Letsencrypt SSL installation issue
Discussion in 'Domains, DNS, Email & SSL Certificates' started by kayx, Nov 29, 2018.
  1. kayx
    kayx New Member
    3:02 AM
    i have followed step by step guide to install SSL for my test domain: s4.smartr.club.
    But seems not working.
    Anyone can help me to check what is the issue ?
    I have run test on SSL Server Test (Powered by Qualys SSL Labs). It shows certificate mismatch.
    49,887
    11,487
    5:02 AM
    which guide there's a few for either paid ssl certs or letsencrypt free ssl certs
    If it's letsencrypt ssl via centmin mod 123.09beta01, then wow was the initial letsencrypt ssl certificate obtained ? Which method ?
    • Was the domain nginx vhost alreadying created prior or new domain nginx vhost site setup for first time ?
    • Via centmin.sh menu option 2, 22, /usr/bin/nv ?
    • If you ran centmin.sh menu option 2 or 22, which letsencrypt option did you select from
      Setup full Nginx vhost + Wordpress + WP Plugins
      Enter vhost domain name you want to add (without www. prefix): acme3.domain1.com
      You have 4 options:
      1. issue staging test cert with HTTP + HTTPS
      2. issue staging test cert with HTTPS default
      Enter option number 1-4: 1
    • Via addons/acmetool.sh ? which specific command ? examples
      ./acmetool.sh issue acme.domain.com
      ./acmetool.sh issue acme.domain.com live
      ./acmetool.sh issue acme.domain.com d
      ./acmetool.sh issue acme.domain.com lived
    • What was order of steps you did ? Did you run centmin.sh menu option 2 first with letsencrypt ? Then did you run addons/acmetool.sh afterwards ?
    Troubleshooting
      ls -lahrt /root/centminlogs
      ACMEDEBUG='y'
    If acme.sh auto renewals didn't happen, check output for the following commands
    grep acme /var/log/cron* | sed -e "s|$(hostname -s)|host|g"
    echo | openssl s_client -connect yourdomain.com:443
    SSLLabs Test
    Also run your HTTPS domain site through SSLLabs tester at SSL Server Test (Powered by Qualys SSL Labs) if it says untrusted SSL cert and prompts to continue the test, continue the test.
