Xenforo Server Config Issue Causing Problems With XenForo
Discussion in 'Forum software usage' started by BamaStangGuy, Aug 6, 2015.
  1. BamaStangGuy
    BamaStangGuy Active Member
    668
    192
    1:16 PM
    We recently did an upgrade using the latest CentminMod and started having the following errors:
    Server Error Log
    Error Info
    Zend_Http_Client_Adapter_Exception: Unable to Connect to ssl://accounts.google.com:443. Error #110: Connection timed out - library/Zend/Http/Client/Adapter/Socket.php:235
    Generated By: Unknown Account, 31 minutes ago
    Stack Trace
    #0 /home/nginx/domains/christianforums.com/public/library/Zend/Http/Client.php(973): Zend_Http_Client_Adapter_Socket->connect('accounts.google...', 443, true)
    #1 /home/nginx/domains/christianforums.com/public/library/XenForo/ControllerPublic/Register.php(1041): Zend_Http_Client->request('POST')
    #2 /home/nginx/domains/christianforums.com/public/library/XenForo/FrontController.php(347): XenForo_ControllerPublic_Register->actionGoogle()
    #3 /home/nginx/domains/christianforums.com/public/library/XenForo/FrontController.php(134): XenForo_FrontController->dispatch(Object(XenForo_RouteMatch))
    #4 /home/nginx/domains/christianforums.com/public/index.php(13): XenForo_FrontController->run()
    #5 {main}
    Request State
    array(3) {
      ["url"] => string(119) "http://www.christianforums.com/register/google?code=4/NLQDmH_UM2_nszR0cjLGE_HGTjdWAYd4PiJ7sxxHNwA&csrf=L6u-zema8MqICzz1"
      ["_GET"] => array(3) {
        ["/register/google"] => string(0) ""
        ["code"] => string(45) "4/NLQDmH_UM2_nszR0cjLGE_HGTjdWAYd4PiJ7sxxHNwA"
        ["csrf"] => string(16) "L6u-zema8MqICzz1"
      ["_POST"] => array(0) {
    This also occurs with Facebook, Twitter and ReCaptcha. It appears anything that connects to a secure connection fails.
    Any ideas what we did wrong?
  2. Andy
    Andy Active Member
    544
    89
    1:16 PM
    I got the same issue, at the time I thought it was with the server since we got some host issue at the time.
    I turn off recapcha no capcha but I believe I still have them complaining about unable to connect to google server for various things such as google sitemap, etc.
    I didn't see anyone reported on XF so I thought only i had this issue.
    55,239
    12,253
    4:16 AM
  4. BamaStangGuy
    668
    192
    1:16 PM
    I opened a ticket and Mike said others have reported it and it probably had something to do with IPV6 server config.
    We have had some reports of this recently, though it's really an issue with your network stack specifically and not something that XF has any direct control over.
    It may be related to Google advertising IPv6 routes and there being issues with your IPv6 network settings. This is something that would need to be addressed on the server itself.
    Regards,
    Mike
  5. BamaStangGuy
    668
    192
    1:16 PM
    5.6
  6. Andy
    Andy Active Member
    544
    89
    1:16 PM
    ipv6 seems to be an issue. But we need to show the host how they can replicate from their ends. Not sure how to do it since it's application specific.
    I run php 5.6.11 and nginx 1.9.3, centos 7.1
    55,239
    12,253
    4:16 AM
    haha guess all you folks are on reliablesite.net hosting Timeouts when downloading resources via SSL/IPv6 | Centmin Mod Community ?
    FYI, quick test you can do for IPv6 enabled servers is curl test for google 443 port.
    on working IPv6 system should return curl IPv6 only test output as follows
    curl -6 -vvvv https://www.google.com/
    *   Trying 2607:f8b0:400a:807::2004...
    * Connected to www.google.com (2607:f8b0:400a:807::2004) port 443 (#0)
    * successfully set certificate verify locations:
    *   CAfile: /etc/pki/tls/certs/ca-bundle.crt
      CApath: none
    * TLSv1.2, TLS handshake, Client hello (1):
    * TLSv1.2, TLS handshake, Server hello (2):
    * TLSv1.2, TLS handshake, CERT (11):
    * TLSv1.2, TLS handshake, Server key exchange (12):
    * TLSv1.2, TLS handshake, Server finished (14):
    * TLSv1.2, TLS handshake, Client key exchange (16):
    * TLSv1.2, TLS change cipher, Client hello (1):
    * TLSv1.2, TLS handshake, Finished (20):
    * SSL connection using TLSv1.2 / ECDHE-RSA-AES128-GCM-SHA256
    * Server certificate:
    *        subject: C=US; ST=California; L=Mountain View; O=Google Inc; CN=www.google.com
    *        start date: 2015-07-23 15:41:59 GMT
    *        expire date: 2015-10-21 00:00:00 GMT
    *        subjectAltName: www.google.com matched
    *        issuer: C=US; O=Google Inc; CN=Google Internet Authority G2
    *        SSL certificate verify ok.
    > GET / HTTP/1.1
    > User-Agent: curl/7.40.0
    > Host: www.google.com
    > Accept: */*
    < HTTP/1.1 200 OK
    < Date: Wed, 05 Aug 2015 19:44:29 GMT
    < Expires: -1
    < Cache-Control: private, max-age=0
    < Content-Type: text/html; charset=ISO-8859-1
    < P3P: CP="This is not a P3P policy! See http://www.google.com/support/accounts/bin/answer.py?hl=en&answer=151657 for more info."
    < Server: gws
    < X-XSS-Protection: 1; mode=block
    < X-Frame-Options: SAMEORIGIN
    < Set-Cookie: PREF=ID=1111111111111111:FF=0:TM=1438803869:LM=1438803869:V=1:S=VMKoP6X7elCoGRjM; expires=Fri, 04-Aug-2017 19:44:29 GMT; path=/; domain=.google.com
    < Set-Cookie: NID=70=p275rU6GHON0AWZURznrNMr54y0Jdx_ecLVR3NDbbgTo1a-nDHMd8EqZGjyojnipQlrAw4nW9bNbA7ZLvDlCg3sdQli8qG2-SxtuBF5sD1Ye7v0V5SAbZ65X2hqPK-Y-; expires=Thu, 04-Feb-2016 19:44:29 GMT; path=/; domain=.google.com; HttpOnly
    < Alternate-Protocol: 443:quic,p=1
    < Accept-Ranges: none
    < Vary: Accept-Encoding
    < Transfer-Encoding: chunked
    on no working IPv6 or IPv6 disabled system curl test over IPv6 should timeout
    * About to connect() to www.google.com port 443 (#0)
    *   Trying 2a00:1450:4001:807::1014...
    * Connection timed out
    * Failed connect to www.google.com:443; Connection timed out
    * Closing connection 0
    curl: (7) Failed connect to www.google.com:443; Connection timed out
    But @deltahf mtr results more useful for web hosts I guess XF 1.4 - Trouble loading resources via SSL | XenForo Community
  8. BamaStangGuy
    668
    192
    1:16 PM
    I opened a ticket with ReliableSite
  9. Andy
    Andy Active Member
    544
    89
    1:16 PM
    my curl ipv6 got timeout
    55,239
    12,253
    4:16 AM
    guess all sorted now ?
  11. Andy
    Andy Active Member
    544
    89
    1:16 PM
    Yes, they sorted it out.
    55,239
    12,253
    4:16 AM
    Great to hear :)
    IPv6 can be a pain heh.. which is why alot of my servers don't have IPv6 or have it disabled :)
    Only site with active IPv6 usage is my sslspdy.com site :)
