SoYouStart.com dedicated servers
Discussion in 'Dedicated server hosting' started by eva2000, Jun 1, 2014.
    10:02 PM
    This is the same server I just purchased, and now using Live on my forum.
    Just transfer my Live Forum last few minutes :)
    12:02 AM
    wow you must have server migrations down to an art form by now :D
    So what you doing with the older SoYouStart server ? Isn't that the same server hardware specs too ?
  3. rdan
    10:02 PM
    haha 20GB+ files and DB took me almost 10 minutes downtime/closed forum.
    Yeah the old server has same specs except I only got 2x120GB SSD and I'm paying more, it's 63 USD + 14 = $77USD month.
    12:02 AM
    Ah I see.. yeah suppose same network transfer must of been much faster >20-40MB/s ?
    Strange visiting their forums at https://forum.ovh.us/forum.php Chrome 37 and Opera 24 give me site unavailable on first load, refresh page and works. Seems their https SSL setup needs work as it uses SHA-1 and limited to TLS 1.0 and SSLv3 connections with no support for TLS 1.1 and TLS 1.2 and no forward secrecy Qualys SSL Labs - Projects / SSL Server Test / forum.ovh.us
    Ah just noticed the SSL certificate expires in 16 days !
  5. rdan
    10:02 PM
    No problem for me, maybe because I already visited it lately.
    Forgot to copy the transfer rate :D
    12:02 AM
    yeah I've had this for a while on their forums but only checked out their SSL with ssllabs today.
    12:02 AM
    okay 4hrs after SoYouStart ID validation confirmation and I have new server setup ready for me.. very nice
    no horror stories of delays - so all up 15hrs for SoYouStart ID validation + 4 hrs for SoYouStart 32G E3-1245v2 SoftRaid 3x120GB SSD server setup = 19hrs all up from time of order :D
  8. rdan
    10:02 PM
    Mine didn't take that long.
    I contact their support after I sent identity validation :)
    I think only takes 2 to 3 hours.
    12:02 AM
    Yeah.. maybe they're busy heh. So now to navigate the control panel and stuff - using this SoYouStart server to test virtualisation with Xen and KVM VPSes :)
    12:02 AM
    I'm alive custom CentOS 6.5 64bit OS with distro kernel selected at reinstall :D
  11. rdan
    10:02 PM
    Headless VNC Install to have a minimal setup :)
    12:02 AM
    not headless VNC, just normal CentOS reinstall from dashboard right now. Playing with all options first :D
  13. rdan
    10:02 PM
    Yes, I mean I suggest you install it via VNC with a minimal server :D
    That's what I always do :)
    12:02 AM
    Yeah plan to, just playing with all that SoYouStart has to offer for now :D
    testing the 120GB Intel 320 SSD series on the SoYouStart server for both normal raid 1 and my fast drive setup :D
    Intel 320 SSD info
            Model Number:       INTEL SSDSA2CW120G3
            Serial Number:
            Firmware Revision:  4PC10362
    Intel 320 SSD ratings
    Performance
    Sustained Sequential Read
    Up to 270MBps
    Sustained Sequential Write
    Up to 130MBps
    MTBF
    1,200,000 hours
    hdparm -t /dev/sda
    /dev/sda:
    Timing buffered disk reads: 648 MB in  3.00 seconds = 215.88 MB/sec
    hdparm -t /dev/sdb
    /dev/sdb:
    Timing buffered disk reads: 654 MB in  3.00 seconds = 217.91 MB/sec
    hdparm -t /dev/sdc
    /dev/sdc:
    Timing buffered disk reads: 640 MB in  3.01 seconds = 212.86 MB/sec
    cd /
    dd bs=1M count=512 if=/dev/zero of=test conv=fdatasync
    512+0 records in
    512+0 records out
    536870912 bytes (537 MB) copied, 4.03928 s, 133 MB/s
    cd /fastdrive/
    512+0 records in
    512+0 records out
    536870912 bytes (537 MB) copied, 1.53197 s, 350 MB/s
  15. rdan
    10:02 PM
    How? What do you mean by this? :unsure:
    12:02 AM
    At install time using SoYouStart partition manager create a raid 0 partition across 3x 120GB Intel 320 SSD, see each has around 130MB/s, so 3x in raid 0 = 350MB/s :D
    cat /proc/mdstat
    Personalities : [raid1] [raid0]
    md1 : active raid1 sdc1[2] sdb1[1] sda1[0]
          81918912 blocks [3/3] [UUU]
    md2 : active raid0 sdc2[2] sda2[0] sdb2[1]
          12578304 blocks 512k chunks
    unused devices: <none>
    df -hT
    rootfs         rootfs     77G  1.6G   72G   3% /
    devtmpfs       devtmpfs   16G  212K   16G   1% /dev
    tmpfs          tmpfs      16G     0   16G   0% /dev/shm
    /dev/md1       ext4       77G  1.6G   72G   3% /
    /dev/md2       ext4       12G  670M   11G   6% /fastdrive
    /dev/md1       ext4       77G  1.6G   72G   3% /var/named/chroot/etc/named
    /dev/md1       ext4       77G  1.6G   72G   3% /var/named/chroot/var/named
    /dev/md1       ext4       77G  1.6G   72G   3% /var/named/chroot/etc/named.conf
    /dev/md1       ext4       77G  1.6G   72G   3% /var/named/chroot/etc/named.rfc1912.zones
    /dev/md1       ext4       77G  1.6G   72G   3% /var/named/chroot/etc/rndc.key
    /dev/md1       ext4       77G  1.6G   72G   3% /var/named/chroot/usr/lib64/bind
    /dev/md1       ext4       77G  1.6G   72G   3% /var/named/chroot/etc/named.iscdlv.key
    /dev/md1       ext4       77G  1.6G   72G   3% /var/named/chroot/etc/named.root.key
  17. rdan
    10:02 PM
    Can't be done anymore on my live server?
    Only possible during install?
    To late I just know this today :(
    12:02 AM
    yeah if you allocated all disk space, then can't be done now, only on reinstall :)
    12:02 AM
  20. rdan
    10:02 PM
    Just a picture, not a big deal :D
