Nginx [Solved] Problem adding .me vhost on beta branch
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Shmee, Sep 23, 2016.
  1. Shmee
    Shmee New Member
    15
    Space
    4:03 PM
    Something goes wrong and normal http DOES NOT work when adding a .me vhost
    If I go to https self signed it DOES work and I get the normal
    Welcome to domain.me. This index.html page can be removed.
    Useful Centmin Mod info and links to bookmark.
    Fresh beta branch install.
    My normal .com vhost work fine. The problem seems to be just the normal http conf
    38,557
    8,512
    4:03 PM
  3. Shmee
    Shmee New Member
    15
    Space
    4:03 PM
    resolved
  4. Shmee
    Shmee New Member
    15
    Space
    4:03 PM
    I just noticed [] works, but without www i get Centmin Mod Nginx Test Page
    edit: I'm wondering if this is a dns issue.
    38,557
    8,512
    4:03 PM
  6. Shmee
    Shmee New Member
    15
    Space
    4:03 PM
    That did it. I change virtual.conf to server.domain.me and now it's working just fine.
    Thank you for the help!
    38,557
    8,512
    4:03 PM
    yeah i should update centmin mod to prevent users adding a new nginx vhost with a domain that matches server_name in virtual.conf to prevent this :)
    38,557
    8,512
    4:03 PM
    Updated Centmin Mod 123.09beta01 nginx vhost generator to check for main hostname domain in 123.09beta01
    prevent folks from accidentally creating a new nginx vhost that matches the main server hostname domain name vhost Nginx - [Solved] Problem adding .me vhost on beta branch | Centmin Mod Community
    example
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    11). MariaDB 5.2/5.5 & 10.x Upgrade Sub-Menu
    14). SELinux disable
    16). Change SSHD Port Number
    20). NSD Install/Re-Install
    24). Exit
    Enter option [ 1 - 24 ] 2
    Important Information
    You are about to create an Nginx vhost site account with/without
    HTTPS/SSL support. Details of this process are outlined on site
    at centminmod.com/nginx_domain_dns_setup.html. Also read the
    continually updated Getting Started Guide for Centmin Mod usage
    at centminmod.com/getstarted.html which covers the pure-ftpd
    ftp username that is auto generated with the Nginx vhost site.
    Do you want to continue with Nginx vhost site creation ? [y/n] y
    Enter vhost domain name to add (without www. prefix): centos7.localdomain
     Error: centos7.localdomain is already setup for server main hostname
     at /usr/local/nginx/conf/conf.d/virtual.conf
     It is important that main server hostname be setup correctly
     As per Getting Started Guide Step 1 centminmod.com/getstarted.html
     The server main hostname needs to be unique. So please setup
     the main server name vhost properly first as per Step 1 of guide.
     Aborting nginx vhost creation...
