the main hostname needs to be unique.
    You can check via recursive grep filter of your domain name in vhost directory at /usr/local/nginx/conf/conf.d
    grep -rnw 'yourdomain.com' /usr/local/nginx/conf/conf.d
    Also check DNS is correct use dig to check DNS for domain
    dig +short A @8.8.8.8 yourdomain.com
    dig +short A @8.8.8.8 www.yourdomain.com
    dig +short A @8.8.8.8 hostname.yourdomain.com
    check HTTP headers via curl for both HTTP (and HTTPS if you have HTTPS/SSL)
    curl -I http://yourdomain.com
    curl -I http://www.yourdomain.com
    curl -I https://yourdomain.com
    curl -I https://www.yourdomain.com
    curl -I http://hostname.yourdomain.com
    In your case what is output for virtual.conf main hostname's server_name
  6. tommy2024
    11
    3:51 PM
    140.00beta01
    MariaDB Ver
    Hi @eva2000 ,
    Thank you for your reply, but still i could not able to fix the issue yet even done with all steps you advised as above :(.
    I am about to delete everything and set up a new server to run Centminmod (ver 140.00beta01) to ensure i will not miss out any important steps, especially those related to SSL. Before doing that, could you help to clarify some of following:
    As mentioned above:
    Once the new Centminmod (ver 140.00beta01) is installed, when creating the new vHost, i wanna create my own self signed SSL certificate and notice that there is a question while adding a new Vhost:
    >> After a few testings and i found that when i chosen "y" (yes) to create my own self-signed certificate Nginx host, by the fault CMM will automatically generated all following 4 files under this path: /usr/local/nginx/conf/ssl/mydomain.com (let's say mydomain.com is the domain i am installing)
    Then, after those files created by CMM >> Should i just open, copy the contents from the file "mydomain.com.csr" to paste directly into the Namecheap SSL (CSR Input) as below image?
    Will the default CSR work with Cloudflare SSL's "Full"/ "Full (Strict)" mode if validated by Namecheap?
    The reason why i am asking because i also saw some other instructions here to generated CSR file (OpenSSL CSR) and also "Creating your own self signed SSL certificate" instead (method 1):
    Which made me confused as if by default CMM already automatically generated the CSR while creating my own self signed SSL certificate when adding a new Vhost, should i use that default generated CSR file contents to provide to Namecheap for SSL validation? or i have to follow the above mentioned article to generate OpenSSL CSR to provide for Namecheap instead?
    Really appreciate your help in advance :).
    55,180
    12,251
    6:51 PM
    To simplify the setup if behind Cloudflare, you do not need paid Name heap DV SSL certificate to use Cloudflare Full SSL.
    If your Centmin Mod Nginx domain is behind Cloudflare orange cloud enabled proxy and you have Cloudflare Full or Full Strict SSL mode enabled, it's recommended you use Cloudflare DNS API domain validation method for issuing free Letsencrypt SSL certificates on your Centmin Mod Nginx origin server side. This way you can ensure every website domain and subdomain you add has its own free Letsencrypt SSL certificate automatically issued and configured in Nginx Nginx Vhost & NSD DNS Setup - CentminMod.com LEMP Nginx web stack for CentOS, AlmaLinux, Rocky Linux
    Yes you can use the Centmin Mod Nginx generated self-signed SSL certificate's CSR but you have to also use its paired private key that is generated and NOT select Letsencrypt SSL options when creating Nginx vhost site. Again, for best trouble free setup use Letsencrypt option instead of Namecheap's DV SSL certificate via Cloudflare DNS API domain validation method Letsencrypt Free SSL Certificates Integration For Centmin Mod LEMP Stack. Paid SSL certificates are no longer needed.
  8. tommy2024
    11
    3:51 PM
    140.00beta01
    MariaDB Ver
    Hi @eva2000
    Thank you for your response.
    The reason why i wanna use Namecheap's paid DV SSL certificate because the expiration of a paid SSL is usually at least 1 year or more depending on how long you choose to pay for the duration of SSL validation, so i don't have to spend more time to care much about SSL once done with the set up.
    I do understand all benefits of using free Letsencrypt. However, as i did some researches, it seems like Letsencrypt certificates are valid for only 90 days, and you have to renew every 90 days, alright?
    Can i ask if CMM is automatically done with Letsencrypt certificates renewals every 90 days? Also, i still got a bit confused if Letsencrypt certificates are free forever as long as i keep renewing it every 90 days?
    Yes, I tried to re-installed CMM and vHost many times followed the CMM Installation instructions with self-signed SSL certificate's CSR (NOT select Letsencrypt SSL options), but still could not see how i should use or where to use the "private key that is generated", even Namecheap's DV SSL only asked for "CSR" contents instead for SSL validation. So when CMM generated self signed SSL certificate for my domain under this path: /usr/local/nginx/conf/ssl/mydomain.com (let's say mydomain.com is the domain i am using)
    I only downloaded "mydomain.com.key" together with other files under the same folder to make a backup on my PC only, but did not taking any further actions with "mydomain.com.key" file.
    By the way, do you think if it is okay if i keep using the Namecheap's DV SSL, then ignore the issue happened above by always turning on Cloudflare's SSL/TSL in "Full" mode for my website, and only change to Cloudflare's SSL/TSL "Flexible" Mode if i needed to access the default: hostname.domain.com (Centmin Mod Nginx Test Page) or any other Centmin Tools pages such as: Memcached, etc?
    Sorry for asking many questions, Thanks again!
    55,180
    12,251
    6:51 PM
    Letsencrypt SSL certificates are 90 day expiry and Centmin Mod automatically renews them via underlying acme.sh client every 60 days.
    Paid SSL certificates aren't really needed and alot of Centmin Mod servers/sites do not have issue with Letsencrypt see Market share trends for web panels, September 2024
    you'd want to fix this - just make sure main hostname and your actual domain name are diferent domain's and not the same as outlined at https://community.centminmod.com/th...n-full-or-full-strict-mode.26197/#post-101191 and you don't want to Cloudflare orange cloud enable your main hostname to begin with (which maybe your issue) due to wanting to setup and ensure your server outbound Postfix sent email is deliverable with proper SPF/DKIM/Dmarc DNS settings outlined at https://community.centminmod.com/th...ver-email-doesnt-end-up-in-spam-inboxes.6999/ which is Getting Started guide step 20
  10. tommy2024
    11
    3:51 PM
    140.00beta01
    MariaDB Ver
    Hi @eva2000 ,
    Yes i did follow the above instructions to setup the default server main hostname (Centmin Tools pages, such as: Memcached, etc) separated hostname from my website domain name. Which was:
    hostname.mydomain.com: "hostname" = my default hostname, and this URL is used as Centmin Tools pages in order to access Memcached page, Phpmyadmin, etc.
    ◦ mydomain.com: This is my website domain name
    I assume there is nothing wrong with the above setup.
    Also,
    I did disable the Cloudflare's "Proxy Status" to "GREY" color for all DNS records as well while installing CMM, Nginx vhost (only enable the Clouldflare's Proxy status to Orange color when i done with all needed installation), and i even tried to add a SPF/TXT DNS record on Cloudflare DNS for my main hostname as well:
    "v=spf1 a ~all"
    But still it could not fix the above SSL issues.
    » Everytime i turn on Cloudflare's SSL/TSL in "Flexible" mode for my website:
    I could access my website in "HTTPS", and was able to access the default: hostname.mydomain.com (Centmin Mod Nginx Test Page) or any other Centmin Tools pages such as: Memcached, Myphpamin etc in "HTTPS" as well, just that the Cloudflare's SSL/TLS encryption displaying as below (all connections between Cloudflare and my origin are made through HTTP only):
    » Everytime i turn on Cloudflare's SSL/TSL in "Full" mode for my website:
    I could access my website: mydomain.com in "HTTPS", BUT the hostname.mydomain.com (Centmin Mod Nginx Test Page) or any other Centmin Tools pages such as: Memcached, Myphpamin etc, whenever I typed it on browser will automatically redirected back to the my website (Nginx vhost) instead, even though it still in "HTTPS", and the Cloudflare's SSL/TLS encryption displaying as below:
    Which means the all connections between Cloudflare and my origin are made through HTTPS already, but just that i could not access the default hostname.mydomain.com (Centmin Mod Nginx Test Page).
    » Everytime i turn on Cloudflare's SSL/TSL in "Full (strict)" mode for my website, Cloudflare displaying:
    But in this mode, i could not access any URLs of the installed website, including the "mydomain.com", or even "hostname.mydomain.com" due to the "Invalid SSL certificate" error as below:
    I just noticed that when installing CMM on my Mac after done with server set up on Digital Ocean, while running CMM, i got this error message below on Terminal which required me to "REBOOT" the server and re-install CMM again, and i did perform a "REBOOT" every time i installed CMM, not sure if it is an issue or not:
    Centminmod First Error Notifications:
    Installed:
      dmidecode-1:3.6-1.el9.x86_64           virt-what-1.25-10.el9.x86_64
    Detected SELinux NOT disabled for EL9
    Adding selinux=0 to Kernel GRUB_CMDLINE_LINUX line in /etc/default/grub
    grubby --update-kernel ALL --args selinux=0
    GRUB_CMDLINE_LINUX="console=ttyS0,115200n8 no_timer_check net.ifnames=0 crashkernel=1G-4G:192M,4G-64G:256M,64G-:512M selinux=0"
    Added selinux=0 to Kernel GRUB_CMDLINE_LINUX line in /etc/default/grub to disable SELinux
    This is the right way to disable SELinux in future as other run-time methods deprecated
    If you intend to use own custom Linux Kernels i.e. ELRepo, ensure you have selinux=0 set
    Please reboot system to disable SELinux then install Centmin Mod
    [root@cloudsv ~]#
    Could you help to have a look on above again?
    If i could not find out the root causes, i guess i will just try the Letsencrypt SSL option then.
    Thank you very much!
    55,180
    12,251
    6:51 PM
    That's normal as per message conveyed
    Sounds like you misconfigured Centmin Mod Nginx's paid SSL certificate configuration so Cloudflare Full SSL strict mode is saying your certificate is invalid
