Safely using Composer on Centmin
Discussion in 'Other Web Apps usage' started by jscott, Apr 16, 2019.
  1. jscott
    jscott Member
    104
    14
    4:53 AM
    Server Type: openvz
    CentOS Version: 7.6
    Centmin Mod: 123.09beta01.b126
    I am working on converting a project that uses composer to Centminmod.
    The problem is that composer advises you not to use it as a root user!
    With good reason!
    Any suggestions on how to set up a php app with composer as a non-root in Centmin? I have always just used the default setup...
    -Jscott
    55,180
    12,251
    6:53 PM
    So you ran composer as root… – Snipe.Net
  3. jscott
    jscott Member
    104
    14
    4:53 AM
    Sorry, I was not clear in what I am asking.
    I do have composer installed globally, and it is working fine.
    I question comes up when I want to use <code>composer update</code> or <code>composer upgrade</code> to update dependencies for my php application.
    Currently they are ignoring the warning and running as root.
    I want to remove that exploit path.
    Currently, the domains public directory is owned by root and is a member of the nginx group
    Should I create a user for the applications updates and add that user to the nginx group? This is kind of pushing my linux knowledge...
    -Thanks
    jscott
    55,180
    12,251
    6:53 PM
    See the linked article which outlines the proper fix for running composer as a non root user which is to use non root user belonging to webserver group = nginx for centmin mod
