Small cosmetic fix for centmin.sh path info
Discussion in 'Bug Reports' started by pamamolf, Feb 28, 2016.
    4,101
    428
    2:10 AM
    Nginx-1.26.x
    Hi
    I was just run centmin.sh and i got this:
    SELINUX linux detected
    disabling SELINUX...
    will require a server reboot before running initial install
    SELINUX disabled, please reboot server and rerun install
    on reboot you can find the centmin.sh file located at:
    echo /usr/local/src/centminmod-123.09beta01
    I think you should hide the "echo" :)
    I love centminmod that's why i report delays for it just to be perfect :)
  2. pamamolf
    4,101
    428
    2:10 AM
    Nginx-1.26.x
    Maybe to change also the default links? :
    http://www.muug.mb.ca/pub/epel/7/x86_64/repodata/c5b1b6a96340468f1f2f2fa3885bb7d83b2b550531bfcfe19a259543231b90a9-primary.sqlite.xz: [Errno 14] HTTP Error 404 - Not Found
    Trying other mirror.
    To address this issue please refer to the below knowledge base article
    https://access.redhat.com/articles/1320623
    If above article doesn't help to resolve this issue please create a bug on https://bugs.centos.org/
    http://fedora.westmancom.com/epel/7/x86_64/repodata/511e52fb435d809f93479279119ab530e40fb4a1d5701e6138d9be990924cdaf-updateinfo.xml.bz2: [Errno 14] HTTP Error 404 - Not Found
    http://linux.mirrors.es.net/fedora-epel/7/x86_64/repodata/511e52fb435d809f93479279119ab530e40fb4a1d5701e6138d9be990924cdaf-updateinfo.xml.bz2: [Errno 14] HTTP Error 404 - Not Found
    http://mirror.umd.edu/fedora/epel/7/x86_64/repodata/511e52fb435d809f93479279119ab530e40fb4a1d5701e6138d9be990924cdaf-updateinfo.xml.bz2: [Errno 14] HTTP Error 404 - Not Found
    http://mirror.sfo12.us.leaseweb.net/epel/7/x86_64/repodata/511e52fb435d809f93479279119ab530e40fb4a1d5701e6138d9be990924cdaf-updateinfo.xml.bz2: [Errno 14] HTTP Error 404 - Not Found
    ftp://ftp.muug.mb.ca/pub/epel/7/x86_64/repodata/c5b1b6a96340468f1f2f2fa3885bb7d83b2b550531bfcfe19a259543231b90a9-primary.sqlite.xz: [Errno 14] FTP Error 550 - Given file does not exist
    http://mirror.cogentco.com/pub/linux/epel/7/x86_64/repodata/c5b1b6a96340468f1f2f2fa3885bb7d83b2b550531bfcfe19a259543231b90a9-primary.sqlite.xz: [Errno 14] HTTP Error 404 - Not Found
    http://ftp.linux.ncsu.edu/pub/epel/7/x86_64/repodata/c5b1b6a96340468f1f2f2fa3885bb7d83b2b550531bfcfe19a259543231b90a9-primary.sqlite.xz: [Errno 14] HTTP Error 404 - Not Found
    http://mirrors.mit.edu/epel/7/x86_64/repodata/c5b1b6a96340468f1f2f2fa3885bb7d83b2b550531bfcfe19a259543231b90a9-primary.sqlite.xz: [Errno 14] HTTP Error 404 - Not Found
    http://mirror.symnds.com/distributions/fedora-epel/7/x86_64/repodata/c5b1b6a96340468f1f2f2fa3885bb7d83b2b550531bfcfe19a259543231b90a9-primary.sqlite.xz: [Errno 14] HTTP Error 404 - Not Found
  3. pamamolf
    4,101
    428
    2:10 AM
    Nginx-1.26.x
    Also zendopcache admin panel file after installation is not located at:
    /usr/local/nginx/html
    55,225
    12,253
    9:10 AM
    that means you didn't disable selinux prior to installing centmin.sh - this was centmin.sh menu option 1 install or curl installer.sh one liner install ? only curl installer.sh disables selinux behind the scenes. The message you got is for folks using centmin.sh menu option 1 install usually
    you vps/server network connectivity has issues or the yum mirror that is mapped automatically by yum is down.. nothing i can do about that
    try yum clean all or clean OS and try again and make sure network connectivity works
    probably related to network connectivity some other required files didn't get downloaded
    does post install check list of main software return their respective version numbers ? nginx and php-fpm restart return output error free ?
  5. pamamolf
    4,101
    428
    2:10 AM
    Nginx-1.26.x
    I hate my english :)
    I just say that on this line:
    the word echo shouldn't be there :)
    It is a brand new server from OVH canada :) Default networking should be ok.......
    Yes nginx -v and php -v is fine also....All working great.
    About the zendopcache admin panel php file why not added to the centminmod and copy it from there ?
