Small Issue. CMM Hangs again.
Discussion in 'Bug Reports' started by EckyBrazzz, May 14, 2019.
    173
    12:13 AM
    Installed a new site and made a little mistake, well thought kill CMM and start over again, but no go this time. No way to exit Centmin
    Disable Auto Generated WP Admin Username / Password ? [y/n]: y wanted to select n
    You have 4 options:
    1. issue staging test cert with HTTP + HTTPS (untrusted)
    2. issue staging test cert with HTTPS default (untrusted)
    3. issue live cert with HTTP + HTTPS (trusted)
    4. issue live cert with HTTPS default (trusted)
    Enter option number 1-4: 4
    Theme Setup:
    Install CyberChimps Responsive Theme (cyberchimps.com/responsive-theme/) [y/n]: n
    Wordpress Setup:
    Not a fan of Gutenberg Editor ? You can switch to Classic Editor
    If you run into Gutenberg Editor issues, you can later switch to
    the Classic Editor https://wordpress.org/plugins/classic-editor/
    Install Classic Editor Wordpress Plugin ? [y/n]: y
    Autoptimize WP Plugin is installed by default. Do you want to install
    companion Autoptimize Gzip Plugin to precompresses js/css optimized files
    details at https://community.centminmod.com/threads/15314/
    Install Autoptimize Gzip Companion Wordpress Plugin ? [y/n]: y
    Set custom WP Admin Display Name ? [y/n]: n
    Install Wordpress in subdirectory /blog ? [y/n]: n
    Disable wp-login.php password protection ? (less security) [y/n]: ^X^C^Z
    y
    n
    43,121
    9,788
    1:13 PM
    you should be able to just hit backspace key to change y to n so no need to kill the process - that far in it would probably hang as some routines/question prompts go through a while/read loop
  3. EckyBrazzz
    173
    12:13 AM
    But that is impossible because I already hit the enter key. Just noticed it to late
    43,121
    9,788
    1:13 PM
    I see. Probably easiest thing for that specific prompt it to just continue forward and just disable wp-login.php password protection after wordpress install. I think the hang at that specific prompt after hitting enter is there's a yum install for cracklib yum package if it doesn't exist which checks end users entered passwords to make sure password strength is up to task and not using weak passwords. I should add cracklib yum package earlier into initial install routines then - though I believe it is already :)
  5. EckyBrazzz
    173
    12:13 AM
    haha, glad I gave you something to fix;). But check it on ALL entries.
    • Funny Funny x 1
    43,121
    9,788
    1:13 PM
    reminds also if I should also be adding checks for re-used or pwn'd/breached passwords via Pwned Passwords API from Have I Been Pwned database centminmod/checkpasswords :)
