Nginx Setting up aio threads
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Lav, Apr 17, 2020.
  1. Lav
    Lav Member
    49
    1:10 PM
    1.17.8
    10.3
    • Nginx Version Installed: 1.17.10
    • PHP Version Installed: i.e. 5.6.37, 7.0.31, 7.1.21, 7.2.9
    I have set up aio on; by using
    NGINX_IOURING_PATCH_BETA='y'
    . I want to enable aio threads functionalty so for that I need to enter 'aio threads;' in nginxocnf in http field and also do I need to enter
       root /storage;
       aio threads;
    in the same nginxconf file and after it do I need to recompile nginx or not?
    Do I need to do something else also in order to achieve aio threads functionality?
  2. Lav
    Lav Member
    49
    1:10 PM
    1.17.8
    10.3
    On inserting aio threads; under http block in nginxconf, nginx fails to restart.
    49,347
    11,308
    5:40 PM
    goes in your domain's nginx vhost within server{} for location context you wise to enable for
    But NGINX_IOURING_PATCH_BETA='y' only works if you updated your server's Linux kernel from CentOS 7 3.10 versions to 5.1+
  4. Lav
    Lav Member
    49
    1:10 PM
    1.17.8
    10.3
    On inserting this in nginx vhost conf within server {}
       root /storage;
       aio threads;
    nginx fails to restart but when I only enter
    aio threads;
    in nginx vhost conf within server {} then nginx works fine.
    Which one do I need to enter?
    Yes my kernel version is 5.6.xx and aio on; is working fine.
    49,347
    11,308
    5:40 PM
    output for nginx config test command
    nginx -t
  6. Lav
    Lav Member
    49
    1:10 PM
    1.17.8
    10.3
    nginx -t
    nginx: [emerg] duplicate location "/" in /usr/local/nginx/conf/conf.d/domain.com.conf:59
    I have placed the code in domain vhostconf after the second server block
       root /storage;
       aio threads;
    include /usr/local/nginx/conf/pagespeedstatslog.conf;
    49,347
    11,308
    5:40 PM
    you have added a 2nd location / context, you can only have one the existing location / {} context already exists so need to add aio threads line to the existing one
  8. Lav
    Lav Member
    49
    1:10 PM
    1.17.8
    10.3
    If I am understanding it right then I only need to add
    aio threads;
    instead of
       root /storage;
       aio threads;
    in the same place where I have inserted
       root /storage;
       aio threads;
    Is that right?
    49,347
    11,308
    5:40 PM
    yes but not sure you would want to add root /storage as that overrides all web root path = / for entire site
    maybe better for to move it out of location / {} to own location /storage {} context
    location /storage {
      aio threads;
    49,347
    11,308
    5:40 PM
  11. Lav
    Lav Member
    49
    1:10 PM
    1.17.8
    10.3
    Changed it and now nginx is working fine.
    New setup looks like this
    location /storage {
      aio threads;
    Is this good? Anyway to check if this is working fine or not?
    49,347
    11,308
    5:40 PM
  13. pamamolf
    3,993
    417
    10:40 AM
    Nginx-1.17.x
    Are you sure George that can't use it at the main Nginx config under http {
    Don't know why i think that it is possible to set it globally .....
    49,347
    11,308
    5:40 PM
    read Boosting NGINX Performance 9x with Thread Pools as to when aio threads should be used or not - won't help in all situations so you only want to narrow it's usage to a location(s) context
