Nginx PageSpeed Some Images Not Being Optimized
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by xhash, Dec 24, 2015.
  1. xhash
    xhash New Member
    6
    3:37 AM
    1.9.9
    10.0.23-MariaDB MariaDB Server
    Hi there,
    I've recently installed the following:
    CentOS 6.5 + Centmindmod with NginX, PageSpeed, MariaDB, CSF etc (performed the auto install).
    I've run into an issue with compression - for some odd reason, 3 images simply wont be compressed, I am out of luck as to why.
    I checked Google to see if other users were also experiencing the same issue - apparently 'noauth' and 'nocache' should not be set on these images (they aren't from what I can tell), also these images are being appended with .pagespeed as seen from the above report from Insights.
    The website address is: Positive Lending Solutions | #1 Car Loans Aus Wide
    Google Insights: PageSpeed Insights
    pagespeed.conf file:
    38,659
    8,533
    2:37 AM
  3. xhash
    xhash New Member
    6
    3:37 AM
    1.9.9
    Hi eva2000,
    Thanks for the quick response, I've searched the forums and already gone through both of those links - unfortunately I can't seem to get just 3 (out of probably 60+ images to optimize).
    Any other suggestions?
    38,659
    8,533
    2:37 AM
    troubleshooting links should direct you to looking into ngx_pagespeed message logs page for clues :) The message log page has a search filter you can run for image names
  5. xhash
    xhash New Member
    6
    3:37 AM
    1.9.9
    Hi eva2000,
    If you're referring to the message history which is available here: http://ps.amebae.com/pagespeed_global_admin/message_history
    It's already been checked - I couldn't attach it to my first response (it wouldn't allow me to create the thread I believe due to the size of my post), I've listed it here on Gist: gist:09f9a840cde6415a413a · GitHub
    If I use an example of one of the images that Insights is reporting is 'not optimized', the logs state that it has been shrunk:
    [Wed, 23 Dec 2015 15:11:36 GMT] [Info] [23559] http://ps.amebae.com/:623: Shrinking image `http://ps.amebae.com/uploads/blogs/11/fit_204x157_baloon_payment_header_image.png' (34108 bytes) to `http://ps.amebae.com/uploads/blogs/..._header_image.png.pagespeed.ic.Vr2GMnIzLK.png' (25572 bytes)
    The above file-name corresponds with what is listed at Google Insights.
    PS. I can normally troubleshoot issues myself, however I have spent almost 6 hours trying to figure out why it isn't working to no avail.
    38,659
    8,533
    2:37 AM
    curl tests show that image was resized so google pagespeed insights is wrong !
    34108 bytes original
    curl -I http://ps.amebae.com/uploads/blogs/11/fit_204x157_baloon_payment_header_image.png
    HTTP/1.1 200 OK
    Date: Wed, 23 Dec 2015 16:01:41 GMT
    Content-Type: image/png
    Content-Length: 34108
    Last-Modified: Mon, 21 Dec 2015 01:28:46 GMT
    Connection: keep-alive
    ETag: "567755ce-853c"
    Server: nginx centminmod
    Expires: Thu, 22 Dec 2016 16:01:41 GMT
    Cache-Control: max-age=31536000
    Accept-Ranges: bytes
    25572 bytes pagespeed optimised
    curl -I http://ps.amebae.com/uploads/blogs/11/xfit_204x157_baloon_payment_header_image.png.pagespeed.ic.Vr2GMnIzLK.png
    HTTP/1.1 200 OK
    Content-Length: 25572
    Date: Wed, 23 Dec 2015 15:12:35 GMT
    Expires: Thu, 22 Dec 2016 15:12:35 GMT
    ETag: W/"0"
    Last-Modified: Wed, 23 Dec 2015 15:12:35 GMT
    X-Page-Speed: 1.9.32.11-7553
  7. xhash
    xhash New Member
    6
    3:37 AM
    1.9.9
    I also ran the same cURL test, verified it via Firebug to see 'X-Page-Speed: 1.9.32.11-7553'
    :/ I thought as much, is it normal for Google Insights to push out false-positives? because I've noticed that sometimes the statistics are inconsistent at times, there's no explanation at all or anything that I can locate to see why this happens...
    38,659
    8,533
    2:37 AM
    from gtmetrix looks like the images can be compressed and optimised further than ngx_pagespeed did Latest Performance Report for: http://ps.amebae.com/?PageSpeed=on | GTmetrix
    38,659
    8,533
    2:37 AM
    not exactly curl on optimized version of that image shows 25696 bytes
    curl -I https://gtmetrix.com/reports/ps.amebae.com/fx7AD6Aj/pagespeed/fit_204x157_baloon_payment_header_image_4dc5f5f6b76b19b54e2e1d9d6198a720.png
    HTTP/1.1 200 OK
    Date: Wed, 23 Dec 2015 16:12:53 GMT
    Server: Apache
    Last-Modified: Wed, 23 Dec 2015 16:09:49 GMT
    Content-Length: 25696
    Strict-Transport-Security: max-age=15768000; includeSubDomains; preload
    so larger than ngx_pagespeed's 25572 bytes heh
  10. xhash
    xhash New Member
    6
    3:37 AM
    1.9.9
    Thanks Eva, you've been extremely helpful, ill be able to take it from here.
    38,659
    8,533
    2:37 AM
    enjoy :D
