MariaDB Running query
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by dooma, Jul 18, 2017.
  1. dooma
    dooma Active Member
    303
    31
    Cairo
    7:36 PM
    • CentOS Version: i.e. CentOS 7 64bit
    • Centmin Mod Version Installed: i.e. 123.09beta01
    • Nginx Version Installed: i.e. latest
    • PHP Version Installed: i.e. 5.6.30
    • MariaDB MySQL Version Installed: i.e. 10.1.21
    Hello
    How can I run the below query to the database because I have an issue with my XenProducts xenforo addon :
    ALTER TABLE `xenproduct_version`
    ADD COLUMN `is_unsupported` TINYINT(1) NOT NULL DEFAULT '0' AFTER `version_details`
    38,044
    8,358
    3:36 AM
    always backup your database first but just wrap query in mysql -e "YOUR QUERY;" YOURDBNAME for command line or run mysql interactive command to just type those queries in ending with semi colon ; or via text file
    single line command but if you do this in SSH pay attention to backticks as they have a different meaning in SSH = run command so need to be removed
    mysql -e "ALTER TABLE xenproduct_version ADD COLUMN is_unsupported TINYINT(1) NOT NULL DEFAULT '0' AFTER version_details;" YOURDBNAME
    successful run will return empty to prompt
    see
  3. dooma
    dooma Active Member
    303
    31
    Cairo
    7:36 PM
    Thanks SOLVed :)
