Running CentOS 7 on VMWare
Discussion in 'System Administration' started by rdan, May 8, 2015.
    1,386
    4:29 PM
    How can I access or test it on my main system?
    What is the correct URL to access? :)
    Sorry first time using Vmware for server deployment.
    50,478
    11,663
    6:29 PM
    Unfortunately don't use vmware, I use virtualbox, should be same the app sets up a network config for local access i.e. 192.168.0.xxx or something - probably read the documentation or if you paid for vmware app, ask support
    50,478
    11,663
    6:29 PM
    50,478
    11,663
    6:29 PM
    and just if ifconfig -a command to see guest OS assigned ip too
  5. rdan
    1,386
    4:29 PM
    You mean this? :)
    50,478
    11,663
    6:29 PM
    yup for you 192.168.71.xxx would be the range depending what VMWare assigns to your launched guest OS
