Nginx Several domains keep returning after deletion
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by RB1, Aug 30, 2017.
  1. RB1
    RB1 Active Member
    285
    75
    California
    11:40 PM
    Nginx 1.18.x
    MariaDB 10.1.x
    • Nginx Version Installed: 1.13.4
    • PHP Version Installed: 7.0.19
    • MariaDB MySQL Version Installed: 10.1.26
    • When was last time updated Centmin Mod code base ? : Daily
    • Persistent Config:
      NGXDYNAMIC_NGXPAGESPEED='y'
      NGINX_PAGESPEED='y'
      LETSENCRYPT_DETECT='y'
      ENABLEMOTD_CSFMSG='n'
      ENABLEMOTD_LINKSMSG='n'
      PHP_PGO='y'
    Can't seem to figure out what the issue here is. I have a couple domains that are returning after I deleted them. It's not instant; sometimes they come back after a couple hours to maybe a full day. Weird, right?
    From what I can tell, they only return to /home/nginx/domains with an empty /public/ folder.
    No domain.conf file in /usr/local/nginx/conf/conf.d
    One of the domains I removed manually by deleting the domain folder and vhost file followed by restarting nginx.
    For the other I used these steps:
    rm -rf /usr/local/nginx/conf/conf.d/domain.com.conf
     rm -rf /usr/local/nginx/conf/conf.d/domain.com.ssl.conf
     rm -rf /usr/local/nginx/conf/ssl/domain.com/domain.com.crt
     rm -rf /usr/local/nginx/conf/ssl/domain.com/domain.com.key
     rm -rf /usr/local/nginx/conf/ssl/domain.com/domain.com.csr
     rm -rf /home/nginx/domains/domain.com
     service nginx restart
    Any idea? This has been going on for months.
    Edit: Also thought it could have been something in cron, but I don't think so after looking at it:
    11 */23 * * * /usr/local/src/centminmod/tools/autoprotect.sh 2>/dev/null
    0 */4 * * * /usr/bin/cminfo_updater 2>/dev/null
    #*/15 * * * * sleep 297s ; wget -O - -q -t 1 http://domain.com/wp-cron.php?doing_wp_cron=1 > /dev/null 2>&1
    0 */12 * * * sleep 221s ;/root/tools/wp_updater_domain.com.sh >/dev/null 2>&1
    0 0 * * * "/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null
    15 */3 * * * /root/tools/updatecm.sh 2>/dev/null
    38,586
    8,517
    4:40 PM
    wow never heard that happen before
    Do these domains by any chance use letsencrypt ssl certificates issued via centmin mod's acemtool.sh and integrated letsencrypt routines ? Could be related to acme.sh cron trying to renew letsencrypt ssl certs
    does accompanying directory at /usr/local/nginx/conf/ssl/domain.com also return ?
  3. RB1
    RB1 Active Member
    285
    75
    California
    11:40 PM
    Nginx 1.18.x
    MariaDB 10.1.x
    Nothing related in /usr/local/nginx/conf/ssl/
    I do see /root/.acme.sh/domain.com for one of my problematic domains. I'll delete this folder and see what happens in the next couple of days
    Thanks!
    38,586
    8,517
    4:40 PM
    yeah that might be it, i updated 123.09beta01 and centminmod.com site instructions to remove that directory too now
    • Useful Useful x 1
  5. RB1
    RB1 Active Member
    285
    75
    California
    11:40 PM
    Nginx 1.18.x
    MariaDB 10.1.x
    Update: Yes, the steps you explained fixed the problem!
    38,586
    8,517
    4:40 PM
    excellent :)
