Nginx Setting resource limit per vHost
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by KlueMaster, Jun 20, 2019.
  1. KlueMaster
    KlueMaster Member
    49
    11:03 AM
    MariaDB 10
    Just wondering if there is a way to set resource limits on vHost level?
    I am planning to use one large VPS instance to host about 5-6 sites. Most of these are WordPress/WooCommerce with light load. However, at times one may see a sudden traffic driven by some consumer promotion. In such cases, I don't want the load times of other sites to suffer. So, if there is a way to set resource usage limit per vHost, then that will be very helpful.
    Gaurav
    44,425
    10,144
    3:33 PM
    Not out of the box for Centmin Mod as all vhosts run under same nginx user/group. If the sites are important enough, having separate VPS server for them would be the best approach from traffic management and security point of view.
