SSL SSL Connection Error
Discussion in 'Domains, DNS, Email & SSL Certificates' started by Jota, Jul 22, 2017.
  1. Jota
    Jota Member
    78
    Barcelona
    7:30 AM
    Hey guys ! ;)
    I tried this in different Centmin mod servers, and always getting same issue.
    When I do create a WP site with let's encrypt enabled, all works fine, but any kind of problem with SSL, I always get SSL Connection error on Pingdom tests.
    See --> Snaggy - easy screenshots
    Anyone knows how to fix this ?
    Seems a root or CA issue, but don't know how to fix this.
    I do have latest centmin mod beta just installed a fresh box 2h ago, centos 6.9 fully updated, openvz VPS.
    Thanks ;)
    45,406
    10,302
    2:30 PM
  3. Jon Snow
    Jon Snow Active Member
    556
    72
    1:30 AM
    Nginx 1.13.9
    MariaDB 10.1.31
    Disabling IPv6 worked for me since SSL was properly installed according to the tools I used to check.
    To disable IPv6 :
    Edit /etc/sysctl.conf and add the following (if it's set to 0, just change it to 1):
    net.ipv6.conf.all.disable_ipv6 = 1
    net.ipv6.conf.default.disable_ipv6 = 1
    Run the following command via SSH :
    sysctl -p
    Pingdom's test should work fine after.
  4. Jota
    Jota Member
    78
    Barcelona
    7:30 AM
    45,406
    10,302
    2:30 PM
    the ssllabs report looks good to me so nothing wrong there
    tested site with gtmetrix.com and webpagetest.org as well ?
  6. Jota
    Jota Member
    78
    Barcelona
    7:30 AM
    Rest of sites load fine, I also can access and manage WP admin panel with SSL without any issue.
    But I've been seeing this just with centmin mod, and I tested on different servers, always same issue.
    Anyone can help please ? thanks !
    45,406
    10,302
    2:30 PM
    curl -Iv https://domain.com
    curl -Iv https://www.domain.com
    curl -Iv http://domain.com
    curl -Iv http://www.domain.com
    nginx -V
    wrap output in CODE tags
  8. Jota
    Jota Member
    78
    Barcelona
    7:30 AM
    I just came back from travelling, let's go to work :)
    There's just SSL conf file, as I installed it.
    cat /usr/local/nginx/conf/conf.d/sub.domain.net.ssl.conf
    #x# HTTPS-DEFAULT
       server_name sub.domain.net www.sub.domain.net;
       return 302 https://$server_name$request_uri;
      listen 443 ssl http2;
      include /usr/local/nginx/conf/ssl/sub.domain.net/sub.domain.net.crt.key.conf;
      http2_max_field_size 16k;
      http2_max_header_size 32k;
      # mozilla recommended
      ssl_ciphers EECDH+CHACHA20:EECDH+CHACHA20-draft:EECDH+ECDSA+AESGCM:EECDH+aRSA+AESGCM:EECDH+ECDSA+SHA256:EECDH+ECDSA+SHA384:EECDH+aRSA+SHA256:EECDH+aRSA+SHA384:EECDH+AES128:!aNULL:!eNULL:!LOW:!3DES:!MD5:!EXP:!PSK:!SRP:!DSS:!RC4:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA:!CAMELLIA;
      #spdy_headers_comp 5;
      ssl_buffer_size 1369;
      ssl_session_tickets on;
      # enable ocsp stapling
      resolver_timeout 10s;
      ssl_stapling on;
      ssl_stapling_verify on;
      # ssi  on;
      access_log /home/nginx/domains/sub.domain.net/log/access.log combined buffer=256k flush=5m;
      error_log /home/nginx/domains/sub.domain.net/log/error.log;
      include /usr/local/nginx/conf/autoprotect/sub.domain.net/autoprotect-sub.domain.net.conf;
      root /home/nginx/domains/sub.domain.net/public;
      # server and/or vhost site
      include /usr/local/nginx/conf/wpincludes/sub.domain.net/wpcacheenabler_sub.domain.net.conf;
      #include /usr/local/nginx/conf/wpincludes/sub.domain.net/wpsupercache_sub.domain.net.conf;
      # Redis - How to install Redis server on Centmin Mod LEMP stack
      #include /usr/local/nginx/conf/wpincludes/sub.domain.net/rediscache_sub.domain.net.conf;
      #autoindex  on;
      # for wp cache enabler plugin
      try_files $cache_enabler_uri $uri $uri/ $custom_subdir/index.php?$args;
      # Wordpress Permalinks
      # Nginx level redis Wordpress
        #limit_conn xwpconlimit 30;
        auth_basic "Private";
        #auth_basic_user_file /home/nginx/domains/sub.domain.net/htpasswd_wplogin;
    location ~* /(xmlrpc\.php) {
      include /usr/local/nginx/conf/wpincludes/sub.domain.net/wpsecure_sub.domain.net.conf;
      include /usr/local/nginx/conf/pre-staticfiles-local-sub.domain.net.conf;
    curl -Iv https://sub.domain.net
    * About to connect() to sub.domain.net port 443 (#0)
    *   Trying 10.20.30.40... connected
    * Connected to sub.domain.net (185.47.129.166) port 443 (#0)
    * Initializing NSS with certpath: sql:/etc/pki/nssdb
    *   CAfile: /etc/pki/tls/certs/ca-bundle.crt
      CApath: none
    * SSL connection using TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
    * Server certificate:
    *       subject: CN=sub.domain.net
    *       start date: Jul 21 18:10:00 2017 GMT
    *       expire date: Oct 19 18:10:00 2017 GMT
    *       common name: sub.domain.net
    *       issuer: CN=Let's Encrypt Authority X3,O=Let's Encrypt,C=US
    > HEAD / HTTP/1.1
    > User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 NSS/3.27.1 zlib/1.2.3 libidn/1.18 libssh2/1.4.2
    > Host: sub.domain.net
    > Accept: */*
    < HTTP/1.1 200 OK
    HTTP/1.1 200 OK
    < Date: Fri, 04 Aug 2017 15:10:39 GMT
    < Content-Type: text/html; charset=UTF-8
    < Connection: keep-alive
    < Vary: Accept-Encoding
    < Server: nginx centminmod
    < X-Powered-By: centminmod
    * Connection #0 to host sub.domain.net left intact
    * Closing connection #0
    curl -Iv http://sub.domain.net
    * About to connect() to sub.domain.net port 80 (#0)
    * Connected to sub.domain.net (185.47.129.166) port 80 (#0)
    > HEAD / HTTP/1.1
    > Accept: */*
    < HTTP/1.1 302 Moved Temporarily
    < Date: Fri, 04 Aug 2017 15:12:48 GMT
    < Content-Length: 154
    Content-Length: 154
    < Location: https://sub.domain.net/
    curl -Iv https://www.sub.domain.net
    * About to connect() to www.sub.domain.net port 443 (#0)
    * Connected to www.sub.domain.net (185.47.129.166) port 443 (#0)
      CApath: none
    > HEAD / HTTP/1.1
    > Host: www.sub.domain.net
    > Accept: */*
    < HTTP/1.1 301 Moved Permanently
    < Date: Fri, 04 Aug 2017 15:18:42 GMT
    < Set-Cookie: PHPSESSID=7n25q9k669qpk4ma5a29phhtk4; path=/
    < Expires: Thu, 19 Nov 1981 08:52:00 GMT
    < Cache-Control: no-store, no-cache, must-revalidate
    < Pragma: no-cache
    Pragma: no-cache
    * Connection #0 to host www.sub.domain.net left intact
    curl -Iv http://www.sub.domain.net
    * About to connect() to www.sub.domain.net port 80 (#0)
    *   Trying 185.47.129.166... connected
    * Connected to www.sub.domain.net (185.47.129.166) port 80 (#0)
    > HEAD / HTTP/1.1
    > Accept: */*
    < Date: Fri, 04 Aug 2017 15:20:21 GMT
    Content-Length: 154
    nginx -V
    nginx version: nginx/1.13.3
    built with LibreSSL 2.5.5
    TLS SNI support enabled
    configure arguments: --with-ld-opt='-lrt -ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib' --with-cc-opt='-m64 -mtune=native -g -O3 -fstack-protector -fuse-ld=gold --param=ssp-buffer-size=4 -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wno-sign-compare -Wno-string-plus-int -Wno-deprecated-declarations -Wno-unused-parameter -Wno-unused-const-variable -Wno-conditional-uninitialized -Wno-mismatched-tags -Wno-sometimes-uninitialized -Wno-parentheses-equality -Wno-tautological-compare -Wno-self-assign -Wno-deprecated-register -Wno-deprecated -Wno-invalid-source-encoding -Wno-pointer-sign -Wno-parentheses -Wno-enum-conversion -Wno-c++11-compat-deprecated-writable-strings -Wno-write-strings' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-compat --with-http_stub_status_module --with-http_secure_link_module --with-libatomic --with-http_gzip_static_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module=dynamic --with-http_geoip_module --with-stream_geoip_module --with-stream_realip_module --with-stream_ssl_preread_module --with-threads --with-stream=dynamic --with-stream_ssl_module --with-http_realip_module --add-dynamic-module=../ngx-fancyindex-0.4.0 --add-module=../ngx_cache_purge-2.3 --add-module=../ngx_devel_kit-0.3.0 --add-module=../set-misc-nginx-module-0.31 --add-module=../echo-nginx-module-0.60 --add-module=../redis2-nginx-module-0.14 --add-module=../ngx_http_redis-0.3.7 --add-module=../memc-nginx-module-0.18 --add-module=../srcache-nginx-module-0.31 --add-module=../headers-more-nginx-module-0.32 --with-pcre=../pcre-8.41 --with-pcre-jit --with-zlib=../zlib-1.2.11 --with-http_ssl_module --with-http_v2_module --with-openssl=../libressl-2.5.5
    45,406
    10,302
    2:30 PM
    your nginx vhost is missing ocsp stapling related syntax
    i.e. if you use Generate Centmin Mod Nginx Vhost - CentminMod.com LEMP Nginx web stack for CentOS and set domain = sub.domain.net and check ssl self-signed/letsencrypt check box
    you'll see missing a single line of letsencrypt syntax for nginx ssl_trusted_certificate directive at bottom of vhost.php generated page for
    you have
      ssl_stapling on;
    while it should be
      ssl_stapling on;
      ssl_trusted_certificate /usr/local/nginx/conf/ssl/sub.domain.net/sub.domain.net-acme.cer;
    make sure /usr/local/nginx/conf/ssl/sub.domain.net/sub.domain.net-acme.cer exists first though not sure if this is why you have issues
    restart nginx service
  10. Jota
    Jota Member
    78
    Barcelona
    7:30 AM
    Adding that line at config file and restarting gave a duplicated error, also didn't change anything in the pingdom tests:
    nginx: [emerg] "ssl_trusted_certificate" directive is duplicate in /usr/local/nginx/conf/conf.d/sub.domain.net.ssl.conf:38
    45,406
    10,302
    2:30 PM
    remove that line then seems it is added to
    /usr/local/nginx/conf/ssl/sub.domain.net/sub.domain.net.crt.key.conf IIRC
    still having pingdom test issues ?
  12. Jota
    Jota Member
    78
    Barcelona
    7:30 AM
    Yes, still having this issue.
    But I'm sure this is happening anyone using centmin mod + let's encrypt, coz I tested same thing on multiple fresh test centmin boxes and always same problem.
    45,406
    10,302
    2:30 PM
    all on same server/web host or some different servers or different web hosts ?
    I haven't run into this once yet myself.
    On XF forums one person said changing their ssl ciphers from Centmin Mod ones helped with pingdom issue dispite no problems with normal non-pingdom access
    Centmin Mod ones
    to Mozilla intermediates helped them
    ssl_ciphers 'ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS';
    restart nginx
    but them again some XF users reported using Mozilla ones also had the pingdom problem
  14. Jota
    Jota Member
    78
    Barcelona
    7:30 AM
    I'll try this next .....
    I tried this SSL tests on multiple fresh VPS servers on multiple and different providers / nodes (tested in our nodes, in Vultr, in Digital Ocean) .... always same problem. Even with a fresh clean WP site, always same problem.
    So weird ..... I'll try ur suggestion soon, let's see.
  15. Jota
    Jota Member
    78
    Barcelona
    7:30 AM
    Hey ! seems that this one worked ! Yay ! Thanks a lot !!! ;)
    45,406
    10,302
    2:30 PM
  17. Jimmy
    365
    12:30 AM
    1.17.x
    I noticed that the old ssl_ciphers vs. the new ones lack a lot of the ! entries.
    Should those be included? It appears only !DSS is on the new list.
    45,406
    10,302
    2:30 PM
    not needed anymore as latest openssl and libressl have deprecated most of those ssl ciphers so no need to disable them at ssl_cipher level
