Xenforo Seeking help with setting up xenforo
Discussion in 'Forum software usage' started by Artonn, Nov 20, 2023.
  1. duderuud
    duderuud Active Member
    320
    97
    The Netherlands
    10:36 PM
    1.29 x
    11.4
    No, you should use Alma or Rocky 8.
  2. Artonn
    Artonn New Member
    21
    10:36 PM
    Is there a specific reason to go with Alma/Rocky 8 over CentOs 8 ?
  3. duderuud
    320
    97
    The Netherlands
    10:36 PM
    1.29 x
    11.4
  4. Artonn
    Artonn New Member
    21
    10:36 PM
    Alright I will test a new install with AlmaLinux 8 sometime soon, and report back with errors if they appear.
    Anything I should do before running:
    curl -4sL https://centminmod.com/installer-el8x-81.sh -o installer-el8x-81.sh; bash installer-el8x-81.sh
    59,722
    6:36 AM
    You missed epel-release command from that link
    yum -y update
    yum -y install epel-release
    yum -y install screen
    screen -S cminstall -h 2000000
    59,722
    6:36 AM
    59,722
    6:36 AM
    Try following https://community.centminmod.com/th...-mod-on-almalinux-8-rocky-linux-8-oses.23261/ steps to the letter first and see if it works. I did update each installer example in that thread to make it clearer of the yum and screen commands you need to run before running installers.
    59,722
    6:36 AM
    Only real path from CentOS 7 is AlmaLinux or Rocky Linux 8 as CentOS 8 is end of life and no more.
  9. Artonn
    Artonn New Member
    21
    10:36 PM
    Installing on AlmaLinux 8.
    Following this:
    I didn't do the screen part.
  10. duderuud
    320
    97
    The Netherlands
    10:36 PM
    1.29 x
    11.4
  11. Artonn
    Artonn New Member
    21
    10:36 PM
  12. MaximilianKohler
    MaximilianKohler Member
    216
    9
    1:36 PM
    Hetzner has cheaper servers.
  13. Artonn
    Artonn New Member
    21
    10:36 PM
    Do they have a trial period, or free credits for new accounts to test out their service?
  14. MaximilianKohler
    216
    9
    1:36 PM
  15. Artonn
    Artonn New Member
    21
    10:36 PM
    Awesome. I got it all up and running, waiting with the add nginx vhost domain.
    I have my server running currently with my forum active. So I'm wondering and asking for advice for what would be the best way to set up the test server, so I can test on it and get everything up and running while still running my other forum?
    The current forum is running on another droplet, with ubuntu and apache. There's not really any configuration other than the database and xenforo. Which I assume I could just recreate.
    Am I thinking correctly that I should just do a subdomain, where I test and move everything over and then later on I can reconfigure it to be the main domain?
    My dns is cloudflare btw
